Epson 3800 Stops Printing Halfway(or less)Through Image
Started Aug 3, 2011 | Discussions
Marshal
Marshal Senior Member • Posts: 1,900
As the title indicates, my 3800 has suddenly developed a problem where after the PC sends the document, sometimes just a Jpeg format Contact Sheet in PS CS5 to the printer, it gets maybe halfway(sometimes more, sometimes less), through the printing and it just abruptly stops and nothing else happens. I then have to Cancel the document printing & try again.
It prints text documents fine, but with anything photographic from + - 3MB up, it just quits about halfway through. This is with Windows 7 Premium, 64 bit, 4Gb of RAM & 3.2ghz quad core proc. I've tried rebooting & trying again, but same thing. This is with the USB 2 connection. I've also performed Disk Cleanup and did get rid of some old temp files, but the problem's still there.
Anyone have experience with this either with the 3800 or any other printer?
Charles2
Charles2 Veteran Member • Posts: 3,321
Try changing one step of the path at a time
Try changing one step of the path at a time. For example, save the image file out of Photoshop and use another program to send it to the printer. You can download the free program Fast Stone if you need another program.
Patchy
Patchy Forum Member • Posts: 63
Re: Epson 3800 Stops Printing Halfway(or less)Through Image
I had the same problem 2 weeks ago with my Epson 3800 printing from Mac Os X.
After printing half way the print procces stopped and I got a communication error message.
It was a long search to find the problem. Finally it was caused by the USB cable.
I have no idea why a USB cable that worked for many year starts to make problems without even touching it.
Give it a try.
Ingo
Robert Snow
Robert Snow Contributing Member • Posts: 831
Ditto to the above...
I have had problems such as yours, and changing out to a different USB cable fixed my problem. This was in the past and on different model Epson printers.
bob snow
pluton
pluton Senior Member • Posts: 2,754
And, just to pile on, I have solved similar problems between the OSX computer and the 3800 by eliminating a USB hub from the signal path.
-KB-
 pluton's gear list:pluton's gear list
Nikon D800E Nikon D800 Fujifilm X-E1 Fujifilm XF 23mm F1.4 R Fujifilm XF 14mm F2.8 R
Marshal
Marshal OP Senior Member • Posts: 1,900
OK, thanks. I'll try that.
Howard Moftich
Howard Moftich Veteran Member • Posts: 7,699
if you're techno savvy, setting up and using the Ethernet port on the 3800 will be a big win.
PaulBearer
PaulBearer Senior Member • Posts: 1,487
Try Operator Error, unless the USB cable is, in fact, the problem....
I'm not sure why a bad cable would cause the same problem over and over again, but perhaps there is a geeky technical answer.
I had the problem with my 3880 more than a year ago. I can't recall exactly what the problem was, but it related to image and canvas size and paper size. As I recall, it took me about 5 bad prints to figure it out, and i was using very large, expensive paper.
Cable changes are an easy troubleshooting step, but the next thought should be operator error.
Vernon D Rainwater
Vernon D Rainwater Forum Pro • Posts: 13,109
Re: Try Operator Error, unless the USB cable is, in fact, the problem....
Was your solution -- Cable, Correcting Operator Error, or what....
Vernon...
Marshal
How would it be operator error? I'm doing everything I'm supposed to be doing. By the book.
Marshal
Robert,
I changed USB cables and it was working fine last night so I thought that had solved it.
But I booted up and went to print some more today, and the problem recurred. So it's back to square one on troubleshooting. Anything else you know to do?
Robert Snow
Ah boy! It could be so many different things...
Here is a quote from a message in 2008:
"I suspect you have a buffer/RAM corruption.
Try rebooting the computer. > BUT
This may or may not be your problem. I would suggest that you check how much disk space is available for your Temp file. Also, how much ram do you have? Are you using a USB port on the computer? If not, try connecting directly to one of the computer ports. There is always a chance that uninstalling and re-installing your driver might cure the problem.
Do some searching on Google...they cache this site along with several others and might have some more suggestions. This has been an ongoing common problem over time.
Good luck, bob snow
Tom-C
Tom-C Senior Member • Posts: 1,148
Go to http://ddisoftware.com/tech/articles/40/ where Mike Chaney, the author of QImage has a series of articles.
In particular, look at the February and April 2006 articles.
The info in those two articles may help in your case.
Tom
 Tom-C's gear list:Tom-C's gear list
Canon EOS 5D Mark III
Marshal
Thanks Robert. I may try that the next time. It worked ok when I was printing more contact sheets last night. But another thing I did was go through the quick setup procedure in the Quick Start Guide. Particularly, disconnecting the printer, restarting both it comp & then reconnecting the new cord & in a different USB port.
Btw, the USB port is on the computer(the back)and I'm not using a hub for anything in case anyone asks. I've heard those cause problems which is 1 reason I've never used them. The other reason is I have 8 USB 2 ports in all, so never needed one.
Thanks again for the info.
Robert Snow
Glad to know you got the printer going good again! They can do beautiful work, but can be totally frustrating at times.
By the way, I checked Epson's USA site and could find no trouble shooting info on this particular boo boo.
Have fun...
bob snow
PaulBearer
Well, if it isn't the cable, and it isn't you, what is it....
When you can't find something, it's always in the last place you look. If I can't find my wallet, I look everywhere, including the places my wife is positive it isn't, since I've already looked all other places.
The other choices are that your software, drivers, or printer are screwed up. My experience is that something I've done accidentally, or some magic microwaves have changed a setting somewhere, turns out to be the problem when I've tried all the logical items.
I usually print through Photoshop, and although an expert I can attest to the fact that there seem to be dozens of settings that can affect printing. I cannot recall the cause when something very similar to what the original post described, but it did turn out to be operator error - as I pointed out above, it was, as I recall, in my case, some combination of paper/canvas size and image size.
Had I simply stopped at reading every tutorial on how to print an image, I'd have never found it. I knew something different was happening, I just didn't know what even though I'd gone "by the book" to make my prints.
The other option is to go through your computer and delete every reference to Epson, including trash, and install fresh drivers from the Epson website. Then, if that doesn't work, contact Epson. If that doesn't work, go back to operator error.
I'm just trying to help. Please don't shoot the messenger.
Marshal
Re: Well, if it isn't the cable, and it isn't you, what is it....
Don't worry, not shooting the messenger.
Syd_Epson
Syd_Epson Junior Member • Posts: 25
My name is Syd and I work for Epson America, Inc.
There may have been an update in your system that is causing this conflict with the printer software. One option to try is to remove and reinstall the printer software; there is a chance some type of corruption is within the software. Should you have another application besides Photoshop it would be a good idea to try this too. It is possible that something within Photoshop could be generating an issue.
Hope this helps,
Syd
Marshal
Thanks Syd. I'll do that if the problem resurfaces again.
dwa1
dwa1 Senior Member • Posts: 2,966
Looks like the same problem that tealeaf is having (4900)...
Just an fyi...
This problem seems to be happening with the 4900 too...
http://forums.dpreview.com/forums/read.asp?forum=1003&message=38986523
Although there were no posts from Epson on this thread, tealeaf (the op) states that she has been in contact with Epson support.
Wayne
