OM 50mm 1.4 or 1.8 for my E-520?
Started Mar 8, 2011 | Discussions
xelidonhs
xelidonhs Junior Member • Posts: 34
I will be visiting an annual photo-fair in a couple of days, in the hope of finding some old manual fixed & fast lenses for my E-520. I really enjoy shooting in atmospheric & dim lit enviroments without flash, so I have 2 problems. First, I'm obviusly not able to use any ridiculous high ISO that would give pleasing results, so the need of a fast prime is great, not to mention the bokeh someone can create with such a lens.
Second problem, my budget is extremely limited, so everything that would cost me more than 80 euros (with a cheap non-chipped adapter) is simply no option...
Actually, I'm rather excited to get a glimpse in the world of lacking AF and having to do everything manually, sounds like great fun
I'm aware that the oly OVF is small, and that I can alternatively use LV with magnification (witch I'm not fond of using more than necessary), or maybe buy an ME-1 magnifier eyecup, which could make the OVF slightly more acurrate.
But back to my question:
after some net research I understand that the later the versions the better, mainly cause of multicoating.
Also have found out on numerous sites for what serial number to look for and how older versions difere from newer ones (Blacknose and so on...)
The thing that interests me is wich will be sharper wide open and better overall on my digital 520!
I've read somewhere that the 1.8 is sharper @ 1.8 and 2.0 than the pricier 1.4 @ the same apertures! And, even if so, is it wiser choosing an older version of the OM 50mm 1.8 than a newer version of the 1.4 one?
Also read some reviews about them used with digital Oly bodies and the results seemed rather disappointing...
Since I didn't yet buy the om> 4thirds adapter, the thought crossed my mind to buy a Nikon AI> 4thirds one. The selection at the fair will surely be larger, maybe a bit pricier, but if it's worth it what the hell. Any suggestions there on old fast primes, or anything else to pay attentin to?
your help is greatly appreciated guys,
thanx in advance
Bluephotons Veteran Member • Posts: 4,486
Re: OM 50mm 1.4 or 1.8 for my E-520?
I don't have the answer, but I'm about to get a 1.8 so i'm interest in your question, hopefully some body will chime in.
Bluephotons
Ah, but I was so much older then, I'm younger than that now. Bob Dylan
 Bluephotons's gear list:Bluephotons's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8
you can call me captain Forum Member • Posts: 51
Count me in too - waiting for people's comments, but also considering the use of a Nikkor 50 1.4D.
The added value of that is that it leaves more options open for the future.
BMcCuskey New Member • Posts: 12
I have an OM 50mm f/1.8 that I got when my dad gave me his OM-2n many years ago. I pretty much always just kept that lens on my e-300 and just suffered with trial and error focusing. (It is amazing how easy it is to focus with a split prism focusing screen found on film bodies.) The little bit I have played with the E-5xx's they have seemed to have a better viewfinder than my E-300, so that might help. The 1.8 might not be the greatest of lenses but it is fast, compact, and rather inexpensive and I have a lot of fun with it. With practice, focusing isn't too difficult and having those few extra stops over the kit lens is a blessing. For a while after I received my adapter and mounted the 50 on my camera I hardly picked up my 14-45mm kit lens just because of how slow it was.
Hope that helps some.
I forgot to mention, I also have a M42 to 4/3 adapter. There are a number of inexpensive lenses on eBay in M42 mount.
RoyGBiv Senior Member • Posts: 1,956
I have both the 50mm f/1.8 & the 50mm f/1.4.
I haven't done any sharpness comparison. Both are quite adequate. I have a preference for the f/1.4, but I must warn you...using it wide open is an exercise in chance, bcs your ability to judge focus through the viewfinder is much less resolved than it needs to be for such shallow DoF. It's not "difficult," or "challenging" as if there were alot of skill involved. If you had it on a camera with a legitimate focusing screen (like an OM-1) I'd say it was difficult. In the case of modern dslr camera bodies, it's a little bit of skill/experience, a little bit of intuition, and a lotta luck. If I had a legitimate focusing mat that offered some indication as to what plane of view is in focus, that would help.
Now, if you use the magnification technique, that helps tremendously.
If you have the patience, they're certainly fun to play with though.
