It (literally) hurts!
Started May 29, 2011 | Discussions
jazzroy1972 Regular Member • Posts: 172
it happened..
after the obvious hour of anger and despair I changed my mind to find a solution.
it seems that the problem is only the glass protecting the LCD, so now I'm trying to find a online seller for spare parts, anyone has suggestions?
anaksatawo Contributing Member • Posts: 657
Re: It (literally) hurts!
i cringed at the sight of the LCD like that. how did it come to this?
loakie New Member • Posts: 6
jendrzych New Member • Posts: 12
jazzroy1972 OP Regular Member • Posts: 172
Thanks for the replies!
How it happened? The shoulder strap hooked a handle and the camera fell on the corner of a metal drawer
The links are really interesting!
I didn't know there was a thick layer covering the lcd glass.
I think I have to rip it to check if it's there the problem.
parallaxproblem Veteran Member • Posts: 5,334
The layer covering the lcd glass in the item is not thick - it is basically just an anti-glare film
The sad news is that your LCD itself is certainly damaged as the 'black' areas on the display prove. You have to decide if the camera is still useable with the LCD in this state. If not then the only source of spare parts is almost certainly Sony themselves
Sorry to be the bearer of bad tidings
 parallaxproblem's gear list:parallaxproblem's gear list
Sony Alpha DSLR-A900 NEX5R Sony a77 II
John Bean (UK) Forum Pro • Posts: 18,035
That's my number two reason for disliking neck straps. I've never used one since I damaged a camera back in the 1970s in exactly the same way, catching it on a door handle.
My number one reason is that having fallen while out walking (several times) I've never liked the thought of the neck strap catching something during the fall and becoming a noose. Cameras can be repaired or replaced...
John Bean [GMT+1 aka BST]
Alupang
Alupang Senior Member • Posts: 2,819
Whoa...never thought of that. Should have a 50lb circuit breaker or something...yikes.
Probably the top layer is not the problem, but the display is ok (all the led pixels work perfectly, the broken part is the glass on top of them)
the cranks on the glass look dark but that's just an effect of the diffractions.
anyway the link to the display shop is good, 50 $ to change it with an original one seem a good price (considering the 20$ of the top layer only - not original!).
I think I will order it and wait patiently, here in Italy products from china take more than a month to arrive!
npires
npires Senior Member • Posts: 1,545
In the mean time might be worth seeing how much Sony might charge to get it fixed and how long it'll take you. Always good to know.
 npires's gear list:npires's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-5 Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 70-200 F4 +3 more
GarageBoy Contributing Member • Posts: 919
That's why you NEVER let your camera strap dangle- wrap it around the camera
