X100 F4.0 sharper than F8.0?
Started May 22, 2011 | Discussions
whlcalifornia New Member • Posts: 18
Maybe it's my user error but I find F4 renders a sharper image than F8, which is a little counter-intuitive, unless F8 is the diffraction limit for X100.
Anyone else out there feel the same way about their X100?
millsart Senior Member • Posts: 2,771
Depends on the scene
Sometimes shooting with a shallower DOF gives an image more apparent sharpness than where more is in focus
I do believe f4 is the peak sharpness of the lens, but I've never found F8 lacking at all. Diffraction probably sets in pretty strong by F16 given sensor size
I wouldn't hesitate using F8 for landscapes etc though. I'd rather have the DOF that every last line/mm resolution at f4 and not have everythign I want in focus
http://www.millsartphotography.com
lnbolch
lnbolch Senior Member • Posts: 1,995
Re: Depends on the scene
If you would check out a bunch of lens tests—here or on Photozone.de—you will see that the sweet spot for most lenses in the f/1.8-2.0 range tends to be around f/4.0-5.6 and down just a tad by f/8.0. Your mileage may vary a bit from lens to lens.
 lnbolch's gear list:lnbolch's gear list
Fujifilm FinePix Real 3D W1 Fujifilm FinePix X100 Nikon D700 Fujifilm X-Pro1 Nikon AF-S Nikkor 14-24mm f/2.8G ED +8 more
whlcalifornia OP New Member • Posts: 18
Thank you, millsart and lnbolch. Your replies perfectly explained what I'm seeing in my X100. Its sweet spot is indeed F4~F5.6. F8 is only slightly worse but still very good.
rami Contributing Member • Posts: 743
Re: X100 F4.0 sharper than F8.0?
Also you should expect more motion blur at F8 as the shutter opens for longer
 rami's gear list:rami's gear list
Nikon Coolpix A Canon EOS 5D Epson R-D1 Leica M8.2 Sony Alpha NEX-5N +15 more