'I have no responsibilities here whatsoever'
marvinvee Regular Member • Posts: 182
I have a zuiko 50mm 1.8 on my e 500. not bad takes time to focus but not bad lens . Not as sharp as the kit lens 14- 42 mm. But i wear glasses so i could be wrong
its nice and compact . But i have get used to a 5omm all over again which acts like an 80 mm on my E 500. Still working out the bugs with digital slr photography, i shot film for years new concept for me. But the 50 mm zuiko was cheap on ebay something in the thirty dollar range. the adapter from China was $15.00 which took two weeks to get , but works fine. If i had a split prism in the camera every thing would be fine with this lens. I also have a 35 -70 tokina zoom i got for cheap on ebay, lota fun to play with with the adapter. just my 2 cents worth
sunisri
sunisri Senior Member • Posts: 1,431
I have both lenses OM Zuiko 50mm F1.8 (multi coated one) and OM Zuiko 50mm F1.4 (Silver nose) I prefer OM 50mm F1.8 over F1.4 as F1.4 lense is too soft at F1.4 so you might have to stop down to F2.0. I am attaching a few sample pics here taken with different bodies so that you will get an idea. All pics are OOC jpegs except the last one as I was playing ISO 800 on E-1 so had to PP a bit to clean the noise.
OM Zuiko 50mm F1.8 you can get it for 20 -30 buks
OM Zuiko 50mm F1.4 you can get it for 60 - 80 buks
E-620 + OM Zuiko 50mm f1.4
E-1 + OM Zuiko 50mm F1.8
E-330 + OM Zuiko 50mm F1.8 ( 2 pics)
E-330 + OM Zuiko 50mm F1.4 + EC-14
E-1 + OM Zuiko 50mm F1.4
Sri
 sunisri's gear list:sunisri's gear list
Olympus SH-50 Olympus E-1 Olympus E-330 Olympus E-30 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +7 more
highyoyo Regular Member • Posts: 138
If you do a search of this forum I believe you will find the the 50mm f1.8 is highly regarded and you will find some excellent photos taken with it. Particularly check out some of Justin's work (jfinite).
You will also find the 1.8 for a much better price than the 1.4 and, since you may have to stop down the 1.4 to get the results you want, I would say it is the better buy.
Check out this website for some detail on the various OM lenses - be sure to check out the latest tests as well as the original ones - http://www.biofos.com/cornucop/omz_e1.html It doesn't talk about the 50/1.4 vs. 50/1.8 but does have some comparisons with the 50/1.2 indicating you may get some decreased sharpness at larger apertures due to what he refers to as "ghosting".
Also check this current thread on the 180mm OM lens - http://forums.dpreview.com/forums/read.asp?forum=1022&message=37903450 I believe there is a link to some of Justin's 50/1.8 photos in there.
Hope this helps.
 highyoyo's gear list:highyoyo's gear list
Olympus E-M1 Olympus 12-40mm F2.8
InOmaha Regular Member • Posts: 236
I own both and have used the 1.4 adapted to an E-510. It's hard to focus wide open with the small viewfinder. But, I have glasses. I also have a pentax magnifier and a focus confirm chip, but live view still works the best.
Here are some nothing special first test photos I took with the 1.4 wide open. You can see the problem ghosting and fringing wide open that can occur if you look at the edges of the water. The flower maybe, but I think the back edge was already going out of focus.
I took this one with the 50 1.4 also using live view to focus.
 InOmaha's gear list:InOmaha's gear list
Olympus E-M1
Another website with direct comparison
Hope this helps.
Here's another website with a direct comparison between the different OM 50mm lenses.
http://omexperience.wordpress.com/comparisons-thoughts-misc/zuiko-50mm-shoot-out/
Olympus E-M1
Dave Bennett Senior Member • Posts: 1,528
Re: Another website with direct comparison
Def the 50mm f1.8, but preferably a later Made in Japan one.
Dave
Welsh Photographic Federation Judge
UK Photo Safari Group Member
Chairman Cwmbran Photographic Society
http://www.pbase.com/benvendetta
pbase supporter
mariomirabile
mariomirabile Senior Member • Posts: 1,319
I've tried both the 1.8 & 1.4 on my E-500. The 1.4 wide open to f2.8 was very soft and fuzzy with unreliable metering anywhere outside the f4-f8 aperture range. The 1.8 is better wide open and possible sharper across the whole aperture range, and the metering seems more reliable. The best examples of the 1.8 have "made in japan" (note no capitals...) inscribed around the front of the lens.
Mario
I just got mine, just as you describe it, got it for $20.00 the guy also have a Takumar but I don't know which one, I just saw it briefly, I will get that one tomorrow for another $10 because I did not carry any extra cash (Craig's list safety transaction habits)
Bluephotons
wjlonien Senior Member • Posts: 1,176
Hi,
I have the 1.8 only, also on an E-520, and yes, it's great fun to play around with it.
According to lenstip at http://www.lenstip.com/118.1-article-90_years_of_the_Olympus_company_-_Olympus_F.Zuiko_Auto-S_50_mm_f_1.8_versus_Olympus_ZD_50_mm_f_2.0_Macro.html - see page 4 at http://www.lenstip.com/118.4-article-90_years_of_the_Olympus_company_-_Olympus_F.Zuiko_Auto-S_50_mm_f_1.8_versus_Olympus_ZD_50_mm_f_2.0_Macro_Image_resolution.html for details - it challenges the 50 macro at an aperture of 5.6 in terms of resolution.
