Problems with SD cards
Started Jun 11, 2011 | Discussions
tombalev New Member • Posts: 4
Hi guys. I've tested 3 different types of SD cards, but each of them gives me a message "Memory card locked". Even after reformatting in computer problem was still here. First was Sandisk Ultra (Class 4), second Kingston Class 4, third Transcend Class 2.
Device is NEX-3 with firmware 3. Sony MSProDuo works fine.
Mark_McD Senior Member • Posts: 1,759
Re: Problems with SD cards
Have you checked the "lock" tab on the side of the SD card?
 Mark_McD's gear list:Mark_McD's gear list
Sony Alpha NEX-5 Sony Alpha 7 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony DT 35mm F1.8 SAM +6 more
BruPri Junior Member • Posts: 30
If it's happening on several different cards, it could be that the record interlock switch inside the camera that makes contact with the safety slider on the card, is jammed or bent. Have a look inside or return the camera for repair.
tombalev OP New Member • Posts: 4
Of course it wasn't by the lock switch, but BruPri - I don't know exactly what you mean, can you describe it more? I'm now outside of country, so I can't send it for repair :/
If one of your cards is working, I'm inclined to rule out a camera issue, but rather an SD card issue. Whether it's physically locked doesn't suggest the lock switch isn't broken. After time, they can seize. Try wiggling the lock switch back and forth a couple times (not aggressively) then let it sit at lock for a couple minutes, then push it back to unlock.
I believe you said all three of your cards exhibited the same issue, has any card worked in the camera?
The "safety switch" on the card doesn't electronically switch anything, but depending on it's position, either inhibits or allows the camera to write to the card or not. This is done by a feeler that is connected to a switch in the camera. If that feeler is jammed or the switch it's connected to is not working properly, no recordy.
Maybe I missed something, but I gather this is limited to 1 card working, 3 not.
" I've tested 3 different types of SD cards, but each of them gives me a message "Memory card locked". "
Knallberto Veteran Member • Posts: 5,478
Try SD cards ...
.. with another camera - then you will know where the problem!
Using brain is very simple, but seldom used ...
Re: Try SD cards ...
problem is in the camera, because all mentioned cards work in Canon EOS 500D without any problems. Maybe I could try it with different firmware, but now I'm on FW 3.0 and can't preform any firmware update... Can I downgrade it somehow to older one?
blue_skies
blue_skies Veteran Member • Posts: 9,456
Read this - most likely, your write-protection-sensor is bend:
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Sony DT 18-55mm F3.5-5.6 SAM +33 more
Thank you guys for this suggestion. I disassembled my NEX and check the card reader...well I thought that everything is fine with that, because I can see the difference between locked and unlocked SD card by change in that small hole on top of the card reader (see photos). Then after assembly, everything started to work fine. So now, I have functional NEX Thank you again.
JasonGood Junior Member • Posts: 46
Very brave - the thing would never work again if I did this.
