D7000 sensor mark
Started Mar 20, 2011 | Discussions
Dave Thompson
Contributing MemberPosts: 645Gear list
D7000 sensor mark
Mar 20, 2011
Hi,
Could anyone tell me what would cause this on the sensor? Doesn't look like the normal dust marks to me. I have not tried to clean it yet until I am sure what type of mark it is.
I am always very careful when changing lenses etc and can only conclude it has been there since it left the factory.
Thanks for any help, Dave
http://davidrthompson.zenfolio.com/
 Dave Thompson's gear list:Dave Thompson's gear list
Nikon D800 Olympus E-M1 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 16-35mm f/4G ED VR +8 more
harri manni
Senior MemberPosts: 1,727
Re: D7000 sensor mark
In reply to Dave Thompson, Mar 20, 2011
Could be oil spots from the shutter mechanism or something, noticed my D7000 also had spots from factory, wonder it more houses is affected by this?
Had to clean my sensor after just a few weeks and I still have som minor spots left.
Harri - My blog: flatulated.blogspot.com
Dave Thompson
In reply to harri manni, Mar 20, 2011
Thanks, did wonder that as it looks like some kind of liquid smear.
Dave
HSway
Senior MemberPosts: 2,511
Hi Dave,
I sent my d7000 straight to Nikon because of this although it was clearly visible only on narrow apertures. Mirror box was not exactly spotless too. They cleaned it up and did so unusually fast (not a fix actually). I checked the work and it was done well.
Best,
Hynek
Dave Thompson
In reply to HSway, Mar 20, 2011
Thanks Hynek,
Did they say what the mark was? As long as it can be done with a wet clean I don't mind doing myself.
Dave
Gunzorro
Senior MemberPosts: 1,880
Why risk doing it yourself and being told you are at fault if it doesn't clean up? Do the smart thing and have Nikon take care of it, and become aware of the problem -- it could help you or others down the line.
HSway
There was some problem at the time caused by shipping cameras based on this sensor with stains in above average number of cases (namely K 5) along with claims it’s not being only a filter issue..
Besides I think brand new camera should come spotless as for these components. I had a chat with a technician and stressed specifically that I do not know whether it’s on the outer side of the AA filter.. All went smooth and quick. It’s clearly of a liquid/grease nature – yours too. I see it shows up at f9 which I think is rather bad.
They did it within warranty; I just mentioned I barely shot with it. They didn’t say what, just a note saying that it was all cleaned. – The last thing I thought to do is to start some ferocious headlines on forums but if someone is in trouble that’s different. – You can imagine we would see forum full of microscopical analyses at f32 for half of a year as some people when seeing no problem actually start to see it anyway as a sort of their brain reflection.
You will see, if it’s brand new (month or two) I’d talk to Nikon – after they log the camera into the system it could be by a week (with some check-call added). And I’d definitely talk to them should it stay there unchanged after wet clean.
Hope it helps Dave,
Hynek
Mr Physics
Contributing MemberPosts: 567Gear list
Seems prudent...
In reply to Gunzorro, Mar 20, 2011
...even if you've done this sort of thing dozens of times, it may be for the better good of you and all D7000 folk if you let Nikon fix it and register it in their product failure databases. And it could come back to bite you on the a$$ if you have another issue.
 Mr Physics's gear list:Mr Physics's gear list
Nikon D90 Nikon D700 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 50mm f/1.4D +8 more
Dave Thompson
Re: Seems prudent...
In reply to Mr Physics, Mar 20, 2011
Thanks for all your help. Think I will get in touch with Nikon and see what they have to say.
You have helped me by confirming that it is some kind of liquid staining and not the sort of thing you would expect in a new camera.
Will keep you up to date.
Regards, Dave
6fingers
Regular MemberPosts: 124
In reply to Dave Thompson, Mar 21, 2011
have the exact same thing on a new D7000, it's a kind of oil/grease. Going to Nikon to clean it.
