Hoodman - with 3x adapter - WOW !! Solves EVF wishes?
Started Jun 9, 2011 | Discussions
blue_skies
Veteran MemberPosts: 9,413Gear list
Jun 9, 2011
Like most (all?) of you, I am eagerly awaiting the focus peaking as a means to make manual focusing a snap - even in bright sunlight.
But I did order the hoodman with the 3x adapter, and like to report on the last few days just trying it out.
  • First, mounted on the LLC adapter (I cut slits in the hoodman, it already made a snug fit before applying superglue), it snaps onto the LCD and it hangs solid. In fact, it takes force to pull it off the LCD.
  • It makes the nex bulky, and the hoodman is heavy (the LCD doesn't like to be tilted anymore, the weight weighs it down).
  • But, the 3x magnification really blows me away - how to describe it? Imagine the LCD screen size increased to 9 inches across, right in front of your eye. I mean, even the basic font characters appear way too large.
  • The detail on the LCD is in fact so high that I can manual focus without the need for 7x or 14x magnification - confident and dead on.
  • It is not compact - it takes the place of a complete lens in my bag.
  • It comes with a cute little pouch, but it does not fit after you add the LLC adapter and the 3x eye piece
  • The 3x eye piece has a big flap, blocking all light around your eye. Works great, but the diopter lens fogs up when I press my eye in too far.
  • The hoodman blocks the ambient light sensor, but the LCD brightness appears to be 'perfect', day or night time.
  • in bright sunlight it works remarkably well - this is (by far) the biggest viewfinder (3x) that you can imagine.
Cost and bulk aside, for all of you that need/want/desire the EVF, this is something that I would recommend. However, it is not as compact as HOD's solution.
It really does blow me away.
Note - if you just get the hoodman, at 1x magnification, it is just a hood with a diopter. but with the 3x adapter it is just mindblowingly easy to work the LCD - there is so much detail in the LCD.
Can't upload any more pictures this month, will post pics later.
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Sony DT 18-55mm F3.5-5.6 SAM +33 more
jazzroy1972
Regular MemberPosts: 172
Re: Hoodman - with 3x adapter - WOW !! Solves EVF wishes?
In reply to blue_skies, Jun 9, 2011
nice to hear.
the hoodman is 3:2 aspect ratio, so how does it fit on the 16:9 screen? does it cut the border pixels?
anaksatawo
Contributing MemberPosts: 657
great info sir. how about a flickr link?
blue_skies
In reply to jazzroy1972, Jun 9, 2011
Barely, the hoodman goes almost edge to edge horizontally, vertically it is too high. That's why I cut horizontal slits inside the hoodman's plastic to fit the JJC adapter. It makes for a perfect vertical edge aligned fit (vertical edges line up, abutting at either side). The horizontal edges have a gap (I should put tape here I guess), but the NEX body covers them up. Vertically it is no taller than the NEX itself.
jazzroy1972 wrote:
nice to hear.
krisjtan
Forum MemberPosts: 83
In reply to anaksatawo, Jun 9, 2011
picture maybe??? thanks
blue_skies
In reply to krisjtan, Jun 12, 2011
Here you go:
  • After superglue,before electrical tape
- It fits snug enough to lift up camera + SEL18200 (before electrical tape)
  • After electrical tape
blue_skies
Re: LLC adapter
In reply to blue_skies, Jun 13, 2011
The LLC adapter is a perfect fit, the Hoodman is slightly narrower, but it cuts by only a few pixels at the sides.
I used the frame of this adapter to mount the Hoodman on.
P.S. last time that I used this particular LLC adapter, the wind blew out the side piece - it just snapped off! (I ordered new ones).
GodSpeaks
Forum ProPosts: 11,393Gear list
Question...
Why do people buy a small camera, only to hang large items (big zoom lens, hoodman loupe) off of it? In the end, would not a DSLR prove to be a more effective tool?
I know... to each their own, but I just do not get the logic.
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
  • Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic Lumix DMC-FZ1000 Kodak DCS Pro SLR/n Sony Alpha DSLR-A850 Panasonic Lumix DMC-GX1 +43 more
John Bean (UK)
Forum ProPosts: 18,034
Re: Question...
In reply to GodSpeaks, Jun 13, 2011
I would agree if the attachment was permanent - but it's not.
You can add things to a NEX to give it a "viewfinder" when needed but you can't take things off a SLR to make it smaller when you need only the LCD.
John Bean [GMT+1 aka BST]
