NEX-5 Video - crazy shutter speeds.
Started Jan 29, 2011 | Discussions
izash
izash Regular Member • Posts: 199
Hi,
Since I wasn't happy with what the shutter speeds did to NEX video, especially with the 18-55 kit lens, I downloaded the demo of DVMP Pro, to check on the shutter speeds of my videos, using AVCHD Metadata.
The shutter speeds range from 1/25 to 1/2000 on sunny days.
Now that I can measure the shutter speeds in video mode, I'll do some tests with my new Fader ND filter and try to establish a system for controlling shutter speeds.
How I wish Sony would let us control shutter speeds in video mode...
Good night
Izhar
jazzroy1972
jazzroy1972 Regular Member • Posts: 172
Re: NEX-5 Video - crazy shutter speeds.
you still cannot control ISO..
but could you tell us if shutter speed changes during a video?
izash
izash OP Regular Member • Posts: 199
ISO is not a variable in video mode. The NEX keeps it at 200.
You can actually see shutter speeds changing during a shot, as the light changes!
Izhar
Leo Fischel
Leo Fischel Regular Member • Posts: 124
Does the shutter works on videos? I thought it is open all the time and if not: Why can't I hear the shutter?
Jorisbass
Jorisbass Regular Member • Posts: 346
During video, exposure time is controlled electronically (I guess by enabling and disabling the photo diodes on the chip).
The mechanical shutter is far too slow for this.
GodSpeaks
GodSpeaks Forum Pro • Posts: 11,406
Prior to shooting video, put your camera into Shutter priority mode. Set the shutter speed to 1/60 second and shoot. The shutter speed should stay locked.
Aperture, on the other hand... and you may need an ND filter for very bright days.
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
  • Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic Lumix DMC-FZ1000 Kodak DCS Pro SLR/n Nikon D800E Sony Alpha DSLR-A850 +43 more
GaryW
GaryW Veteran Member • Posts: 8,119
I thought it was the other way--set aperture, and that setting is preserved in video mode. So you couldn't directly change the shutter, but you can effectively force it to be slower when using a wider aperture. Besides, I would think many would like to set aperture for aesthetic reasons.
  • Rayna Butler
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Alpha NEX-5 +9 more
GodSpeaks
The one thing you do not want in video, is a fast shutter speed. That leads to jerky motion... ie: non fluid. So it is best when shooting video to control the shutter speed.
You can also control the aperture, and that is easiest to do using a legacy lens where you can manually set the aperture. You would then use ND filters to bring the exposure down to where you wanted it (assuming plenty of light).
But that process is obviously not for casual shooting.
Oh, and turn OFF AF. Focus hunting in HD really looks horrible.
  • Rayna Butler
Amateur Sony Shooter
Amateur Sony Shooter Veteran Member • Posts: 5,417
What speed during video?
Sorry for my dumb question. Is it shutter only apply when you take still pictures? For video recording my understanding is that the shutter always remain open. I heard lots of talks about "rolling shutter", "jittery", etc. Can someone explain to me in plain language. What happened when still camera is doing video recording?
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-200mm F2.8 G Kenko Teleplus Pro 300 AF 1.4x +5 more
Higgins2002
Higgins2002 Regular Member • Posts: 393
  • Rayna Butler
Yes 2x fps is the way to go...
  • 25p--> 1/50
  • 30p--> 1/60
But that's not possible to choose by yourself
NEX crippled videomode gives you:
Aperturemode to play with
you can always use F16-32 to get slower shutterspeed (and record all the dust on sensor too )
  • All the other modes doesn't affect the video at all
Too bad is:
You never get Sony do do manual video for the NEX3/5 because they aimed these models toward up-graders from P&S
 Higgins2002's gear list:Higgins2002's gear list
Sony RX100 Panasonic Lumix DMC-FZ1000 Canon EOS 6D Samsung NX500 Canon EF 70-200mm f/4L IS USM +4 more
izash
In the past few days I've been experimenting with Fader ND to control shutter speeds with decent results.
I set ISO at 200 as NEX records video at a constant ISO of 200. I choose A mode, chose my desired aperture and dial the Fader ND until shutter speed reaches 1/50.
When I checked the resulting AVCHD files, I noticed that shutter speeds moved between 1/50-1/60.
This is not ideal, but Fader ND is a savior and the resulting video looks much better when the shutter speeds are controlled.
  • Rayna Butler
  • 25p--> 1/50
  • 30p--> 1/60
Too bad is:
alpi
alpi Forum Member • Posts: 57
Just curious , how do you know NEX records at constant ISO 200 ?
(Is it showing up as gain figure in DVMP ?)
Higgins2002
You can set whatever ISO you want but it doesn't affect the movie mode .. so kind of pointless.
Higgins2002
Gain in DVmp is probably connected to ISO.
It seems like GAIN in DVmp never going higher than 27dB
Oelph
Oelph Contributing Member • Posts: 621
Izash, thank you for sharing your results.
alpi
Which is why it would be nice to have gain limiter as well as control of shutter speed.
danw82
danw82 Regular Member • Posts: 120
I've not done anything to back up the observation, but I got the impression that if the video would otherwise underexpose even at 1/50 shutter, or whatever the minimum is for video, that it automatically cranked the gain/iso to compensate. I've tried shooting the same video in poor lighting with f1.7 and f5.6, and the f1.7 video came out with noticably lower noise.
It is a shame, if it was simple enough for Sony to enable aperture locking in the last firmware, I can't really see that it would be much of a stretch to extend that to shutter and ISO... simple additions and it would make video far more useful.
It'd be nice if they let us pick a higher video bitrate too, assuming the encoding chip could handle the bandwidth.
alpi
That would make more sense. I just wondered if maybe DVMP was mis-interpreting or missing metadata resulting in a constant gain figure being reported.
Just downloaded it and gave it try myself on a range of short clips. It gave gain figures from 3 dB to 27 dB in a range of conditions from bright to low light which would be roughly what you would expect.
GodSpeaks
Re: What speed during video?
When talking about video we are talking about the electronic shutter, not the mechanical one.
An electronic shutter will capture a frame off the sensor and give it a timed exposure (shutter speed). It does this 24, 25 or 30 times per second (depending on the frame rate of the video).
The mechanical shutter is only for stills. If it was used for video I think it would have a pretty short life, assuming it could even keep up with the frame rate.
  • Rayna Butler
zoranT
zoranT Contributing Member • Posts: 915
to make things clear
1) ISO gain does change in video mode - visible and obvious with the noise in low light surroundings (where would the noise come from?); however, very bright lenses behave more favourably than the kit lenses; less noise
2) You cannot control shutter speeds directly in video mode; you only crank up aperture value, but then ISO value may increase as well; the exact algorithm and behaviour in relation to light, aperture, circumstances etc. is hard to understand
Izhar
