Sigma 28-200 f/3.5-5.6 Aspherical Lens for Canon SLR Cameras
Started May 2, 2011 | Discussions
llc7 New Member • Posts: 5
Hello,
my sister had an old Canon EOS Rebel G camera with Sigma 28-200mm Aspherical IF f/3.5-5.6 len
i recently bought Canon EOS Rebel T3i
does this len can work with my camera?
does anybody know?
thank you
Kreitmann Contributing Member • Posts: 650
Re: Sigma 28-200 f/3.5-5.6 Aspherical Lens for Canon SLR Cameras
It depends on the age of the lens and a little luck. Many old Sigma lenses don't work. Even it is working, it is not a good lens, you will be way better of with a EF-S 18-55 IS or 18-135 IS. Old and cheap zoom lenses are no match for your camera.
 Kreitmann's gear list:Kreitmann's gear list
Canon EOS 80D Canon EOS 5D Mark IV Canon EF 300mm f/4.0L IS USM Canon TS-E 45mm f/2.8 Canon EF 100mm F2.8L Macro IS USM +9 more
OP llc7 New Member • Posts: 5
thank you so much for replying
the lens 18-55 came with the camera
can you recommend a good canon len that is good just like the old sigma 28-200 or perhaps anything else?
Karl Gnter Wnsch Forum Pro • Posts: 11,408
Any lens today is way better than that piece of junk...
If you want something good then the combination of EF-S 18-55 f/3.5-5.6 IS and EF-S 55-250 f/4-5.6 IS would be my recommendation!
regards
Karl Günter Wünsch
 Karl Gnter Wnsch's gear list:Karl Gnter Wnsch's gear list
Canon EOS 7D Mark II
Peter A. Stavrakoglou Veteran Member • Posts: 8,200
If you are looking for something with a wide range like that older Sigma lens, check the Sigma 18-250mm DC OS HSM lens. My experience with this lens is that for a superzoom, it's very good. Any lens with a range like this is a compromise in image quality and, generally speaking, you'll get better image quality out of two or more lenses that cover that range. What lens or lenses are best for you matters on what you want to shoot.
My humble photo gallery: http://www.pete-the-greek.com
 Peter A. Stavrakoglou's gear list:Peter A. Stavrakoglou's gear list
Fujifilm X-S1 Sigma SD1 Merrill Canon EOS R Sigma 10-20mm F4-5.6 EX DC HSM Sigma 70-200mm F2.8 EX DG Macro HSM II +18 more
Dan999 New Member • Posts: 24
this lens works in my 5D2, but only manual focus is possble.
Dan999
Tinu_ch Contributing Member • Posts: 660
It depends if the lens is 2005 or younger, then it probably works. If it is older it may work as long as you shoot it wide open (only possible with the camera set to Av or M).
Tinu
If the text above reads like real English, it must be a quotation
Some of my pictures: http://www.pbase.com/tinu
 Tinu_ch's gear list:Tinu_ch's gear list
Sony RX100 Canon EOS 5D Mark II Canon EOS 7D Canon EOS-1D Mark IV Canon EF 500mm f/4.0L IS USM +7 more