I can confirm that from f4, mine is really super sharp. At f2.8 it's nice, and at f1.8 you still get a nice sharp image if you focus carefully, tho it is lots more "dreamy" than the 50 macro of course. Not bad at all for portraits.
My wife tool this one of me with f5.6 and external (bounced) flash:
(for full resolution, look at Flickr)
I have similar sharp photos taken with that lens - and also had lots of misses in the beginning. But you can grow on it; I really did, and it's still lots of fun to use this little (and cheap) gem even now that I also own the 50 macro.
I have tagged images on Flickr, so if you want to see more taken with that lens, look at http://www.flickr.com/photos/wjlonien/tags/omzuiko1850mm/
Good luck with finding one (mine came from Austria, the adapter from Germany). You will have lots of fun with it I'm sure.
There's one photographer here (John King from Australia) who told me his 1.4 lens is even better than his 1.8 one - I cannot confirm that since I only have the cheaper 1.8 one.
Hope that helps,
and cheers,
Wolfgang
using free and open source software, and an open camera system
http://wolfgang.lonien.de/
http://picasaweb.google.de/wjlonien/
nazmi Regular Member • Posts: 200
My vote is for OM Zuiko 50mm f1.8 (Made in Japan)
I think i've read somewhere saying that the 'Made In Japan Version' is much sharper than the earlier version of this f1.8 lens after olympus make a correction to their optical formula which is in the 80's. The new version is very sharp at f2.8. I don't have the f1.4 so i can't comment. Some of the source which you can read about the OM Zuiko lenses:
http://www.mir.com.my/rb/photography/hardwares/classics/olympusom1n2/shared/zuiko/htmls/index.htm
http://www.mir.com.my/rb/photography/hardwares/classics/olympusom1n2/shared/zuiko/htmls/50mm1a.htm
Hope that helps.
Cheers.
 nazmi's gear list:nazmi's gear list
Canon EOS 6D Canon EF 50mm f/1.8 II Sigma 35mm F1.4 DG HSM Art
Paribus Regular Member • Posts: 111
Example of low light hand held
I have a 50mm f1.8 which I have had with my OM1 since the late 70's. You will find the f1.8 is cheaper and easier to find than the f1.4. I find it plenty sharp enough on my E510 and E3. Here's an example taken with the E510, hand held at f1.8 late in the afternoon summer light in Australia (in my backyard actually).
I used the LV to focus as it would have been impossible through the viewfinder. I printed this picture in A3 size and am very happy with it.
I don't do a lot of close up or flower photography but I particularly like the 50mm for this type of shot. The de-focussed area looks almost painterly.
 Paribus's gear list:Paribus's gear list
Sigma DP2 Ricoh GR Digital IV Fujifilm X100T Olympus E-3 Ricoh GXR A12 50mm F2.5 Macro +3 more
mr inspire Junior Member • Posts: 38
Re: Example of low light hand held
THe 50mm OM is nice. But can i recommend you the helios 44m? It is sharper and nicer bokeh. But the focusing is not as silky smooth as OM
Olympus maniac I am.
Gaëtan Lehmann Regular Member • Posts: 121
I've played with two old legacy lens on my E-420: a tokina 2.8/135 and a zuiko 1.8/50.
I've been quite disappointed by the poor quality of the tokina, but very pleased by the quality of the zuiko.
Focusing is quite hard and I don't have an AF confirm adapter to help.
It's possible get quite sharp results with it - I'm often more limited by the very thin DOF then the sharpness of the lens.
On this image for example, it was not possible to get the two eyes in focus.
Full size image is there: http://glehmann.smugmug.com/Public/24h-avec-le-Zuiko-OM-50mm-f18/13539023_Xmv3V#986662892_EYTyH-O-LB
I've put all the photos I took in my first 24 hours with this lens in this gallery - it may give you an idea of the kind of result you may have.
I bought mine for 30€ with the old OM reflex and the box. The adapter was order on a ebay for ~ 12$.
If you go with this kind of large aperture, I think it's worth getting an adaptor with AF confirmation.
Gaëtan
AlexRC Regular Member • Posts: 169
Anyone considering using fast legacy lenses on a DSLR should read this link first:
http://www.jayandwanda.com/photography/dslr_man_focus/man_focus.html
The witer points out that the live view sensors on DSLRs have a focusing limit of f/2 to f/3.5, depending on the model, in your case around f/3.5.
Which means that an f/1.4 lens depth of focus appearance in live view will be what the lens would have at about f/3.5. So that the live view will look sharp, but the image may be out of focus.
The link has test images to show this effect.
