AppData folder , huge size
Started Jul 16, 2011 | Discussions
Lazlo Senior Member • Posts: 1,812
I am running Window 7 64 bit.
My C drive is getting full slowly without installing any new program.
Seems like App Data folder just keeps on growing.
Have 22.3 gig in the Roaming subfolder and 28.4 gig in the Local subfolder.
Is there a way to trim this folders to free up some space on the drive ?
malch Forum Pro • Posts: 13,126
Re: AppData folder , huge size
Sure, you can trim it down but you'll have to be selective. Some can be deleted safely; other files will cause huge problems if removed.
Cache and temp folders can generally be safely emptied. Others may require considerably more discretion.
There are some tools which can help automate this process. Two that I trust are:
http://windows.microsoft.com/en-US/windows-vista/Delete-files-using-Disk-Cleanup
And:
http://www.piriform.com/CCLEANER
The first is actually part of Windows, and CCleaner is a widely used freeware program.
Personally, I prune mine a lot more aggressively using largely manual methods but you need to understand exactly what you're deleting.
Before you delete anything, you might want to play with SpaceSniffer:
http://www.uderzo.it/main_products/space_sniffer/
This program will help you understand which program(s) are eating up all of this space. Then you may choose to reconfigure those particular apps (e.g. reduce the amount of space allocated for cache) or even replace them if they're behaving really badly.
Edit: with 50GB is there I'm guessing that iTunes is responsible for a good chunk of those files. Sadly, there isn't anything you can (easily) do about the iTunes data.
Lazlo OP Senior Member • Posts: 1,812
Thank you so much for your reply.
I will check out those programs
Zone8 Forum Pro • Posts: 16,527
Warning!
Be aware that such utilities as ccleaner can cause their own havoc! You would be surprised if you knew what they can delete! Same for many Registry Cleaners!
Make a Restore Point before using - I know from past experience (I service local clients' computers) if you do not take that precaution, you will most likely regret using such as ccleaner. You must have the ability to step back or you could well regret what it does. Some report OK to use but my own experience (and many others) totally differs. I would not recommend its use.
Zone8
3 Quotes by Ansel Adams:
"A photograph is usually looked at - seldom looked into." "A good photograph is knowing where to stand." "Sometimes I do get to places just when God's ready to have somebody click the shutter."
LINK: For B+W with Epson 1400 (and other models) using black ink only PLUS other useful tips:
http://www.photosnowdonia.co.uk/ZPS/epson1400-B&W.htm
Re: Warning!
Thank you so much. I will proceed with caution
Lazlo
http://www.pictures-by-lazlo.com/
http://www.pbase.com/sigmadslr/lazlo
Eric Carlson
Eric Carlson Veteran Member • Posts: 6,474
Re: Warning!
If you are worried about CCleaner messing up your registry, then just don't use the registry clean feature: You can still use the file clean features, which sounds like what the original poster would be more interested in anyway. And the file clean feature is the main feature of CCleaner anyway.
 Eric Carlson's gear list:Eric Carlson's gear list
Olympus C-2100 UZ Panasonic Lumix DMC-SZ7 Panasonic Lumix DMC-FZ20 Canon EOS 500D Motorola Triumph +1 more
Re: Warning!
The "sky will fall" scare stuff is really rather silly.
Of course, I hope you have some kind of backups -- you need that regardless of any file and/or registry cleaner. And folks can always make a restore point if it makes them feel better (although it's really not necessary).
Personally, I've run CCleaner about once a week for two years with no restore points or other special measures. This on a 64-bit Windows 7 machine with many hundreds of applications and 2TB of data. My computer did not explode, burst into flames, or anything else. It just keeps on runnin'...
Frankly, most folks are at a greater risk from web surfin' or checking email than they are from CCleaner. What are they supposed to do? Make a restore point each time they read email or visit a web site...
For the record, I do not take a cavalier attitude with my system or data. I have backups up the wazzo, a UPS in part to protect against lightening strikes (also a greater risk than CCleaner), and more.
Any program you install or run can, in theory, mess up your registry. CCleaner is far better written and better behaved than most, IMO. Sames goes for the other Piriform programs.
Andreja Contributing Member • Posts: 740
As implied by the name, this is the per-user location where applications are meant to store data. The "local" branch also contains the VirtualStore - the location where "naughty" apps which try to modify "Program Files" contents have their writes silently redirected.
Odds are that you've got one or two apps doing a heck of a lot of writing, and that examining the relative size of the folders will show you which app is doing it. Afterwards, it's a question of whether or not the app(s) in question can be cajoled into changing its behaviour.
Oh, I'd also like to second the anti-ccleaner message. "Registry Cleaners" are snake oil for the uninformed. Don't fall into the trap of listening to such "advice".
Many are. However, CCleaner is primarily a file cleaner; history, temp, cache files and the like. Plus, optionally, cookies.
It does include a very non-aggressive registry cleaner but there's no need to use that especially if the goal is to prune the AppData folder.
I really don't care what folks run or don't run on their systems but CCleaner is definitely not snake oil. It's free, it works exactly as advertised, it's used regularly by many millions of users, and has 5 star ratings at many of the major review sites such as CNET, Freewarefiles, MajorGeeks, and more.
CCleaner is produced by Piriform and their other products (Recuva, Defraggler, and Speccy) are held in similarly high regard. I recommend all of them without reservation or hesitation.
And for the record, my only association with Piriform is as a satisfied and grateful user.
Thank you guys,
I have used the Disk Cleanup and it has freed up quite a bit of space.
But, I should really figure out which apps write so much data on the C drive
Lazlo
Try SpaceSniffer -- it will help you figure that out very quickly and easily and is free.
It's only a 1.5MB download -- just extract the ZIP and execute (no installation required).
In a minute or two you'll identify the guilty parties!
All "registry cleaners" are snake oil, by definition. The registry doesn't need "cleaning" - ever. It may also have useful adjuncts, but at its core an automated "cleaner" is always unnecessary for the skilled, and dangerous for others.
It's better to seek the cause of any given issue instead of trying to blow it away, shotgun style, with an app which fundamentally has no way of knowing which files/registry values/cookies/whatever are important in any given context.
OttawaTony New Member • Posts: 3
Actually, in iTunes you can go into Preferences/Devices and delete earlier (redundant) backups that might exist for each device.
 OttawaTony's gear list:OttawaTony's gear list
Sony Alpha NEX-7
digitalshooter
digitalshooter Forum Pro • Posts: 19,604
Tony, why? (nt)
Thanks,
Digitalshooter
PS: all posts are just my opinion!
 digitalshooter's gear list:digitalshooter's gear list
Sony Alpha DSLR-A700 Canon Pixma Pro9000 Mark II
Archer66 Senior Member • Posts: 2,929
Are you using Lightroom ?
If yes then it's probably LR that is using more space.
jlinear Regular Member • Posts: 174
Re: Warning!
Yes, indeed. CC caused havoc with my Thunderbird e-mail setup. To remedy it I had to go into CC's Application tab and turn off access to Thunderbird files. It remedied the situation.
AxelR Senior Member • Posts: 1,147
Re: Warning!
Use the system's built-in Disk Cleanup Utility and *nothing* *else*.
BrianPriceUK Contributing Member • Posts: 716
I use a free program called WinDirStat whichshows you eaxactly what size every folder and file on your disc is:
http://windirstat.info/
Once you know exactly where the extra Gbs are you can decide what to delete.
Brian
