Astrophotography with GPS O-1 !
Started Sep 5, 2011 | Discussions
stephp
Forum MemberPosts: 52Gear list
Sep 5, 2011
Hardware: a K-5, a DA*200/2.8 wide-open, a (solid) tripod and the GPS O-1
Software: Astrotracer function, DeepSkyStacker & Lightroom
Photos: ISO 1600 & 45 seconds for each raw image
Conditions: Slightly hazy sky
The Great Andromeda galaxy (8 raw images stacked):
North America nebula (7 raw images stacked):
 stephp's gear list:stephp's gear list
Pentax K20D Pentax K-5 IIs Pentax smc FA 50mm F1.4 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +8 more
MightyMike
Forum ProPosts: 31,651
Re: Astrophotography with GPS O-1 !
In reply to stephp, Sep 5, 2011
Wow, impressive
Mike from Canada
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
miles green
Senior MemberPosts: 4,293Gear list
Stunning!!! Very very cool shots...
I wish I could do that with my 200mm!!
Miles Green
Corfu
 miles green's gear list:miles green's gear list
Pentax K-5 Sigma 70-200mm F2.8 EX DG Macro HSM II Pentax smc DA 21mm F3.2 AL Limited Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +9 more
Bart Roskam
Regular MemberPosts: 460
That is very neat! With what program did you stack the pictures?
stephp
stephp OP
In reply to Bart Roskam, Sep 5, 2011
These images were stacked with DeepSkyStacker
baldeagle21b
Contributing MemberPosts: 868Gear list
Excellent work, well done!
 baldeagle21b's gear list:baldeagle21b's gear list
Pentax K20D Pentax K-5 Pentax K-01 Pentax Q7 Pentax K-3 +8 more
uliw
Regular MemberPosts: 261
Nice ones!
below a wide angle shot I just brought home from vaction. ISO 1600, f6.3, 241 sec exposure. I used the 10mm fisheye. Unfotunately, the lens is not very sharp. I also tried the 12-24mmm but than, the astrotracer can only correct for the stars in the center of the image.
cheers
Uli
ozdean
Forum ProPosts: 21,608Gear list
That looks good.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited +9 more
Colorado CJ
Regular MemberPosts: 484
Wow, that's great! I wish they would make this backward compatible with the Kx, I'd buy it in a heartbeat. I've been looking for a tracking setup for my Kx, but everything I've found is just too expensive.
I wonder if Pentax will ever make this backward compatible, or if it's possible.
I might need to upgrade to a K5 sooner rather than later.
blowfish23
Regular MemberPosts: 101
In reply to stephp, Sep 6, 2011
Wow, these are definitely the best pictures I've seen yet with the gps unit.
stephp
stephp OP
In reply to miles green, Sep 6, 2011
Of course you can !!
It's very easy. Thanks to Pentax
You just have to perform the precise calibration of the GPS unit.
Miles Green
Corfu
Ishpuini
Veteran MemberPosts: 6,088Gear list
Great results!
Could you provide details on how you shot them?
Questions I have:
  • are these cropped or not?
  • did you reposition your camera for each shot in a stack?
  • why did you use as many as 7 or 8 45s exposures? whereas you could have done it in fewer exposures (at 200mm exposures up to 110-300s are possible depending on the declination).
  • why did you decide on ISO1600?
  • did you focus at infinite? (focus is critical since wide open aperture giving small depth of field)
Tx! Wim
Belgium, GMT+1
 Ishpuini's gear list:Ishpuini's gear list
Pentax Q Pentax K-3 Pentax K-3 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM +16 more
stephp
stephp OP
In reply to Ishpuini, Sep 6, 2011
Ishpuini wrote:
Great results!
thanks
Questions I have:
yes for M31: from horizontal to vertical (roughly 1.5x magnification)
no crop for NGC7000
no, just perform precise calibration at sunset and put the camera on the tripod
In order to reduce the signal/noise ratio. Unfortunately, I was not able to get good results beyond 45s exposures.
2 reasons:
  • up to 1600 ISO no in-camera raw noise reduction
  • light pollution is still present even at 50km from the big city (@12800 the sensor was completely saturated)
Using the live-view function, indeed it's the most critical part of the process.
Tx! Wim
Belgium, GMT+1
Gmbal
Regular MemberPosts: 274
Impressive, I was hoping that this kind of results would be possible now,and apparently it is. Well done.
Ishpuini
Tx!! Great info.
Still not sure whether I should or should not get one... I love what it allows to do, but fear its use for travelling may not be ideal.
I mean, in order to get the coordinates onto my images, it needs to sit on the camera all the time, since putting it on and taking it off everytime I take the camera out of my bag or put it in again is something I won't keep up for three weeks or more. So in the end I will either have it on the camera in the bag too (space, risk of damage when bumping the bag while hiking), or not use it at all... What would you say?
The astrotracker function is secondary to me, even though it's fascinating of course.
Wim
stephp wrote:
Ishpuini wrote:
Great results!
thanks
Questions I have:
no crop for NGC7000
2 reasons:
Tx! Wim
Belgium, GMT+1
Belgium, GMT+1
Gmbal
Imagine that the light you caught started its voyage towards us some 2.5 million years ago and finally ended up inside your K5... That is some old light you got there.
Jarda_Houdek
Contributing MemberPosts: 811Gear list
Great! I can't wait to get my O-GPS1. The andromeda galaxy is superb!
Through a Pentax Limited prime things may appear sharper than they actually are...
http://www.pentaxphotogallery.com/jaroslavhoudek
 Jarda_Houdek's gear list:Jarda_Houdek's gear list
Pentax K10D Pentax K-5 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 10-17mm F3.5-4.5 ED (IF) Fisheye Pentax smc DA 50-200mm F4-5.6 ED +4 more
stephp
stephp OP
In reply to Jarda_Houdek, Sep 6, 2011
stephp
stephp OP
In reply to stephp, Sep 26, 2011
One more: Messier 33, the Triangle Galaxy
stack of 40 images @ 60sec - 1600ISO - DA*200/2.8 stopped down to f/4
so so sky conditions: haziness, high light pollution, object at 25-35° above skyline
mag. limit ~ 16.0
Gmbal
Amazing!
