GH2 vs Sony Alpha 55
Started Mar 24, 2011 | Discussions
Alexsfo Senior Member • Posts: 1,480
Can somebody explain to me how Panasonic GH2 can beat Sony A55. Both are very similar in size and weight. Sony is quite a bit cheaper, has best in class IBIS, much wider (4x times?) lens selection, much higher LCD resolution (2x), currently best sensor out of all DSLRs with usable images all the way up to ISO12800, built-in GPS, HDR and 3D panorama to name a few. What exactly does GH2 offer which is substantially superior to Sony’s to command a higher price tag?
E-PL2+20mm 1.7
 Alexsfo's gear list:Alexsfo's gear list
Sony RX100 Canon EOS 6D Canon EF 85mm f/1.8 USM Canon EF 135mm f/2.0L USM Canon EF 70-300mm f/4-5.6 IS USM +2 more
jimboyvr Senior Member • Posts: 1,273
Re: GH2 vs Sony Alpha 55
please not this thread again.
Kikl Contributing Member • Posts: 986
E-PL2+20mm 1.7
These are DPreviews reasons for rating the GH2 higher than the A55:
mpgxsvcd Veteran Member • Posts: 8,092
Video Quality was enough for me.
E-PL2+20mm 1.7
 mpgxsvcd's gear list:mpgxsvcd's gear list
Panasonic Lumix DMC-LX100 Panasonic Lumix DMC-GF1 Olympus PEN E-PM2 Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GH4 +4 more
normsmith Veteran Member • Posts: 3,372
Decide your TOTAL setup i.e. GH2 plus what lenses plus what accessories, against A55 with what lenses and what accessories and THEN compare which meets your needs the most (weight, cost, shooting speeds, movie, image quality blah blah blah).
Alexsfo OP Senior Member • Posts: 1,480
I agree if you buy GH2 for video but how about those who are interested in photo only?
E-PL2+20mm 1.7
E-PL2+20mm 1.7
Jogger
Jogger Veteran Member • Posts: 8,441
video (nt)
E-PL2+20mm 1.7
 Jogger's gear list:Jogger's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 Nikon D700 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +4 more
CDMc Contributing Member • Posts: 523
Why buy an A55? why not a D7000 or K5?
Carl
http://www.cdmc.smugmug.com
 CDMc's gear list:CDMc's gear list
Panasonic Lumix DMC-LX3 Panasonic Lumix DMC-TS1 Canon EOS 40D Panasonic Lumix DMC-GH2 Panasonic Lumix G 20mm F1.7 ASPH +5 more
If you don't shoot video at all then the GH2 does not make economical sense. Remember, as much as some people don't like it the dpreview ratings are based on still and video performance and not just still performance like they used to be.
The GH2 is close to the DSLRs for still performance but not quite as good as the D7000. What makes it get rated as high as some other DSLRs is the fact that it also shoots the best video on the planet. Stills cameras are also expected to shoot video now whether you use it or not.
E-PL2+20mm 1.7
Adventsam Veteran Member • Posts: 4,983
Well actually the GH2 makes a lot of sense, what else has a walkaround 100-300mm lense that with body weighs in at less than 1kg? at the other extreme, a body and lense with f1.7 that almost pocketable and a perfect 35mm focal length. As a stills camera unless these people are blind its a powerhouse. In my quick tests over a week the a55 was poor in all respects, especially detail and I found the raw files very poor. As a stills machine it missed focus a lot, you couldnt shoot in af and on turning of the mf ring tweak focus, at 10x auto maginfier. There are no iso intermediates that I found, the evf is crude on an evening, noisey, there are no custom buttons of functions settings, bracketing is basic, I could go on, its a low end featured dslr, it was awkward to hold and output was continually soft.
Video aside GH2 is function and feature rich and with LR3.4 awesome in detail and DR.
E-PL2+20mm 1.7
Just Having Fun Veteran Member • Posts: 3,869
Not really true the A55 is much thicker/deeper. Many of the GH2 lenses are much smaller.
A little cheaper. GH2 body only is $675 on Panasonic's facebook site. The 14-140 kit lens is what is expensive.
GH2 has no IBIS so a clear win for A55
AF lenses only. Minolta MD, Canon FD, etc all work on the GH2.
