Problem: Sony TruBlack anti reflection glare lcd display screen film coating failure?
Started Sep 28, 2011 | Discussions
maceo1 New Member • Posts: 18
I'm wondering what folks' experiences are with the anti-glare or anti-reflection coating on the NEX cameras?
After less than a year of careful use, here's what is beginning to happen to my NEX-3:
The anti-reflection coating seems to be wearing off. From another angle:
The Sony TruBlack system, which supposedly includes an anti-reflection film (please see http://www.sony.net/SonyInfo/technology/technology/theme/trublack_01.html )
appears to be abrading away or breaking down in some way.
I had a TX7 point-and-shoot on which I used a typical PET silicone bonded screen-protector and about a year later when I peeled off the protector to replace it, much of the TruBlack anti-reflection film came off with it. It looked very much like this failure:
(The above is on a TX1 borrowed from this thread http://forums.dpreview.com/forums/read.asp?forum=1009&message=37061605 )
I ended up scraping off the remaining coating residue with a plastic scraper! The screen looked better, but it had noticeably lost the higher-contrast, anti-glare characteristics. I'm using a Sony brand adhesive screen protector on my current TX10 (hoping, likely naively, that if the anti-glare fails, Sony might back it up).
I don't want my NEX-3 to suffer a similar fate.
I am familiar with the Sony and GGS rigid protectors as possible solutions, but I'm curious about others' actual experiences with the essential problem...
Will this coating inevitably keep breaking-down?
Will a stick-on protector just lift off the film or contribute to the anti-glare failure?
Thanks!
kage Senior Member • Posts: 1,480
Re: Problem: Sony TruBlack anti reflection glare lcd display screen film coating fail
I've been using both a stick on and a clip on protector since I got my 5, and haven't run into this problem.
  • k
 kage's gear list:kage's gear list
Sony Cyber-shot DSC-V1 Sony Cyber-shot DSC-V3 Sony Cyber-shot DSC-F828 Sony RX100 Sony RX100 II +35 more
Timbo63 Forum Member • Posts: 56
I had the same problem on my NEX-5 after 6 mths, returned under warranty came back good as new. I never abused the screen or got it wet in any way it just happened after time so i doubt that a screen protector would stop it happening. I use the hard Sony clip on protector which I find excellent for protecting against scratches and smearing.
Cheers
Tim
 Timbo63's gear list:Timbo63's gear list
Samyang Reflex 300mm f/6.3 ED UMC CS
Masterbrew Regular Member • Posts: 496
It's just a flimsy layer of plastic. It doesn't do much in the way of protection or glare reduction. Take it off is my advice. I did:
http://dp-master1.dpreview.com/forums/readflat.asp?forum=1042&thread=38076689&page=3
JaccoW Regular Member • Posts: 344
Similar problem here with my Nex-5 after a year. It probably has to do with salts and oils from your fingers. Those things are known to destroy bonding layers.
I just tore it of and replaced it with a hard protector. Less likely to smudge, and easier to clean. I would even put it in a pocket with one.
This forum needs a +1 button. Not just the comments.
 JaccoW's gear list:JaccoW's gear list
Sony Cyber-shot DSC-HX50V Sony Alpha NEX-5 Sony E 18-55mm F3.5-5.6 OSS +3 more
rrfischer Regular Member • Posts: 232
It does protect and reduces glare wonderfully. The problem is that its way too fragile. With Sony's own protector, the LCD, as a screen, is a nice mirror. With only the TruBlack film, it's amazingly good.
Dennis Forum Pro • Posts: 16,392
Same story, within a year. I peeled it off & replaced it with a glass cover. The only problem with the glass cover is that, thin as it is, it's just thick enough that my pop up LCD shade won't shut tightly. But I wasn't terribly enamored of using that anyway.
You can read David Kilpatrick's take on it:
http://www.photoclubalpha.com/2011/04/18/replacing-nex-lcd-cover-glass/
  • Dennis
Greg Gebhardt
Greg Gebhardt Forum Pro • Posts: 25,430
It works well but
Sony is using a cheap applied to glass method rather than a more expensive method where it becomes PART of the glass.
Greg Gebhardt in
Jacksonville, Florida
 Greg Gebhardt's gear list:Greg Gebhardt's gear list
Sony Cyber-shot DSC-RX10 Leica Q Leica M9 Nikon D4
I whole heartedly disagree. I've been barebacking for months now. There isn't a scratch on the glass and because there are no fingerprints, the clarity in sun light is better. It has been a clear improvement and I can only recommend it.
GaryW Veteran Member • Posts: 8,200
Mine scratched pretty early on, but now, the delamination is pretty noticeable. But, I can tell that the part that still has the coating is better -- more anti-glare, higher contrast, etc. But as it wears off, and part is one way and part another, it is a bit distracting.
I don't know that I have the courage to peel this hard layer off and replace it like DK's job. Maybe I'll try adding a film on top. Not sure which one to try.
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Alpha DSLR-A100 +9 more
