how important light is for sharp photos
Started May 25, 2011 | Discussions
ocean76 Regular Member • Posts: 323
hi,
I thought "light" was the 1st rule for getting sharp photos...
I took that photo at a dim light and got surprised to see it was really sharp and noiseless although it was dark and had an apperture value of f 1.8.
exif:
time: 23:45
d7000
f 1.8
10 seconds
iso 100
matrix
lens: 35 mm
so it is possible to shoot vey sharp photos at no light at all...
I find it strange (it is just the opposite they taught me in the class) but nice....
tc333 Veteran Member • Posts: 3,928
Re: how important light is for sharp photos
ISO 100 and you are surprised it is noiseless. Just what did they teach you!
Tony
Tbolt47 Senior Member • Posts: 1,673
No
Light is the thing that gives you good photos - whether it's a lot of light or very little. There's no reason why a ISO100 long exposure shouldn't be sharp.
 Tbolt47's gear list:Tbolt47's gear list
Olympus XZ-2 iHS Olympus E-620 Nikon D7000 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +12 more
GeraldW Veteran Member • Posts: 6,948
Very impressive.
The benefits of a tripod, fast lens, shooting at base ISO, and an advanced camera.
Or, you could shoot at 1/3 second at ISO 3200, hand held, with image stabilization; and then live with the fuzzy edges and noise.
As the class says, good lighting helps a lot and eliminates the need for the fast lens and the tripod, and maybe even the advanced camera technology. Good light also eliminates the need to know that you need a fast lens and a tripod and the better camera.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon PowerShot A720 IS Canon PowerShot SD950 IS Canon PowerShot Pro1 Canon PowerShot S95 Canon PowerShot ELPH 330 HS +3 more
Cytokine Contributing Member • Posts: 661
ocean76 wrote:
hi,
There has to be some light otherwise just leave your lens cap on!!!
exif:
time: 23:45
d7000
f 1.8
10 seconds
iso 100
matrix
lens: 35 mm
On the contrary there is allot of light, you just collected it over a long time.
Low ISO is your best friend if you can use it. Nice capture!
John
learnerguy Contributing Member • Posts: 683
My question is: what makes a photographer to decide on 10 seconds?
What are the "deciding" factors for shutter speed in "low light" or "poor light"?
How would the same photo look like if I were to keep the shutter open for 1 minute or 2 minutes? Too Overexposed?
ocean76 wrote:
 learnerguy's gear list:learnerguy's gear list
Canon PowerShot S95 Nikon D3100 +2 more
stuntmonkey
stuntmonkey Senior Member • Posts: 2,696
It is, you just haven't factored in 'time'.When you expose at 10s at f/1.8, you're going to let in a lot of light regardless. When they say you need 'light', they mean that you need to control the light that you have.
Also, f/1.8 is very unoptimal for the lens. Since you were shooting on a tripod, you could have made the same exposure at 30s and f/4 and would have achieved an even sharper image.
sic0048 Regular Member • Posts: 403
Well today's DSLR cameras can meter pretty well out to about 30 seconds. So it is likely that the camera's meter was used either in aperture priority mode, or as a baseline to get the exposure in manual mode.
This picture is exposed nearly perfectly IMHO and increasing the exposure from 10 seconds to 1 minute would increase the exposure by about 2.5 stops. If you didn't compensate for that increase by changing the ISO (can't in this case as it already is at ISO100) or aperture, then the picture would be overexposed.
binary_eye Veteran Member • Posts: 4,290
Except at f/4, the background would appear more sharp, making the wheel appear less sharp relative to the rest of the scene.
