That's not bokeh
Started Aug 3, 2011 | Discussions
LincolnB
Senior MemberPosts: 3,659Gear list
That's not bokeh
Aug 3, 2011
It's heat rising off the field.
There was a flock of buzzards eating dead mice etc. from this field of freshly mowed hay. With a 400mm lens the distortions from the heat rising off the field was quite noticeable. it made it very difficult to get a sharp shot. Of course being buzzards they stayed in the areas with the most updraft! The very short depth of field at this focal length also proved challenging. All in all an interesting learning experience. I think a native 300mm autofocus M43 lens would have had a slighly better result than this $65 manual focus lens but it still would have been a challenge.
I applied a little bit of sharpening to the bird but nothing else in the shot. It's also slightly cropped.
 LincolnB's gear list:LincolnB's gear list
Olympus PEN E-P1 Panasonic Lumix DMC-G3 Fujifilm X-E1 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +4 more
LTZ470
Forum ProPosts: 10,356
Re: That's not bokeh
In reply to LincolnB, Aug 3, 2011
looks like it came out of a Sony with Max NR!
FlickR Photostream:
http://www.flickr.com/photos/46756347@N08/
WC Wood
Senior MemberPosts: 1,624
Re: That's not bokeh...or heat distortion
That distortion is weird, but it seems, first, that ground covered with grass or hay will not get hot enough to cause heat distortion like that. Second, the buzzard would show distorted also.
W.C.
http://www.flickr.com/photos/29320396@N05/show/
LincolnB
In reply to WC Wood, Aug 3, 2011
W.C.
The heat rising was obvious in the viewfinder. I could see it with the naked eye as well. The buzzard was sharpened a bit in that picture. Also, the buzzard is closer than the background so the distortion would not be as bad.
Here's a detail from another shot, this time straight out of the camera. Notice especially how the objects in the background like the fence and the bench appear bent and warped. That's heat rising.
LincolnB
Here's the same lens, different weather
Late afternoon in the spring looking nearly straight up vs. midday summer looking across a field
Sean Nelson
Veteran MemberPosts: 9,915
The buzzard is a lot closer than the background so there's a lot less disturbed air between it and the camera to cause refraction distortions.
Peter Gregg
Veteran MemberPosts: 4,704Gear list
Just a heads up. Bokeh is not the blurriness of the background. It is the roundness of specular points in the blurry background showing the lenses ability to create a smooth transitions or the quality of actual points of light.
A good example would be a very round point of light versus an octagonal shape of a point of light. The octagonal shape is showing you the blades of the lens making the called for f stop. That (usually) is why a lens with more blades makes a smoother transition giving you a better bokeh.
Peter
'Life is good - eternal life is better'
 Peter Gregg's gear list:Peter Gregg's gear list
Olympus E-M1
WC Wood
Re: Here's the same lens, different weather
I stand corrected. The weather was crazy hot for awhile, wasn't it....
W.C.
LincolnB
W.C.
It hadn't been hot here in the PNW until recently. Big temp differences yesterday. To the left of this field you could see snow in the mountains!
dotborg
Veteran MemberPosts: 7,373
In reply to Peter Gregg, Aug 3, 2011
I'm pretty sure that bokeh (boke) literally means "blur" in Japanese.
Peter
Doug Kerr
Forum ProPosts: 20,898
In reply to Peter Gregg, Aug 8, 2011
Hi, Peter,
Actually, bokeh refers to the nature of the blur figures produced from out-of-focus object features (including, but not limited to, point sources or specular objects). It does not just refer to that phenomenon when we think it is "nicely done". Bokeh does not refer to "the degree of roundness" of the blur figure.
Best regards,
Doug
Doug Kerr
In reply to dotborg, Aug 8, 2011
Hi, d,
Essentially so - perhaps "blurry" or "blurriness".
Best regards,
Doug
