2-8 stop Variable Neutral Density Filter 67mm
Started Jun 10, 2011 | Discussions
Shmuel
Regular MemberPosts: 436Gear list
Jun 10, 2011
Hi guys, I wonder if any of you have used this type of ND filter and can recommend a brand. It is important to know whether the one you have been using doesn't produce vignetting. I intend to use it mostly on my 16-85 VR lens.
Thank you.
Shmuel ( http://pbase.com/acumedico )
( http://acumedico.com )
raunak
Forum MemberPosts: 98Gear list
Re: 2-8 stop Variable Neutral Density Filter 67mm
In reply to Shmuel, Jun 10, 2011
I had seen one in Hong Kong. I think it was called Fader ND filter and it offered a range of 2-8 stops reduction in light. I didn't know anything about this brand so did not buy it. I believe they are copied from Light Craft Workshop's Fader ND design.
http://www.lightcraftworkshop.com/site/page1000.aspx
I think Singh Ray also makes Variable ND filters but they are among the more expensive ones.
 raunak's gear list:raunak's gear list
Nikon D90 Nikon D7100 Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Tokina AT-X Pro 11-16mm f/2.8 DX Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +3 more
cfh25
Senior MemberPosts: 1,068
In reply to raunak, Jun 10, 2011
Appears to depend on your type of photography - quote from the UK site:
"If your intended use for the Fader ND filter is predominantly wide angle photography at high densities, then in all honesty it is probably not for you. For this application, we would recommend using a fixed density ND filter, such as the Light Craft ND500MC."
http://www.lightcraftworkshop.co.uk/about.html
arynd
Regular MemberPosts: 110
Tiffen now offers a 2-8 variable ND filter in 77mm for around $190 at adorama. I have not tried it, but Bryan Petterson speaks very highly of it. I don't know if they make other sizes. Their 77mm version has a wider outer ring to minimize vignetting for wider angle lenses.
Shmuel
Shmuel OP
In reply to cfh25, Jun 10, 2011
Thanks. I know all this but this was not my question...
Shmuel
Shmuel OP
In reply to arynd, Jun 10, 2011
Yeah.. I checked them. They have a "Fader 67mm Mark II Variable Neutral Density Filter" I can't figure out what brand and if it has or not a vignetting issue.
dominikpl72
Regular MemberPosts: 191
Below You will find just my remark based on article published in trustworthy and credible newspaper, not my own experience !!!
I have read the tests of 2 such filters in our local Photography Newspaper.
They DO NOT RECOMMEND IT AT ALL.
1. Such filters cause heavy problems with correct exposure - unknown black areas appear on the picture.
2. At longer exposure time - moving objects are not eliminated on the picture.
3. Another problem - the two filters stacked together cause vignetting problems.
Their conclusion is: the technology of such filter - two polarizing filters is something that does not work anyway good as an replacement for a stronger or weaker ND filter.
greetings from Poland
Dominik
http://dominik.4me.pl
Bobby Handal
Veteran MemberPosts: 5,415Gear list
In reply to dominikpl72, Jun 10, 2011
The filter has gradation points : minimum to maximum, if you pass the maximum point indicated in the filter you will get banding. Just don't go pass the maximum point.
These filters work, and for me at least, is better than sandwiching two ND filters to make it darker. Yes depending on the lens you may get vignetting, but that is very easily corrected YOU CROP or you photoshop it , usually edges are easy to handle.
Meanwhile , I am enjoying my cheap ND vario filter.
 Bobby Handal's gear list:Bobby Handal's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-TS3 Sony Cyber-shot DSC-HX400V Ricoh WG-M1 Nikon Coolpix P900 +55 more
jfk
jfk
Senior MemberPosts: 2,966
It's been awhile since I've used my Fader ND, but I don't believe there was an issue on my 16-85, but I bought the 77mm unit that has the 82mm outer ring. Come to think of it, I don't think it had any issues with my 12-24 either. Check to see if the 67mm unit has the 72mm outer ring. Unit isn't a whole lot thicker than a standard circular polarizer.
jfk
Caline de binne
Regular MemberPosts: 200Gear list
In reply to Bobby Handal, Jun 12, 2011
Bobby those are great shots!
At what speed were the two top waterfall takin?
I just received mine this week.
Fader 2.
Can't wait to try it at the waterfalls.
Bobby Handal
In reply to Caline de binne, Jun 12, 2011
I think that I shot those like 20 sec.
I need to play with mine more, I have seen awesome BW photos done with nd.
Best regards
http://www.photoexpedition.net
keano12
Regular MemberPosts: 355
In reply to Bobby Handal, 10 months ago
What is the best way to use this? Put the filter on and then adjust you aperture you seek for shallow DoF.
So if I am at F2.8 on the camera but my 2-8 ND is at 5. I need to shoot my flash at F16 or F5? IT's whole stops right?
Also is the an attachment of my Tiffen to use on 67mm lens/
