Canon EF 28-105mm f4-5.6 USM
Started Jun 17, 2011 | Discussions
Simon_In_Reading
Simon_In_Reading Forum Member • Posts: 51
Hi, I'm a part-time mature student (29) shooting with a Canon 40D and am looking to invest in a lens that would enable me to do portraits and hopefully some decent shots at weddings. More so socially but potentially friends have asked if I would take their wedding photo's for them?
I've not got a huge budget but wondered what people's opinions would be on the following lenses both in terms of value for money and also to be used as above or maybe as a walk around lens?
Canon EF 28-105mm f4-5.6 USM - £70
Canon EF 28-105mm f/3.5-4.5 II USM - £170
Canon EF 28-135mm f/3.5-5.6 IS USM - £290
Or similarly you might be able to advise on an alternative lens?
Thank you for any help and advice
 Simon_In_Reading's gear list:Simon_In_Reading's gear list
Canon EOS 7D
RD24
RD24 Junior Member • Posts: 39
Re: Canon EF 28-105mm f4-5.6 USM
I own this lens & it is a fantastic walk around lens. Delivers very good IQ. Very little CA & vignetting, not noticeable most of the times(especially on crop sensor DSLR). However in low light condition the need to bump up the ISO arises or using of tripod since it does not have IS. The AF is very good & quiet & it also has FTM overide. It is a fairly quick lens. Adding a good CPL filter improves the IQ even further.
Don't own it, but have used a friends' on many occasiong & a very good lens too, especially since it has IS & a slight more FL but a tad slower (by 2/3 of a stop) on the longer side of FL.
Boris
Boris Veteran Member • Posts: 9,257
Bought the Canon EF 28-135mm f3.5-5.6 IS USM
I generally shoot with primes but I needed a zoom to cover events but did not want to spend $1000 (24-105IS) on a lens that I would rarely use. I ended up getting 28-135IS white box special from B&H for $400us. I'm quite happy with this zoom, quite sharp on my 1Dsmk2 at 135mm wide open even compared to my 135f2L! Build quality is pretty good and AF is accurate and the lens is close focusing and has IS.
Boris
 Boris's gear list:Boris's gear list
Sigma DP2 Merrill Ricoh GR Digital IV Ricoh GR Ricoh GR II Canon EOS 60D +40 more
Simon_In_Reading
Simon_In_Reading OP Forum Member • Posts: 51
28-105-135 comparison
Thanks mate... I'm guessing the Canon EF 28-105mm f4-5.6 USM is no good hence the price?
When you say one lens is slower... does this mean that I would need to shoot at a slower shutter speer or open the aperture up a little more to achieve a balanced exposure?
Sorry just getting to grips with a few terms...
Canon EOS 7D
Simon_In_Reading
Re: Bought the Canon EF 28-135mm f3.5-5.6 IS USM
Thanks Boris some great images - was i a film premiere or something?
I wondered, what does USM stand for?
Canon EOS 7D
Gearóid Ó Laoi, Garry Lee
Gearóid Ó Laoi, Garry Lee Veteran Member • Posts: 6,057
Ultrasonic motor
Níor bhris focal maith fiacail riamh (Irish Gaelic)
A good word never broke a tooth.
 Gearóid Ó Laoi, Garry Lee's gear list:Gearóid Ó Laoi, Garry Lee's gear list
Fujifilm X10 Canon PowerShot S90 Canon EOS-1Ds Mark III Canon EOS-1D Mark IV Sony Alpha NEX-7 +25 more
Boris
Hi Simon
No film premier, High School Prom pictures under terrible high noon light in a back yard.
Boris
http://public.fotki.com/borysd/
RD24
Re: 28-105-135 comparison
Slow as in; the max appeture for 28-105 II at 105mm is f/4.5 however in the case of 28-135, at 135 the apperture is f/5.6.
Thus in the case of the latter, the shutter time will be 2/3 stop slower, but since it has IS the slight decrease in shutter speed will not cause a problem.
I would recommend the 28-135mm due to IS & 20mm add. FL.
GregoryA
GregoryA Contributing Member • Posts: 518
The 28-105mm f4-5.6 is not a very good lens. Not even close to the two others you are considering.
 GregoryA's gear list:GregoryA's gear list
Canon EOS 7D
jitteringjr
jitteringjr Veteran Member • Posts: 3,298
I wouldn't consider either of those
I had one that came with my 7D kit and it could not keep up with either of my el-cheapo kit lenses (18-55IS and 55-250IS). It was much softer than those so I would not recommend it. Buy the 18-55IS and a speedlight instead.
