Scanner Drivers
Started Oct 5, 2011 | Discussions
Harv
Senior MemberPosts: 2,740
Scanner Drivers
Oct 5, 2011
Mac 10.6.8 Where are the scanner drivers located? I installed the driver for a new scanner loaned by a friend. I do NOT like the scanner. My CS 3 program imports from the NEW scanner but does not see the old scanner. Yes, I have reinstalled the OLD scanner driver. From System Preferences, Print/Fax, I can see the OLD scanner and it works from there.
Help!!! How to rid my computer of the NEW scanner driver.
tonyjr
Veteran MemberPosts: 5,139Gear list
Re: Scanner Drivers
In reply to Harv, Oct 6, 2011
Do a search using magnifying glass . It is probably under / in the users folder .
1st it's a hobby
7D gripped XTI gripped
Canon - efs 10-22 , 17-55 , ef 18-55 IS
EF 28-90 , 28 @ 2.8 , 50 @1.8 , 28-135 IS
L's 35-350 , 70-200 MK II IS
Quantaray lens 70-300 macro
Sigma 135 - 400
2X III , Life Size converter
KSM filters for all
kenko auto tubes , EF 25
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
Harv
Re: Scanner Drivers
In reply to tonyjr, Oct 6, 2011
Thanks for the suggestion but I've done the shallow and deep searches. I've looked into both the personal and the system libraries. I'm beginning to think it might even be in the application itself, so I may try trashing that. Odd that the system preferences printer/fax shows the old scanner and CS3 indicates only the new one. Both are twain.
JEPH
Contributing MemberPosts: 780
Vuescan
Install Vuescan and be set forever?
An option.
Harv
Re: Vuescan
In reply to JEPH, Oct 6, 2011
Vuescan? Good idea. I have it on my computer but have no idea why I never use it.
Thanks!
tonyjr
Re: Scanner Drivers
Vuescan - thanks , I have the minolta quickscan 35 and this is 1st driver I have seen for it . It is a scsi 2 interface .
The bad thing is it only works on an intel Mac - my desktop is a powermac [ G-4 ] but the laptop is a duel core .
1st it's a hobby
Sigma 135 - 400
KSM filters for all
