Is there a difference between a SDHC Class10 card and a SDHC UHS-1 class10 card?
Started Apr 8, 2011 | Discussions
Bo Regular Member • Posts: 170
A different question with the same premise as in another thread...
I need to get a Class10 card for my D7000. That is because I shoot a lot of sports and my class 6 cards start choking after 15 or so high speed shots at full size jpg. I wouldn't even dream of trying it in raw.
Amazon shows the Sandisk Extreme 8gig SDHC Class10 for $43. Then I happened to be at Best Buy last night and saw that they had a Sandisk Extreme 8gig SDHC HD Video Class10 that is also UHS-1.
They both say 30mb/s speed.
My understanding is that the UHS-1 rating means that even though it is a Class 10, it should be able to sustain faster write speed.
So is there a speed difference between those two cards? Does the UHS-1 rating on one of them mean anything if they both say 30mb/second? Will it make a difference is high speed shooting for sports?
Thanks very much.
Bo
Steve Bingham
Steve Bingham Forum Pro • Posts: 23,305
A simplistic answer
In spite of advertisements and standards, ALL class 10s are NOT the same. I trust SanDisk. BOTH would be plenty fast!
Steve Bingham
http://www.dustylens.com
http://www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D810 Nikon D5500 Nikon D7200 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF Nikkor 85mm f/1.8D +27 more
sandy b
sandy b Veteran Member • Posts: 8,163
Re: Is there a difference between a SDHC Class10 card and a SDHC UHS-1 class10 card?
this one is rated @45 is even less.
SanDisk Extreme Pro 8GB Secure Digital High-Capacity (SDHC) UHS-1
I bought mine at b&h for $36 for an 8 gb, one for each slot.
The biggest advantage for the D7k is how fast the buffer clears, although you may get a few more shots even with settings maxed out.
 sandy b's gear list:sandy b's gear list
Nikon Coolpix A Nikon 1 J1 Nikon D7100 Nikon D750 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +9 more
madecov
madecov Veteran Member • Posts: 3,172
I purchased two of the 8G UHS-1 cards from Adorama at $36.00 ea.
These cards are the fastest available at the current time. The D7K buffer will clear faster and allow a few more shots before slowing down. The camera also does not slow as much as with class 10 cards.
Well worth the money.
In god we trust, all others are suspects
Licensed firearms dealer in Houston, Texas
 madecov's gear list:madecov's gear list
Nikon 1 V1 Nikon D610 Nikon D7200 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +15 more
amooz Regular Member • Posts: 320
A little more detailed
The SD Class X spec only specifies the minimum read/write speed of the card, not the actual speeds. That's why you have some Lexar Class 10 cards doing 10.4MB/s, some Kingston class 10 cards doing 20MB/s, and Sandisks doing 30+MB/s. The rating system only goes up to Class 10, which creates the aforementioned ambiguity as to just how fast the card is.
"In technology I'm placing all my trust"
http://www.AdamMooz.com/Photography
 amooz's gear list:amooz's gear list
Nikon D700 Nikon D7000 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +2 more
Bo OP Regular Member • Posts: 170
Thanks for the info everyone!
Great tip, Sandy. I hadn't even noticed that. Just order one of the Extreme Pro from Amazon. Thank you.
Bo
Cultured Woman
Cultured Woman Regular Member • Posts: 146
The memory buffer will clear out faster with UHS-1 speed class cards.
I have noticed no difference in test I ran with Class 6 or Class 10 cards.
UHS-1 cards work to clear out the buffer faster than class 6/10 cards.
But, more expensive, faster UHS-1 cards do not work any better than each other...
See test meathods and results at: http://glamourphotography.co/gear/nikon-d7000-memory-speed-tests-sdhc-memory-cards-including-sandisk-extreme-pro-uhs-speed-class-1-45mbsec-and-several-popular-class-10-sdhc-cards/
And,
http://glamourphotography.co/gear/uhs-speed-class-1-sdhc-memory-cards-tested-delkin-8gb-elite-633x-secure-digital-uhs-i-95-mbsec-vs-sandisk-extreme-pro-32gb-45mbsec/
Yucel
Glamour Photographer
 Cultured Woman's gear list:Cultured Woman's gear list
Canon EOS 5D Mark III Sony Alpha 7 II Canon EF 50mm f/1.4 USM Canon EF 16-35mm f/2.8L II USM Canon EF 100mm f/2.8 Macro USM +4 more