I would look around for a good used copy of the Tamron 28-75/2.8 or Tamron 17-50/2.8 non VC so you at least have the 2.8 to help blur the background out for portraits.
 jitteringjr's gear list:jitteringjr's gear list
Canon EOS 7D Sigma 30mm F1.4 EX DC HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm f/4L IS USM +5 more
jitteringjr
You might want to send your 135L in for calibration if you feel that way.
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=116&Camera=453&Sample=0&FLI=6&API=1&LensComp=108&CameraComp=453&SampleComp=0&FLIComp=0&APIComp=4
Boris
Canon EF 28-135mm f3.5-5.6 IS USM wide open
100% crop
135f2L at f4...nothing wrong w/my 135L
100%crop
Pretty good sharpness for a reasonable priced zoom...of course the 135L is better in sharpness,contrast, color and background blur...for 2x the price plus sometimes you need a zoom.
Boris
MoreorLess
MoreorLess Senior Member • Posts: 3,805
Canon EF 28-105mm 3.5
I was using my dads old copy when I picked up a 550d a few months ago and personally I found it rather soft compaired to the 18-55 IS kit lens. That is a lens that had been gathering dust for the best part of a decade though so perhaps not a very representive sample.
Boris
Here is a review of the lenses you are interested in.
http://www.wlcastleman.com/equip/reviews/28_135zoom/index.htm
boris
Boris
photonius
photonius Veteran Member • Posts: 6,458
Re: Canon EF 28-105mm 3.5
I would concur, mostly old film day lenses.
and for groups indoor you may need wide-angle. 28mm is just normal on crop.
18-55 IS is a start, but you may need faster lens for DOF or available light.
also, wedding is not easy - be warned.
Life is short, time to zoom in ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
RS_RS
RS_RS Senior Member • Posts: 1,678
Don't confuse the EF 28~105/3.5~4.5USM (original or II) with any version of the EF 28~105/4~5.6.
The latter is a very low-end lens sold as part of a kit with late-model low-end film bodies, and has poor performance and build. Certainly not worth £70 (or, indeed, anything).
The 28~105/3.5~4.5USM was a respectable ring-USM lens first introduced as the kit lens with the EOS-5, if I remember correctly. It was silently improved by replacement of the original 5-blade diaphragm with a 7-blade diaphragm, and then cosmetically upgraded to the II version. It probably falls short of expectations for digital use, and does not offer a particularly useful focal length range on a crop-factor body. I doubt if it is still available new, and you should not pay much for it s/h.
The 28~135 is, I believe, still in production, has IS, and is optically better than the 28~105 although a little slower at the same focal lengths. Canon have sold it as a kit lens with some digital 1.6-factor bodies, although it is not particularly suitable as a general-purpose 1.6-factor lens because it has no WA end. You could use it for portraiture to complement, say, an 18~55, nut there are probably much better ways of spenfing that much money.
KevinRA
KevinRA Regular Member • Posts: 229
Much better to get a modern zoom
These lenses are all old- and start at 28mm!
Much better quality and useability from a 18-55 IS, 17-85mm IS, 18-135mm IS. I owned a 24-85mm 3.5-4.5 (similar era to the others and reviews generally bit better) OK but - the modern even cheapo zooms are much better. (Replaced with 24-105 L and 18-55 IS).
Buy used - for example somewhere like mpbphotographic. Good stuff from them an warranty - from my 5D and 500mm f/4.- right down to the 18-55IS I picked up last week for casual shooting where I dont want to carry £££££££ around with me.
maarensv
maarensv Contributing Member • Posts: 671
Hi,
Forget the 28-105 f4-5.6 , not worth any money. The f3.5-4.5 version is a step up with it's better optics and ring type USM. But it lacks contrast wide open and also for good sharpness it needs to be stopped down. It is light and compact.
The 28-135 is the best of those three. A decent copy is usable wide open and stopped down it can be quite good. It has the plus of having an image stabilizer and a ring type USM. Never really liked the build quality of this lens, but it's not that bad either.
Some budget alternatives.
Canon EF-s 17-85 f4.0-5.6 , slow max aperture, not the best optics but not bad either, has IS and a ring type USM. Tamron 17-50 f2.8 (non-VC) , fast max aperture, slow focus, very good optics. Tamron 28-75 f2.8, fast max aperture, slow focus, very good optics, beware of bad copies.
Sandor.
 maarensv's gear list:maarensv's gear list
Sony RX100 Canon EOS 6D Canon EOS M3 Canon EOS 80D Canon EOS 70D +22 more