But the GH2 EVF is better
True, but the mirror blocks 1/3rd the light. I compared both up to ISO3200 and there is no difference. From ISO6400 and up the A55 wins (I think DPR confirmed)
Is that what you buy a camera for? If so buy the A55. I do the panos and HDR via software (even my A55 images).
Well, again, it is really not much more expensive anymore. You can't get video lenses for the Sony (like the quiet, stepless aperture 14-140mm lens). The video is much better on the GH2, and for some reason DPR likes the RAW files from the GH2 better.
Now, all that being said, I tried both and went with the A55. I did not like the GH2 jpegs (lots of green and yellow faces), and my wife thought the A55 was 5x easier to use.
I sold the GH2 for $200 more than I bought it for and got an E-PL2 (with IBIS) as my carry-around camera.
HankK
HankK Regular Member • Posts: 389
GH2 vs Sony Alpha 55 -- Had both returned A55
I am a still shooter. I had the A55 for a time and found that to get decent quality lenses you are back to getting full size DSLR lenses so you are back to big size kit and heavy. I have a Canon 5D2 and did not want another DSLR kit.
The GH2 is just so much better size and weight wise. I also found the GH2 with the proper choice of lenses yielded better quality photos for me. I do not shoot above 1600 and mostly at 160 to 400.
I also had an overheat problem shooting stills with A55.
The GH2 just turned out to be a better overall kit for me, one that I have with me at all times.
Hank K
Panasonic GH2, G1, Canon 5D2, L and Zeiss lenses
petr marek Regular Member • Posts: 178
Before I´ve bought GH2 I´ve tried A55 for a short time. It was a really short time, because I was very dissapointed with its performance while shooting video. No control at all, noisy and chaotic autofocus while filming, terrible kit lens quality, small viewfinder. Now I´m very happy everyday user of GH2. Try both for comparsion, there´s much more key differencies... Also with GH2 you can use ANY lens via adapter and it´s a camera wihout compromises.
SHood Veteran Member • Posts: 4,559
Re: GH2 vs Sony Alpha 55 -- Had both returned A55
This is a general problem with APS-C cameras. There is a limited selection of quality APS-C lenses expecially at the long end. There is a large difference in weight and size between m43 and FF lenses.
 SHood's gear list:SHood's gear list
Sony RX100 Panasonic Lumix DMC-GH3 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
PerL Forum Pro • Posts: 13,366
deleted (nt)
E-PL2+20mm 1.7
zxaar Veteran Member • Posts: 3,924
Yaa agree with you, this is general problem with APSC cameras. For example take canon APC cameras, they hardly have any lenses for them when compared to m43.
Nikon also has same problem, to make things worse, these two are market leaders and so clearly these fools who are buying these APSC cameras are restricted to 1 or 2 kits lenses.
::> I make spelling mistakes. May Dog forgive me for this.
MrTaikitso
MrTaikitso Contributing Member • Posts: 822
As someone who spent literally months evaluating each camera, (lack of stock of GH2s meant I had to wait until the last moment, a week ago), I only rejected the A55 because the flip out display could not be positioned where I wanted it whilst the camera was on a tripod. The A55 is very innovative and excellent 'VFM' (Value For Money), but I purchased a GH2 14-140 and am over the moon with it. But that is not to discount the A55. They are both good for different reasons, but I would consider the GH2 more professional, whilst the A55 is the ultimate tourist camera, in particular thanks to the panorama and GPS capabilities.
E-PL2+20mm 1.7
 MrTaikitso's gear list:MrTaikitso's gear list
Samsung Galaxy Note 4 +2 more
bur437 Regular Member • Posts: 382
LOL! surprised you didnt post this thread as well!
http://forums.dpreview.com/forums/readflat.asp?forum=1037&message=37876909
You know the one where you continually bitch about Sony but get found out.
For what its worth, i think the GH2 is an excellent camera with few flaws but too expensive for me right now. The A55 has so much potential but seems let down by some small issues which hopefully are resolved in future SLT models.
Bur, get your facts right! I got found out for nothing, if you read the thread properly you will see I pointed at somebody else's comments, not mine. I recently tried an a55 myself a few weeks back, for a full 10 days, man it was bad and everything I heard about it was true, for video its the worse ever, for stills it made good and bad images, some was user errror some was just a poor image imo. I have zero experience with nex and I hope your happy with your choice of whatever in the future.
