What does the "G" mean after a lens name?
Started May 24, 2011 | Discussions
Frank
Regular MemberPosts: 352Gear list
May 24, 2011
Does it only mean its not AF?
 Frank's gear list:Frank's gear list
Nikon D600 Fujifilm X-E2 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Teleconverter TC-14E II Nikon AF-S Nikkor 24-120mm f/4G ED VR +5 more
Graystar
Veteran MemberPosts: 8,373
Re: What does the "G" mean after a lens name?
In reply to Frank, May 24, 2011
"G — Designation for lenses without an aperture ring, indicated after the f-number in the name. G lenses retain the mechanical diaphragm coupling of other Nikkors, but the aperture setting can only be controlled by the camera body. Only autofocus bodies with command dials are capable of controlling G lenses. Older autofocus bodies will work with G lenses in shutter priority and program modes with full opened aperture.[2][3] Some recent G lenses feature a weatherproofing gasket around the mounting flange. G lenses otherwise have the same characteristics as D lenses."
http://en.wikipedia.org/wiki/Nikon_lenses
mnodonnell
Contributing MemberPosts: 639
Gelded
They have no aperture ring. Aperture must be controlled from the camera.
http://www.flickr.com/photos/cheesenpickles/
Skywalker23
Senior MemberPosts: 1,164Gear list
Re: Gelded
In reply to mnodonnell, May 24, 2011
It means nothing if you're going to put the lens on a DSLR.
However, you cannot use the lens on older film SLR bodies because you will not have control over the aperture. I believe it will be constantly stuck at wide-open.
Visit my Flickr!!
http://www.flickr.com/photos/argonalex/
 Skywalker23's gear list:Skywalker23's gear list
Ricoh GR Nikon D610 Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 24-85mm F3.5-4.5G ED VR Tokina AT-X 17-35mm f/4 Pro FX
DaveOl
Senior MemberPosts: 2,857Gear list
Re: Gelded
In reply to Skywalker23, May 24, 2011
It means that Nikon ripped you off by selling you a lens that cannot be used on old MF bodies. Hopefully, Nikon will come to it's senses and go back to an aperture ring. How much can that possibly cost?
DaveO
 DaveOl's gear list:DaveOl's gear list
Nikon D300S
Frank
Frank OP
Re: Gelded
Thanks for the replies.
Graystar
Re: Gelded
In reply to DaveOl, May 24, 2011
Yeah...and Lexus ripped me off when they sold me a car that can't be hitched to a team of horses. The nerve!!
:rolleyes:
SNGX1327
Veteran MemberPosts: 5,186
Re: Gelded
In reply to Graystar, May 24, 2011
pontiac tried to rip me off by offering me an automatic transmission, but i ordered my car with a 6-speed manual. how much more can that extra clutch pedal really cost?
seriously though... considering that the average DX G lens retails for $200, any amount of savings is beneficial if you aren't planning on using a film camera.
combine that with the fact that, even if you are using a non-G lens, the aperture lens cannot be used on a digital camera. it's really just two differing formats. no conspiracy, nobody is trying to rip you off...
also consider this: 100% of canon's EF lens lineup is "G" type in that they do not have aperture rings. they are all 100% electronically controlled...
Chroko
Forum MemberPosts: 75Gear list
Re: Gelded
They would be slightly usable (albeit wide open) if that was the case.
But G lenses close all the way when mechanically activated and not communicating with an electronic body.
 Chroko's gear list:Chroko's gear list
Nikon D300S Nikon D3S
Aaron@Utah
Senior MemberPosts: 1,458
Your information is incorrect
In reply to SNGX1327, May 24, 2011
who told you aperure ring lenses can't be used on DSLR cameras?
"combine that with the fact that, even if you are using a non-G lens, the aperture lens cannot be used on a digital camera. it's really just two differing formats. no conspiracy, nobody is trying to rip you off..."
all of them can be used to some extent and some are fully functional as well
with AF and Metering
Nikon even still sells aperture ring lense's brand new
Mac OS X: Because making UNIX user friendly was easier than fixing Windows.
http://www.pimshots.com
toomanycanons
Forum ProPosts: 10,545
Re: Gelded
In reply to Frank, May 25, 2011
It stands for "good". I thought everyone knew that.
