Anybody used Lambency Flash diffuser with Canon 580EX II ?
Started Aug 17, 2011 | Discussions
mjoshi
Senior MemberPosts: 1,196Gear list
Aug 17, 2011
I'm in process of deciding which flash diffuser to get for my 580EX II. Found following on ebay -
http://shop.ebay.com/i.html?_nkw=580ex+diffuser&_frs=1&_trksid=p3286.c0.m359
Anyone used this particular diffuser ? or recommendation for anything better to go with 580EX II ?
M
 mjoshi's gear list:mjoshi's gear list
Canon EOS 6D Canon EF 70-200mm f/2.8L IS II USM Tamron SP 24-70mm F/2.8 Di VC USD
OOPSOS
Regular MemberPosts: 413Gear list
Re: Anybody used Lambency Flash diffuser with Canon 580EX II ?
In reply to mjoshi, Aug 17, 2011
I had one but rarely put in use. It is ok for indoor and subject is not to far. Easy to fall off from speedlight, you need to use wide rubber band to hold it in place. This is China product (copy of Gary Fong that make a lot pro and con debates). I make my own similar to demb flip it
'Photography is about feel of view, not field of view'
I view, I feel, I shoot
 OOPSOS's gear list:OOPSOS's gear list
Nikon D300 Nikon D800 Nikon Df Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +7 more
Port Royal Dad
Senior MemberPosts: 2,602
Lambency Flash diffuser? What a complete waste of money.
So much light is lost and wasted by sending light in all other directions including towards your subject.
A few things that will get you miles further....
  • Learning to bounce your flash. The 580exII's head can tilt and swivel
  • Look at those walls and ceilings and think.....big umbrella's
  • There's nothing wrong with direct flash, learn to see the existing light and let your direct flash act as highlights or as fill to push out shadows.
  • Or get a diffuser which projects all the light forward.
Here's a great little diffuser that will work awesome with your 580EX. Website is by a fella named Chuck Gardner.
http://super.nova.org/DPR/DIY01/
I made mine using a spray on adhesive vice stapling the edges.
Best Regards, Mike
M
B.R.A.S.S. (Breathe, Relax, Aim, Sight, Squeeze)
Zee Char
Veteran MemberPosts: 8,184
Re: Lambency Flash diffuser? What a complete waste of money.
In reply to Port Royal Dad, Aug 18, 2011
Some excellent advice here
Many new flash owners start to think about diffuser before they even know why
the head tilts and swivels.
+1
If I have to I shoot direct flash. Flash goes on a bracket and ISO goes up.
This diffuser took me about 45 minutes to make and cost about $5. The Demb flip it is a good tool.
Whatever you do don't get caught up in the quest for latest and greatest diffuser. Most are expensive gimmicks.
http://russellspixelpix.blogspot.com/2008/11/flash-diffusers-no-need-to-spend-big.html
Learn about light. Take a lighting course if you can. This is a very good book.
http://www.amazon.com/Light-Science-Introduction-Photographic-Lighting/dp/0240808193
Best Regards, Mike
M
mjoshi
Thanks for sharing - I know Chuck but did not look at his website - thanks for pointing me in right direction.
M
ShaunHill
New MemberPosts: 2
In reply to Zee Char, Apr 15, 2012
Please confirm how you made that cool tool! Materials used, template etc.
jjlad
Senior MemberPosts: 1,870Gear list
MIKE Re: Lambency Flash diffuser? What a complete waste of money.
In reply to Port Royal Dad, Apr 16, 2012
Same unit I made (4 of them) and they are amazing on camera or off. I still take umbrella softboxes on location if I do a test shot with these and if it does the job (and most often does), I leave the softboxes closed.
jj
http://www.flickr.com/photos/jjlad/sets/
 jjlad's gear list:jjlad's gear list
Fujifilm FinePix S100fs Nikon D7100
Paul Farace
Contributing MemberPosts: 679Gear list
Re: MIKE Re: Lambency Flash diffuser? What a complete waste of money.
In reply to jjlad, Apr 17, 2012
My Canon speedlight diffuser is the bottom 4 inches of an alcohol bottle... the Velcro loop panels on the flash hold it securely for most apps... can't beat the free aspect! And the bottle plastic is not as dense as these caps... therefore, more light efficiency!
Holding a camera, any camera, reduces my blood pressure, calms my nerves, and gives me a sense of opportunity!
 Paul Farace's gear list:Paul Farace's gear list
Fujifilm FinePix Real 3D W3 Fujifilm X100S Canon EOS 5D Mark II Canon EOS 50D Fujifilm X-Pro1 +3 more
Quantum Help
Senior MemberPosts: 1,666Gear list
For 1/5th of what the GF cost ---
In reply to Paul Farace, Apr 17, 2012
You can only lose $20.00 if you do not like it. Just remember, the GF cloud has to be used with low white ceilings, at a max of around 10 feet, f/4 at ISO 400. After that distance, you are hindered by light loss.
 Quantum Help's gear list:Quantum Help's gear list
Nikon D90 Nikon D1X Nikon D200 Nikon D300S Nikon AF-S Nikkor 300mm f/4D ED-IF +5 more
jjlad
In reply to Zee Char, Apr 18, 2012
Here's a 39 person group shot using only a DI 866 MkII on camera with the same diffuser as Mike has shown. That was a very dimly lit room too.
With a Stoffen, or those other units that blow light all over the place I wouldn't have got this shot at all and just using bounce off the cieling would have lost way too much light. I simply opened the diffuser up to spread the light while keeping the top and side lips curled slightly forward. The ones I make have a plastic mesh inside between the white and black layers so they can be very accurately shaped.
jj
