New NEX leses, f1.8 24mm, f1.8 50mm, f4.5-6.3 55-210mm
Started Aug 13, 2011 | Discussions
eddieaus
New MemberPosts: 18
Aug 13, 2011
These are the upcoming NEX lenses. You see them here first
eddieaus
New MemberPosts: 18
Re: New NEX leses, f1.8 24mm, f1.8 50mm, f4.5-6.3 55-210mm
In reply to eddieaus, Aug 13, 2011
links fixed
malextrolli
Contributing MemberPosts: 709
Wow (nt)
Wow
anaksatawo
Contributing MemberPosts: 657
would you happen to have some sample images? thank you for the lens pr0ns! can't wait for aug. 24!
Phatalbert
New MemberPosts: 17
Re: Wow (nt)
In reply to malextrolli, Aug 13, 2011
Wow! Thanks a lot for the previews! I haven't been following the chatter on these lenses. They are all due out on the 24th? Also, what is expected price of each?
anaksatawo
SRP information?
any info on the SRP too? this is too exciting. xD
D Cox
Forum ProPosts: 12,553
Re: Wow (nt)
In reply to Phatalbert, Aug 13, 2011
They will be officially announced on the 24th.
It is then likely to be a few weeks before you can buy one.
WT21
Veteran MemberPosts: 4,839Gear list
That long zoom is WAY too dark -- 4.5-6.3!!! I suppose it's to keep the size down, but wow. I'd like to see it compared (size-wise) to the Canon 55-250, which is 5.6 at the long end, and is a very light, compact lens with IS.
I refuse to wed myself to any of these vendors. I'm just having fun taking pictures,
and watching the technology develop.
 WT21's gear list:WT21's gear list
Sony RX100 Sony Alpha 7 Sony a6000 Sony FE 28mm F2 Sony FE 70-200 F4
franzel
Contributing MemberPosts: 797
In reply to WT21, Aug 13, 2011
Thanks for quoting the images, keeps my scroll wheel busy .
Hard to say right now, but I believe the Canon is quite a bit bigger, with a filter size of 58mm vs 49mm.
The Sony lens has IS, too, and is just 1/3 stop slower.
More importantly, where are those images from ?
Spade357
Senior MemberPosts: 1,052
Looks like the Zeiss is slightly shorter than the zoom kit. I'm glad they made the lens black to perfectly match the black NEX-7. I'm excited that finally the NEX is getting a high quality lens.
ianimal
Senior MemberPosts: 1,053
Yes this is what the NEX system need
This and a few more maybe. Maybe a better 16mm and a new 85mm with
some near macro properties (1:4 or better).
For me the 16mm looks ok (from image samples I have seen here and other places). But it has been so much talk about it so if possible maybe Sony could updated it. And of course a few more pancakes if possible would be nice.
I guess the 50mm will be nice for portrait shooting. Not so much DOF and
nice bokeh. The first true E-mount portrait lens... at last!
AdamT
Forum ProPosts: 58,216Gear list
Fabulous Stuff
Fabulous Stuff - just what NEX needs - being non-Pancakes, the 24 and 50 should be far less compromised - the tele-zoom is a bit slow (these things are usually F5.6 at the long end) but has their excellent OIS so not a disaster ..........
The KEY thing will be PRICE - they've really got to be in the same ballpark as the Nikon 35 F1.8, 50 F1.8 and 55-200VR - Hopefully they won't "Sony-out" on us and ask laughable prices like the 18-200 and keep to sensible prices like the budget SAM lenses for Alpha mount .
A Problem is only the pessimistic way of looking at a challenge
Canon PowerShot G1 X Nikon Coolpix P330 Panasonic Lumix DMC-GM5
AdamT
Re: Yes this is what the NEX system need
In reply to ianimal, Aug 13, 2011
an 18mm F2.5 would be the most likely (easier to make and a direct competitor to the Panny 14mm which M43 has), an 85 F1.8 would be superb .
PaulPI
New MemberPosts: 11Gear list
In reply to Spade357, Aug 13, 2011
Here i made a quick comparison. I think it should be quite correct so that everybody can see how big the lenses really are.
 PaulPI's gear list:PaulPI's gear list
Sony Alpha NEX-6 NEX5R Sony E 35mm F1.8 OSS Sony E 16mm F2.8 Pancake Sony E 50mm F1.8 OSS +1 more
Mark_McD
Senior MemberPosts: 1,759Gear list
In reply to AdamT, Aug 13, 2011
Erm, I think you forgot about sensor size. 18mm on an APS-C sensor is an EFL of 28mm. 20mm on an mFT sensor is 40mm. Not even close.
Also, the SEL18200 is comparable to other 18-200mm zoom prices, the Nikkor 18-200mm G ED VR II is the same price, Samsung's 18-200 ED (NX) is the same.
 Mark_McD's gear list:Mark_McD's gear list
Sony Alpha NEX-5 Sony Alpha 7 Sony DT 35mm F1.8 SAM Sony E 16mm F2.8 Pancake Sony E 18-55mm F3.5-5.6 OSS +6 more
AdamT
In reply to Mark_McD, Aug 13, 2011
Read again - I said Panny 14mm = 28mm
Got a point about the Nikon (which is now Vastly overpriced - the optically identical Mk1 debuted at £399 - the price Tamron's better variant is now)
Rinneh
Regular MemberPosts: 210
i think they are a bit tooooo large for the system. where are the pancakes.....i know because the shirt flange distance it is harder to make shorter lenses, but the 50mm prime still should be at least shorter than the kit zoom lens.
AdamT
In reply to Rinneh, Aug 13, 2011
they've probably used the optics from the Cheapo SAM 50mm which requires the deep flange distance to work and stuffed CD-AF friendly electronics in - just a guess, but it'd keep the price down and the optics are already there and pretty good
Amin Sabet
Veteran MemberPosts: 6,757Gear list
NEX Lens Size Comparison (Large Image)
 Amin Sabet's gear list:Amin Sabet's gear list
Fujifilm XF1 Olympus OM-D E-M5 Sony Alpha 7R II Panasonic Lumix G 14mm F2.5 ASPH Leica Summilux-M 35mm f/1.4 ASPH +10 more
Davidgilmour
Senior MemberPosts: 1,338Gear list
Re: SRP information?
In reply to anaksatawo, Aug 13, 2011
This is my guess
24mm $899
50mm $229
55-210 $499
 Davidgilmour's gear list:Davidgilmour's gear list
Fujifilm FinePix X100 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Sony RX1 Fujifilm X-A1 +1 more