Aristoc
Senior MemberPosts: 2,699
In reply to 6fingers, Mar 21, 2011
I have heard of cameras coming back from Nikon service more dirty then when they got there. I was at Nikon service desk personally when I heard the customer next to me get his camera back that went for cleaning. He said it was more dirty than when he gave it. The customer service person said there was nothing that could be done because the technicians do not work in a 'dust free environment'. If the customer wanted further cleaning, he would have to leave the camera and they would have to take it all apart completely and that would take several weeks.
It's well worth it to do some of your own mirror/sensor cleaning with a product like http://www.visibledust.com
Dave Thompson
Re: Update
In reply to Aristoc, Mar 27, 2011
Hi, just thought I would update you on the progress with the staining on my D7000 sensor. I e-mailed nikon and they have agreed to take the camera in and check it. Thought this may be the best approach rather than do it myself just incase it's something nasty!
I will keep you informed, Jessops have very kindly sent it back through the store.
Regards, Dave
rpps
Senior MemberPosts: 1,090Gear list
Re: Update
In reply to Dave Thompson, Apr 23, 2011
I have the same oil type marks on my sensor and have ordered a kit from Copperhills to do the cleaning myself but after seeing the posts here I think I will send it back to Nikon Australia at least then it will be logged in case of further trouble.
I have sent them this photo and they have agreed to do the cleaning under warranty it's a nuisance having to be without the camera for 10 days or so.
Has anyone had their D7000 cleaned by Nikon and what was the results ?
 rpps's gear list:rpps's gear list
Nikon D600 Nikon D5200 Nikon AF Nikkor 35mm f/2D Tamron SP 70-300mm F/4-5.6 Di VC USD Nikon AF-S Nikkor 50mm f/1.8G +2 more
Hooterville
Contributing MemberPosts: 552Gear list
Re: Update
In reply to rpps, Apr 23, 2011
UFO in the sky?
 Hooterville's gear list:Hooterville's gear list
Sony Cyber-shot DSC-HX100V Sony Cyber-shot DSC-HX200V Sony Cyber-shot DSC-HX30V Nikon D7000 Nikon 1 V1 +1 more
eNo
eNo
Forum ProPosts: 11,717
Dust bunnies are a DSLR byproduct
Yes, dust bunnies. Careful lens swapping (camera upside down, non-windy/dusty environment, etc.) along with the built-in shake sensor cleaning will avoid much dust, but not all dust. If it is dry dust, a Rocket blower will get it off without much hassle. If it's wet, caked on, or oil from moving parts, etc., you will need a wet cleaning. Learn how to do it yourself, and with care and meticulous attention, you should be able to do it without too much trouble.
Seeking the heart and spirit in each image
Gallery and blog: http://imagesbyeduardo.com
Flickr stream: http://www.flickr.com/photos/22061657@N03
rpps
Re: Update
In reply to Hooterville, Apr 23, 2011
Hooterville wrote:
UFO in the sky?
There's always got to be one in the crowd . LOL
Rotorbug
Contributing MemberPosts: 690
In reply to harri manni, Apr 24, 2011
I think you are spot on, excuse the pun!
I have cleaned 800 sensors over 5 years and would come to the same conclusion just looking at the above photo.
Needs a wet clean.
My D300s came dirty with same kind of lubricant type spot.
birdpix
Senior MemberPosts: 1,381
In reply to Gunzorro, Apr 25, 2011
Mine is coming back from NY Nikon service this week from the same exact problem - looked like a star map of an astrological sign on my sensor, despite repeat camera and manual sensor cleanings. I've had dust bunnies on other DSLR's, but these seemed to be more of splash or stain mark look to them.
Hope it's fixed when it gets back here!
Eric in Florida
rpps
In reply to birdpix, Apr 25, 2011
Eric in Florida
Please post the results as I'm still debating whether to send mine back to Nikon or doing it myself, 2 weeks turn-around for Nikon service
Steve Bingham
Forum ProPosts: 19,730Gear list
As stated above - oil spot
In reply to Dave Thompson, Apr 25, 2011
Return to Nikon for cleaning. This is NOT a dust bunny.
Steve Bingham
http://www.dustylens.com
http://www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon D300 Fujifilm X-E2 Nikon D5300 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 50mm f/1.8G +10 more
