CS 5 - Unable to see the controls in free transform
Started Mar 26, 2011 | Discussions
yduckie
Contributing MemberPosts: 893
Mar 26, 2011
... just recently upgraded to CS5 (late to the show as usual) and have run into an issue that I hope you can help me with. In earlier versions of Photoshop, I was able to import into a document a different image. Sometimes the imported image was bigger than the canvas size, so I would hit Control T to bring up the transform tool, and then resize the imported image. If I could not see the bounding box, I would make the image smaller on the workspace and then the bounding box would be visible.
In CS5, that little trick doesn't work. Does anyone know what I must do to be able to see the bounding box in CS5? I've tried clicking on "show transform controls" with the move tool enabled, but no joy there.
System: Windows XP CS 5 32 bit, version 12.0.3.
Thanks in advance for your insight.
Heather
Sam B
Veteran MemberPosts: 5,736Gear list
Re: CS 5 - Unable to see the controls in free transform
In reply to yduckie, Mar 26, 2011
Try checking your Preferences. Under the General tab check and see if Resize Image During Place is checked. If that still doesn't work, try hitting Ctrl+H once or twice after you hit Ctrl+T to transform. It may be that the bounding box is being hidden by the Show Extras command.
Heather
 Sam B's gear list:Sam B's gear list
Apple iPhone 6s Plus +1 more
yduckie
yduckie OP
In reply to Sam B, Mar 26, 2011
Thanks, Sam.
I tried your suggestions but nothing worked, so on a hunch, I changed the colour of the "pasteboard" to black. Now I can see the bounding box. It seems the lines delineating the bounding box are the same colour as the default pasteboard. Weird!
I can see a lot of pasteboard colour switching in my future, unless I can figure out a way to change the colour of the lines in the bounding box.
Thanks again for your prompt assistance.
Cheers.
Heather
http://www.pbase.com/yduckie
eagle_I
Senior MemberPosts: 2,670
In reply to yduckie, Mar 27, 2011
Heather - I'm not entirely clear on your problem, but I can relate to not being ale to see the free transform "box" and adjustment handles when I've added what is usually a new background layer that is larger than the image I'm working on. CS5 was new to me on how it locks multiple images to the top of the work area in a tab setup. I like my open images floating individually in the work area like in older PS versions. I think it's possible to disabled the tab feature, but I haven't opting instead to occasionally having to drag the pic down to get it free "floating" in the work area. Once the pic is free I shrink it's whole window then drag the corner of it to reveal the inner "matte." Right clicking in the matte area allows a change of color with the choice of grey, black, and custom. I usually use black and the transform "box" shows well it. Thought this might be helpful.
Mark
