More for the peepers
Started Jun 11, 2011 | Discussions
Chunsum J Choi
Veteran MemberPosts: 8,431Gear list
Jun 11, 2011
 Chunsum J Choi's gear list:Chunsum J Choi's gear list
Sigma DP2 Merrill +1 more
Jaelkay
Senior MemberPosts: 2,243
Re: More for the peepers
In reply to Chunsum J Choi, Jun 11, 2011
As the full size image opened, I was struck by the amount of CA on the roof structure.
This is not good from such an expensive camera. It's not good from any modern camera.
AdamT
Forum ProPosts: 58,226Gear list
Yeah - LOL - the 17-50 is definately not up to the Job , a mess at F2.8 and F4 has as much CA as a Sony 828 ........ Shame Tamron don't make lenses in Sigma SA mount . Wow does this thing need an EOS mount version .
A Problem is only the pessimistic way of looking at a challenge
Canon PowerShot G1 X Nikon Coolpix P330 Panasonic Lumix DMC-GM5
stanislaw stitchanow
Senior MemberPosts: 1,956Gear list
So you believe
In reply to Jaelkay, Jun 11, 2011
CA is caused by the camera?
Well than I must admit you are a really expert with deepest knowledge of photography
I admire you
Jaelkay
Re: So you believe
In reply to stanislaw stitchanow, Jun 11, 2011
Partly. Yes.
There is no wideangle lens for the SD1
In reply to AdamT, Jun 11, 2011
maybe the new 12-24mm will do the job, but any SD1 pictures I saw with zoom lenses where depressing.
This camera shows the slightest decentering of a lens.
Even the new 70-200 was showing blurred corners.
So there are only the primes from 50mm Macro onwards and maybe the 120-300mm which will match the SD1.
But it is anyway to expensive to buy so it is ok for me
And there is no wideangle zoom on the Canon side either which will match the SD1.
Just the 14, 24, 35mm Primes will do the job, maybe.
AdamT
Re: There is no wideangle lens for the SD1
the 17-55IS EFS is a lot better at F2.8 than the Sigma 17-50 - the original Tamron 17-50 F2.8 is also and neither are CA monsters - the canon 10-22 has an excellent reputation . I'm not big on EFS canons (I have a 550D with a megazoom on that's all) I use Fullframe for work but there are quite a few decent lenses for crop sensors for it which stand up to pixelpeeping bayer 18Mp , things should be even sharper with 15Mp Foveon (that's how it worked comparing the SD cams to a bayer canon or nikon anyway - my 17-70 non OS performs better on the SD14 than I've ever seen one do on a D80, Sony Alpha or Pentax K10 anyway)
Jaelkay
Have you tried the Nikon 14-24? It's brilliant across the zoom and aperture range.
AdamT
yeah (on FF too) but its an odd lens on APS and there's no way an SD will ever be Nikon mount due to lever operated aperture more than anything - SA is basically the EOS mount electronically but with Pentax mount hardware
Roland Karlsson
Forum ProPosts: 23,478Gear list
Chunsum J Choi wrote:
this will be fun.
The building image is mighty sharp - but it has terrible CA. It also have areas with blown out highlights. But - except for the huge amount of detail - I cannot really draw any conclusions from this.
The macro shot at ISO 3200 is not good. But - I dont think anyone has promised it to be and I also assume we would be surprised most of us if it was the case.
Roland
support http://www.openraw.org/
(Sleeping - so the need to support it is even higher)
X3F tools : http://www.proxel.se/x3f.html
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited +8 more
Tiffles
Veteran MemberPosts: 4,966Gear list
 Tiffles's gear list:Tiffles's gear list
Sigma DP1 Sigma DP1 Merrill Kodak DCS Pro 14n Nikon D700 Sigma SD10 +6 more
D Cox
Forum ProPosts: 12,589
In reply to Roland Karlsson, Jun 11, 2011
this will be fun.
I think we can draw the conclusion that we now have cameras for which the lens is the limiting factor.
However, I have not yet seen an SD1 example with colour quality as good as in typical SD15 shots. They look muddy. This is probably a matter of SPP needing more work.
petr marek
Regular MemberPosts: 178Gear list
Thanks.
Clearly dissappointing, the resolution is the only thing left, the rest is far behind nowadays cameras quality.
I´m glad I´ll save the money. I wanted from Sigma just similar sensor as SD15 with improvement in ISO performance, but it looks like they screwed with large megapixel count tonal quality of previous sensor.
cinefeel
Contributing MemberPosts: 860
In reply to D Cox, Jun 11, 2011
This shot has too much noise reduction, all the detail is smeared here.
I want to see it with NR off, like the cat shot or fungus shot on outliner.jp.
Now THOSE have detail.
cinefeel
This shot has too much noise reduction, all the detail is smeared here. Also, the 17-50 sucks at 2.8, we all know that!
DaSigmaGuy
Forum ProPosts: 12,280Gear list
They did...Tamron Adaptall lenses with an M42 mount or PK mount adapter. I use several.
Wow does this thing need an EOS mount version.
No its just needs sharp prime lenses, not necessarily made by Sigma, instead of soft Sigma zooms.
A picture is emerging....It seems those tiny few that have bought an SD1 have opted for one of the kit options. Specifically, the SD1 + 17-50 EX kit option, and thats probably why the samples always look so soft and poor quality compared to samples from the SD14 and SD15. That and the highly intrusive built-in noise reduction in SPP 5, of course
 DaSigmaGuy's gear list:DaSigmaGuy's gear list
Fujifilm FinePix F660EXR Sigma SD10 Sigma SD14 +25 more
DaSigmaGuy
You missed the SD1 samples taken with the Sigma 8-16mm EX?
DaSigmaGuy
I've tried one, on a late Nikon DSLR, and I was'nt impressed. Lots of distortion for a zoom thats supposed to be rectalinear. The old Sigma 14mm f3.5 rectalinear prime has less distortion and in the centre of frame at least is noticably sharper. The Nikon has better contrast but thats about it. You can pick the Sigma up for peanuts...Cant say the same for the Nikon.
DaSigmaGuy
It CAN be Nikon mount, if you buy one of sigmacumlaudes Nikon mount swap kits.
However, your correct that its really only an option for manual focus, manual stop down Nikon lenses as later AF versions, with no manual aperture dial, would be stuck wide open all the time.
cinefeel
In reply to DaSigmaGuy, Jun 11, 2011
Leica mount is the way to go, clearly.
Look at this sample:
http://outliner.jp/Foveon/bbs43.cgi
(it's market as a test of full-auto on SPP5, which looks wrong to me)
However, I think it's a good sample despite the overuse of noise reduction.
Tweak the highlights and downscale 50%... looks SPANKINGLY sharp.
