8 gigs of RAM in a mini 3,1 ?
Started Sep 13, 2011 | Discussions
Mateo Miller Regular Member • Posts: 473
I use cs4 on a Mac mini 3,1 (2ghz Core2 duo).
Is there a noticeable difference between 4 gigs and 8 gigs of RAM ?
Considering upgrading RAM but only if it makes a difference .
Thx
 Mateo Miller's gear list:Mateo Miller's gear list
Panasonic Lumix DMC-G5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8
Tom_N Forum Pro • Posts: 10,079
Re: 8 gigs of RAM in a mini 3,1 ?
If I recall correctly, CS4 is 32-bit on Macs. The operating system may gain some advantage out of using the extra memory, but CS4 won't directly use it. With CS5 I believe that Adobe did convert CS5 for 64 bits.
Peter Rongsted Senior Member • Posts: 1,641
While it is true that CS4 (it is 32-bit on OS X) will not directly use the extra memory it will be used by the OS for disk cache if not used by other apps. So if you are working with very large files in CS4 it will try to use the scratch file. That will much faster with the extra memory.
With the low price on memory I would make the upgrade.
Peter
 Peter Rongsted's gear list:Peter Rongsted's gear list
Canon PowerShot S95 Nikon D70 Nikon D1X Nikon D700 Olympus E-500 +35 more
MacTracker claims that the Early 2009 Minis (like this one) can take 8 GB of RAM, even though Apple's official limit is 4 GB. Both Crucial and OWC seem to think the Mini can take 8 GB.
On the OWC site, there is an "important" note saying that people with Early 2009 Minis need to install Apple's free EFI Firmware Update 1.2.
http://support.apple.com/kb/DL888
The description of this update says that it "improves compatibility with the latest Apple memory kits on Mac mini computers".
Mateo Miller OP Regular Member • Posts: 473
Good to know.
Jeff Charles Veteran Member • Posts: 7,514
I can confirm that this works. I upgraded the firmware and installed 8GB in my 3,1. No problem.
Jeff
My cat, who likes to sprawl on my keyboard, gets the credit for anything I write that makes sense.
 Jeff Charles's gear list:Jeff Charles's gear list
Sony Cyber-shot DSC-RX100 III Fujifilm X100T Olympus E-M1 Fujifilm X-E2 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +5 more
Andy Hewitt Senior Member • Posts: 2,990
I have the 'Late 2009' MacMini here, which is basically identical to the 'Early' model, but with the EFI update already applied.
I have 8GB in this one, all working fine, and yes, it's definitely worth doing. Especially if you do any Raw photo editing. I started mine off with 5GB (they work OK with unmatched sticks), but even then Aperture was still causing a few Page Outs, it's much better with 8GB.
Don't forget you need to allow for the shared VRAM on these too, which will eat into the main RAM, so more is always going to be better.
Andy Hewitt
 Andy Hewitt's gear list:Andy Hewitt's gear list
Nikon D5100 Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Topaz Adjust Apple iPhone 5c +3 more
dblfitboy
dblfitboy New Member • Posts: 6
I have a 2009 mac mini 3,1 with 8gigs of ram plus I put in a 120 gig ssd hd for my operating system and applications. I also replaced the opticle drive with a 500 gig 7200 rpm hd (with a bracket from owc) for my photos. I run Photoshop CS5 and Lightroom 3 with no problems. There is a noticeable increase in start up speed and processing in Photoshop and Lightroom.
I did the same thing on my late 2008 2 GHz Macbook. 8 gigs ram a 64 gig ssd for the operating system (Lion) and applications. I also replaced the optical drive with a hd for files and photos (adapter from owc). Runs much faster.
 dblfitboy's gear list:dblfitboy's gear list
Samyang 14mm F2.8 IF ED MC Aspherical
