EOS Utility
Started Sep 21, 2011 | Discussions
medcapt
Regular MemberPosts: 220Gear list
EOS Utility
Sep 21, 2011
Why won’t Canons EOS Utility start up when I hook up my 7D, I have gone in to the EOS settings and checked the box.
Thanks for the help…
 medcapt's gear list:medcapt's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 50mm f/1.8 II Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm f/2.8L IS II USM +4 more
Lemming51
Forum ProPosts: 12,473Gear list
What operating system?
In reply to medcapt, Sep 21, 2011
For me, think it's a Windows XP (Pro SP-3) thing. I have to open EOS Utility first, then connect the camera, and Utility syncs up with it. If I plug in the camera first and try to pick EOS Utility from the pop-up menu, it doesn't work.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm f/1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM +5 more
medcapt
Re: EOS Utility
Sorry, Windows 7 64bit
cheezit
Regular MemberPosts: 278
Re: EOS Utility
Same here. Running Win7 64bit. I had no problems with win XP.
Anyone got any ideas?
Olga Johnson
Forum ProPosts: 21,489Gear list
Re: EOS Utility
What does Control Panel > Autoplay show for images?
Olga
 Olga Johnson's gear list:Olga Johnson's gear list
Canon EOS 60D Canon EOS 650D Canon EOS M Canon EOS 100D Canon EF 15mm f/2.8 Fisheye +16 more
medcapt
Re: EOS Utility
In reply to Olga Johnson, Sep 21, 2011
Thank You...
Could not remeber what I did before and you jogged my sleeping brain, yes I had autoplay disabled.
Now it works...
Thanks again
ussery
Regular MemberPosts: 275Gear list
Re: EOS Utility
I'm running windows 7, 64 bit since April 2010,and have never had a problem with EOS utility. When I plug my camera in, I turn the camera on, EOS utility starts up and works fine. If it's autoplay that's the problem just click the box on the left top corner that says always do this for this device then click the download images from EOS camera using EOS utility and next time EOS utility should open right up.
No matter what you're shooting, always keep God in the picture.
 ussery's gear list:ussery's gear list
Canon EOS 40D Canon EF 50mm f/1.8 II Canon EF 28-135mm f/3.5-5.6 IS USM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Canon EF 70-300mm f/4-5.6 IS USM
medcapt
Re: EOS Utility
In reply to ussery, Sep 21, 2011
Yep, unless you get tired of autoplay and turn it off like I did.
ussery
Re: EOS Utility
Yes but autoplay doesn't come on after you check the box EOS utility then opens up all by itself.
cheezit
Re: EOS Utility
In reply to ussery, Sep 22, 2011
Need help folks. Mine still doesn't open EU and download images automatically. It does nothing when I connect the 7D. Have to click on EU before download starts.
Autoplay doesn't show EU as one of the choices for pictures. Help!
TIA.
seconds away
Forum MemberPosts: 59
Re: EOS Utility
In reply to cheezit, Sep 22, 2011
Motorola phone software on my Win 7 64 bit PC was preventing autoplay, I removed it and all was good again. It is a known issue with Moto.
Hope this helps someone.
I never use a big word when a diminutive one will do
Olga Johnson
Re: EOS Utility
Did you first connect your 7D and configure EOS Utility and save settings while the camera is connected? My Win7 doesn't show EOS Utility because I seldom have to connect any of my cameras.
Olga
tonyjr
Veteran MemberPosts: 4,991Gear list
thanks
In reply to medcapt, Sep 22, 2011
1st it's a hobby
7D gripped XTI gripped
Canon - efs 10-22 , 17-55 , ef 18-55 IS
EF 28-90 , 28 @ 2.8 , 50 @1.8 , 28-135 IS
L's 35-350 , 70-200 MK II IS
Quantaray lens 70-300 macro
Sigma 135 - 400
2X III , Life Size converter
KSM filters for all
kenko auto tubes , EF 25
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
cheezit
Re: EOS Utility
In reply to Olga Johnson, Sep 22, 2011
Olga
Yes I did. Checked the box "open EOS Utility When camera is connected" Ok, then exit, but it doesn't stay checked.
Very frustrating. Thanx, all.
