e-pl2 fl-300r external flash help
Started Jul 18, 2011 | Discussions
tomjones_85
tomjones_85 Junior Member • Posts: 28
Hi I'm new to m43,
I have an e-pl2 and got the fl300r today. It works in RC mode. However, when put on the hotshoe the camera doesnt seem to recognize it. Is there somewhere hidden in the menus to activate ttl-auto/manual modes with an attached flash, or is something else going on?
Mike
 tomjones_85's gear list:tomjones_85's gear list
Fujifilm X100T Olympus E-M1 Sony Alpha 7 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +8 more
Gregm61
Gregm61 Forum Pro • Posts: 14,472
Re: e-pl2 fl-300r external flash help
tomjones_85 wrote:
Hi I'm new to m43,
Did you turn the RC mode off on the camera?
You should not need to do anything to have the flash just work.
 Gregm61's gear list:Gregm61's gear list
Leica M9 Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus E-M1 Leica M (Typ 262) +21 more
tomjones_85
tomjones_85 OP Junior Member • Posts: 28
Yeah RC mode is off. I'm starting to fear that it's not compatible with the e-pl2 right off the bat. Sometimes being an early adopter is a risky thing.
LTZ470
LTZ470 Forum Pro • Posts: 11,926
Firmware?
FlickR Photostream:
http://www.flickr.com/photos/46756347@N08/
tomjones_85
When going to the firmware in the menu, there is only information for the body and lens. When i get home i will try to use olympus software to find firmware for it. I still can't find confirmation if it will work for e-pl2/e-pl1/e-p1/e-p2 online. But RC works so i'm confused.
Gregm61
That could not possibly be correct. I have not seen an FL300R yet to know what the control layout is, but I would think as long as RC mode has been turned off on both the flash and camera, and the flash is set to TTL Auto, it should just plug in and work. No way they would not make this unit backwards compatible.
Look at the cameras' flash control box in the super control panel. Is it set with either the lightening bolt or the word "auto" in that box?
:). Yes, indeed.
LTZ470
Well Tom we who have ordered the FL-300R would not consider calling you an early adopter...I am seriously thinking along the lines of "Guinea Pig" though...lol...
The more you figure out the less I have to learn! Thanks for this thread though as I have the E-PL2 as well and never even gave it any thought to not being compatible!
tomjones_85
in the super control panel, there is auto with the lightning bolt no matter if i have the fl300r in the hotshoe or not in aperture or shutter mode. in manual mode there is just the lightning bolt (fill in) . i select the box and there is no options for ttl-auto or manual. Haha i bet i'm missing something really simple. Anyone know the exact way how to get the other olympic flashes to work with auto-ttl? is it basic plug and play?
thearne3
thearne3 Regular Member • Posts: 155
The usual with a Fl-36R is to just attach flash, turn on flash, hit Mode switch until Auto TTL shows. Done. I have an E-P2, so no built-in flash. Otherwise should be the same.
Oh, and make sure flash is fully seated in the hotshoe!
Gregm61
Yes, the FL50R just plugs in and goes whether used on my E5 DSLR or Pen (E-PL1 and E-PL2). The flash has a mode button you have to set depending on whether you are shooting in TTL, non-TTL or manual flash. You then use the SCP to toggle between forced flash (lightening bolt only), auto flash or the other options such as first or second curtain slow sync, variable manual power, etc, etc.
tedolf
tedolf Forum Pro • Posts: 22,049
With the FL-36r.......
You have push the mode button on the back of the flash to set it to "TTL auto" mode otherwise the flash mode set on the flash overides the camera menu.
I would have to think the the flash control system is the same. Maybe not?
Tedolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +8 more
tomjones_85
There is no switch/button on the fl-300r unit to set flash mode.. there is just a switch for RC(channel a or channel b) and then there is a off position. The manual says set it to "off" and then set the flash mode of the camera. I don't really see where to set the flash mode in the camera. Only in the super control panel or by pressing the flash button on the camera. Both show the same thing. auto, fill-in options that the onboard flash have. But the FL300r doesn't flash if i pick force flash or anything. Maybe my hotshoe connectors are screwed up. Anyone see anything wrong i'm doing on the menu side of things?
Thanks a bunch
Mike
Gregm61
That all sounds kosher to me. With no flash mode on the flash unit itself, all you have are the options in the super control panel on the camera. Assuming the flash is seated all the way and you have RC mode turned off on the camera, the flash should be a plug and play affair.
tomjones_85
I starting to think something is a lemon. Either my e-pl2 hotshoe or the FL-300R. A user at mu-43.com ( http://www.mu-43.com/f45/b-h-has-fl-300r-stock-14153/ ) has it working on his e-p1. I thought that when you put on an external flash, the ISO becomes the minimum iso (iso=200) automatically like when you use the popup flash. That also doesn't happen when i use the fl-300r. grrrrr.. so annoying lol
javafool
javafool Regular Member • Posts: 385
Batteries?
I hate to ask, but are you sure the batteries are good?
E-520, 620 & E-30 DSLRs, E-PL2, Canon S95 & SD4000 P&S
 javafool's gear list:javafool's gear list
Sony Cyber-shot DSC-RX100 III Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS
tomjones_85
Re: Batteries?
I think the batteries are fine. Brand new and test flashes (it has a test flash button) and wireless RC both work.
tedolf
Are you absolutely sure.....
tomjones_85 wrote:
Hi I'm new to m43,
Mike
that RC flash control is turned off in the camera and on the flash?
Take the batterys out of the flash and put them back in. Maybe this will reset the flash?
tedolph
javafool
Get it working
I sure hope you get yours working soon. Mine has shipped from B&H, so I am looking up to you to have all the answers for me when mine arrives.
Good luck Tom.
E-520, 620 & E-30 DSLRs, E-PL2, PL-3 preordered, Canon S95 & SD4000 P&S
tomjones_85
Re: Are you absolutely sure.....
alright, time for some investigative work. I'm going to go to the nearest best buy and see if their e-pl2 responds to the flash unit. This is driving me nuts lol
Guy Parsons
Guy Parsons Forum Pro • Posts: 23,383
Official compatibility chart...
The official compatibility chart at http://www.olympus.co.jp/en/support/imsg/digicamera/compati/pen_flashes.cfm shows that all Pens works with the new flash but with E-PL1/2 the exception is "MANUAL flash mode cannot be used. "
Usually as a default TTL operation is normal. Just make sure the flash mode of the camera is TTL (= "AUTO"). It should work.
Regards........... Guy
Olympus PEN E-PL5 Olympus PEN E-P5 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Olympus 12-40mm F2.8 Panasonic Lumix DMC-LX3 +19 more
