Zeiss 2.8/35mm C + 2.8/25mm ZM Shots
Started Apr 20, 2011 | Discussions
Alupang
Alupang Senior Member • Posts: 2,819
Straight jpegs from the Nex-3--no PP, cropping or cornerfixing (or extra sharpening) just resized with Irfanview. I don't see any issues with this lens. The first 2 shots are with the 2.8/35 ZM C Biogon. The last 3 are with the 25mm ZM. Really enjoying my new toy--ultimate waist level finder camera.
heynowtest Regular Member • Posts: 399
Re: Zeiss 2.8/35mm C + 2.8/25mm ZM Shots
great lenses - should get a leica m film body next
Alupang
Alupang OP Senior Member • Posts: 2,819
Yes that is the plan. If I could get a new M 8.2 under $2000 I might bite. M9 still needs to depreciate to well under $3000 before I could rationalize buying one. I don't buy electronic toys that depreciate that much so quickly.
On the other hand, these Zeiss lenses may even appreciate in value..if I keep them in mint condition.
Leica needs to ditch the silly LCD screen and make the M more simple and rugged--with 2-3 times the battery life. A good top deck black and white liquid crystal display like the original EOS-1 had is all the M needs. IMO.
jazzroy1972 Regular Member • Posts: 172
Leica M8.2 could be an unpleasant discovery, belive me.
The facts:
  • it's not full frame but APS-C, so same as NEX. (M9 is full frame).
  • Has a awful sensor (and I mean really awful, noise starts to be invasive at 400 ISO, 800 ISO is unusable except for B/W and small scale printing
  • Display is ridicuolus in size, resoultion and color.
You would end up in having a camera that takes photos much worse than your Nex and costing 4X.
M9 is FullFrame and has an improved sensor (not on par with Nex-5, but way better than M8.2).
What makes Leica photos unique are lenses, not the digital body.
If you really want it I suggest waiting to buy an M9, for what is worth (fullframe and rangefinder focusing).
My 2 cents
Alupang
The M 8.2 is 1.33 crop though...that's significantly better than Nex 1.5 crop. But the camera has issues...and like I said I might buy one only if I could get a brand new one for under $2000. I'm assuming Leica ironed out M8's realibility issues with the M8.2?...didn't the M8 have shutter problems too? I read about M8 users sending their cameras in for repairs...
But I agree... skip it all and wait patiently for the M9 to come down to earth. Perhaps Canon or Nikon will pull their heads out and deliver something that blows everything away...who knows.
Until then, I'm really enjoying the Nex-3 and Zeiss glass. I will sell my 16mm on eBay reducing the cost of the Nex body to about $320...cheap fun.
headofdestiny Veteran Member • Posts: 9,226
I'm not sure I'd call aps-h significantly better than aps-c.
Alupang
It's a bigger sensor correct? So it has less of a crop I believe. That would be better for me because I only shoot 17mm-50mm tops. I have no need for telephoto--if I can't walk up to something, I'm not interested in it.
I don't really shoot tele, either. The M8 is a slightly bigger sensor, but you have to weigh whether it makes THAT much of a difference in your field of view, because, performance wise, the NEX has a better sensor.
So, mounting a 35mm lens on an M8 gives you a nearly 47mm equivalent, versus a 52mm equivalent on NEX. Will that affect your shooting that much?
IMO, the only real reason you should consider an M8 or M8.2 is if you're just dying to use a rangefinder focusing system. Field of view and IQ wise, I'm not so sure if it's worth it (I've been having my own debate about this, as well.)
p.s. you'll also have to deal with using IR filters with the M8.
Alupang
Not so much with my (our) 35mm C, but with the 25mm, going from 37.5mm to 33.25mm is pretty significant to me. 28mm is my favorite focal length. 33 is getting there...38 is not.
Well yeah, that's the point...to be able to focus through clear glass @ eye level with an all metal Leica would be nice...
That said, waist level with the Nex is actually better suited for my use.
Perhaps the deal-breaker yes. So I'm waitiing for M9.
I hear ya. Wider angle is still tough on the NEX. Your ZM 25 looks good, but I've still seen purple shift in the corners in some scenes form others.
Do you have the Sony 16mm? If you crop to about 12MP, it gives you around a 28mm field of view, and it conveniently chops off the most extreme corners, which is the problem area with that lens.
Alupang
I have a ZM 25 landscape shot with bright edges--from what I see, I cannot detect (or want to see? lol) any purple shift or smearing. I was going to upload it for you, but dpreview is updating servers atm.
Yes I have the 16mm and it performs fine for me @ f5.6-f11. I am considering selling it though, mainly because it has no distance scale. Shooting at f8 @ ISO200 usually means long exposures with 2 sec self timer. I need a distance scale for that. I feel like I'm shooting blind in the dark with the 16mm; I need to see exactly what distance the lens is set.
Alupang
I want to add that the 16mm lacking a distance scale is one of the reasons I've been out of photography for over a decade. Cheap autofocusing lenses with crude sloppy plastic focusing rings feels like I'm screwing on a cap on a peanutbutter jar...even with a Canon L.
The Zeiss ZM feels like I'm dialing in a precise metal microscope. I like that.
millsart Senior Member • Posts: 2,771
Your distance scale it actually acurate at 25mm ??
I had the ZM25mm as well (though bought mine when I had a M9, where its an awesome lens) though I do think it works pretty well on the NEX, by far the best in its range and way better than the Voightlander 25mm etc
One thing I found though was that regardless of the adapter used, the distance scale was always way off, and as a whole, the wider the lens, the more the distance scales are off.
As such, I found it pretty impossible to focus accurately using the distance scale and always had to confirm the focus using the LCD zoomed in.
Actually I always use the LCD with every focal length as even infinity isn't infinity with most glass/adapters. Sometimes DOF covers it, but I don't want to shoot hyperfocally, as its not exacting enough for larger prints, I want to see right where the point of focus falls and the LCD is great for that.
Alupang
Re: Your distance scale it actually acurate at 25mm ??
You can shim your adapter or just do what I do. I spent about 10mins doing 2 tests and noting exactly where 3ft and infinity really are on the lens' scale. Now that I know the overall behavior of my lens+adapter, I can easily determine any distance. For example, a hair to the left of the infinity symbol is exactly infinity on both lenses I own. I need to know in feet where the lens is set. I also require having a distance scale + DOF markings for landscapes.
maxuci Contributing Member • Posts: 728
More please?
Thanks for the pics. I'm really considering the 35/2.8, so I would appreciate any additional pics you could post. Goes for you too headofdestiny (and anyone else with the lens and NEX combo) Thanks a lot
go film!
at least get an m3 or a zeiss ikon
ZoranC Veteran Member • Posts: 5,569
ZM 25 does have color shift, trust me.
Alupang
Yep I trust you. It's just not yet showing up in my 1st day of shooting about 30 snaps. Here is a light edge jpeg I took yesterday..no cropping or PP of course; just resized.
Tough to see in that shot, because the sky is overexposed.
Alupang
So an overexposed sky won't show the purple shift hmmm. Learned something here. Next time I go out I'll properly expose a white wall or something.
