ISO test of a $7000+ SD1
Started Aug 30, 2011 | Discussions
Spade357 Senior Member • Posts: 1,052
mike earussi Veteran Member • Posts: 5,729
Re: ISO test of a $7000+ SD1
Interesting, thanks for posting. For all its improvements the new Foveon chip is still too noisy to be used at high ISOs. Looks like it will remain a speciality tool for the forseeble future.
Kendall Helmstetter Gelner MOD Forum Pro • Posts: 19,374
Les JPEG
Um, yes, we already knew not to shoot high ISO in JPG files thanks.
I mean, did you bother even to look at the full size images below which plainly shows the 100% views are from JPG and not from a file develop by SPP?
The full-size ISO6400 they show is still noisy but not nearly as noisy as the crop they are showing.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
Not so
Actually, at this point finally the SD-1 is usable at what people generally consider higher ISO - 800 and 1600. Beyond that it does get noisier but is not unusable at 3200, 6400 would be OK for something to be used on the web or possibly a B&W print...
petr marek Regular Member • Posts: 178
Yep, price/performance and IQ ratio is not good...
But SD1 detail at low ISO is better, very gentle and sharp, even the image is overexposed. Also Nikon shows some moire. As for me, for large prints I would definitely choose SD1 shot in raw X3F. My best photos except those with stars in the night sky, are shot at low ISO.
Roland_d Regular Member • Posts: 256
Worth a serious look specially since you can compare colors/noise/details with other cameras - Sony a77, Nikon 7000 etc
Not sure that SD1 shines as gold !
thanks for the link
rd
Raist3d Forum Pro • Posts: 35,513
Not so hot noise...
how fast the Sigma crowd scream when anyone compares JPEGS of the SD1 (or any Sigma) to JPEG or RAW of Bayer, but sure they don't say beep when they are comparing Sigma RAWS to JPEG Bayers.
But that's besides the point. It sure has a lot of noise. For someone who told me before it didn't seem that far from a Pentax K-5 I can tell you, it's very far from what a K-5 can do. And they have the RAWS right there to download.
Still I see an improvement, at least resizing down to older Sigma Foveon class you can get something that is quite usable. But from what I see, ISO 1600 in B&W and ISO 3200 also in B&W. Not too far from where it was before when seen as a whole.
It wouldn't personally bother me much if I could do B&W on a DP2 with this sensor at ISO 3200 if they allow us to turn off SPP's noise reduction.
But I can say right now, the K-5 is way ahead of this at high ISO.
Raist3d/Ricardo (Photographer, software dev.)- "You are taking life too seriously if it bugs you in some way that a guy quotes himself in the .sig quote" - Ricardo
The Panda Contributing Member • Posts: 776
