Accessories for the Olympus XZ-1
Started Jan 20, 2011 | Discussions
Knight Palm Veteran Member • Posts: 3,723
I've prebooked a XZ-1 camera today. Now I'm trying to figure out what essential accessories are needed (extra battery, charger, case, HDMI cable) and what to skip. I'll await to see if I really need the VF-2, since the 3" OLED display might be satisfactory for my needs.
Comprehensive accessory list for XZ-1:
• FL-36R Electronic Flash
• FL-CB05 Off Flash Cable
• MAL-1 Macro Arm Light
• VF-2 External Electronic Viewfinder
• SEMA-1 Microphone Set 1
• CB-HD1 HDMI cable (type A / type D micro)
• LI-50B Battery (3.7V, 925mAh)
• LI-50C Lithium ion battery charger
• CNS-09 Black leather strap
• CSCH-84 Fitted leather case
Ludwig Wittgenstein; British philosopher born in Austria; a major influence on logic and logical positivism (1889-1951):
“What can be said at all can be said clearly; and whereof one cannot speak thereof one must be silent”
 Knight Palm's gear list:Knight Palm's gear list
Olympus XZ-1 Olympus E-3 Olympus E-300 Olympus E-400 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD +4 more
Knight Palm OP Veteran Member • Posts: 3,723
a page with its accessories
Found Olympus America has a page with its accessories:
http://www.olympusamerica.com/cpg_section/product.asp?product=1530&page=accessories
and an additional accessory for the XZ-1:
• RM-UC1 Remote Cable Release
What functionality has the multi-USB port of the camera besides charging, remote, accessing the cameras memory card, VGA video?
Allan Ostling
Allan Ostling Regular Member • Posts: 236
conversion lens adapter
Also you might want the CLA-12 conversion lens adapter, mentioned in the last table here: http://www.dcresource.com/reviews/olympus/xz1-review . This may allow mounting of the TCON-17 1.7X telephoto attachment, giving a focal length of 200mm. You may also be able to mount the new wide-angle and fisheye attachments announced for the Olympus E-PL2 (using the appropriate step rings).
Allan
AJohn Veteran Member • Posts: 9,461
I'm not so sure...
...Yes, the last table does mention the CLA-12 lens adapter, but the table at the top shows 'no' conversion lens support. So, does it have lens threads for an adapter or not? I'm not sure this has been addressed anywhere yet.
No lens threads might be a deal breaker for me. I like leaving the camera on with lens extended and protected in a tube with a filter on the end (like my C750).
Richard Butler
Richard Butler dpreview Admin • Posts: 2,204
Re: I'm not so sure...
There's a menu option to enable the use of the TCON-17.
Richard - dpreview.com
Hmmm, interesting...(edited)...
...so then there must be lens threads on the body like the C-series cams. Hard to tell in the pictures.
I wonder why it would need a menu item to enable it? That seems odd. It should be just like a filter that you screw on and it's all optics after that. There's no menu item like that on any of the c-series (or others) that I ever heard of.
Will have to stay tuned on this one. Thanks Richard.
DigiDan Contributing Member • Posts: 575
Re: Hmmm, interesting...(edited)...
This is to stop the lens from zooming and hitting the TC, most cameras with add ons have this menu option.
Danno
 DigiDan's gear list:DigiDan's gear list
Samsung TL500 Panasonic Lumix DMC-LX5 Sony Cyber-shot DSC-HX30V Olympus E-1
Danno...
...I getcha, thanks! It's just not something I even considered, because when I got the adapter tube for my C750 (way back when), I just had to make sure to get the right one so lens extension was not an issue.
That was a common consideration back then. I guess things have changed. Maybe this is done by Oly, so they can use their standard tube without designing another?
When I did this, I bought a Bower and there were different sizes. Just had to get the right one.
justharry Regular Member • Posts: 369
There are several excellent shots of the XZ-1 on DPRs Preview. One of the photos - when enlarged - clearly shows the threads . It's on page three of the review; the photo (with zoom extended) next to the photo of rear control dial.
 justharry's gear list:justharry's gear list
Canon PowerShot SD700 IS Canon PowerShot G9 Sony SLT-A77 Sony DT 35mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD +2 more
Oh yeah, I see it,...
...Arrrgh, I missed it in that picture. I was looking at the straight on view before. Nice to see that filters can be used. Thanks for pointing that out JH.
Wayne N. Veteran Member • Posts: 9,986
Re: Oh yeah, I see it,...
Indeed. Gotta have a polarizer on that puppy!
Wayne
http://www.pbase.com/wayne_n
Conversion Lens Adapters for i.e. DigiScoping
exists for several P&S cameras, and obviously the XZ-1 has threads that can fit to an existing or new one:
http://asia.olympus-imaging.com/products/compact/accessories/conversion/#adapter
Also an adapter is needed if the camera should be used for digiscoping.
Until we'll see a System Chart for XZ-1 , I suppose we'll have to guess what the lens accessories are. Most likely we'll see more accessories if the XZ-1 sustain it's initial scuccess and as well paves the way for an XZ-10 complement.
XZ-1 arrives in Sweden
Got my new camera today.
No accessories decided yet, apart from 133x (20MB/s) 16GB SanDisk Extreme SDHC card. And one extra battery.
It's a responsive camera, it loves low light, has an effective built in IBIS image stabilizator, fast focus, and an impressive image quality. Video is fun too.
The control wheel on the back is quite sensitive, I did struggle a bit with my freezing hands today, but I might get used to it after some practise.
Olympus 12-pin multiconnector for USB, AV, Remote, Charging
Both these images are taken with the XZ-1 in the supermacro setting, both at max aperture opening ƒ/1.8, both at freehand. I can imagine this little camera will become popular for easy macro work, since it's so easy to achieve both sharp and esthetic results with it.
First time I experienced this connector was with the DSLR E-400, and it seems Olympus has been frequently using this one, so a lot of accessories using this connector are also found on eBay.
FlamingJune1967 Contributing Member • Posts: 845
Re: Olympus 12-pin multiconnector for USB, AV, Remote, Charging
Thank you for posting your photos, Knight Palm! Please post more! I am camera-less at the moment, and so am having to live off other's photos
High altitude skiing with Olympus XZ-1
Thanks for your comment.
More pictures and a link to a youtube video at my other thread:
  • High altitude skiing with Olympus XZ-1 [IMGs]
http://forums.dpreview.com/forums/readflat.asp?forum=1008&message=37663944
Regarding accessories, one extra battery was enough to have to switch with, since the capacity lowers in very cold temperatures. Regarding the 133x (20MB/s) 8GB + 16GB SanDisk Extreme SDHC cards, those worked well and even some space were left on them after a week of plenty useage.
LLS1 Regular Member • Posts: 423
I guess the image stabilization system has to know the focal length to work properly.
PT-050 Underwater Housing for the XZ-1
Perhaps something to even put on a car or a motorbike.
System chart in original language:
http://olympus-imaging.jp/product/compact/accessory/underwater/pt050/pdf/pt050_systemchart.pdf
Powering your XZ-1 (LI-50B & LI-50C)
It seems the Olympus LI-50B battery (3.7V, 925mAh, 3.5Wh) is manufactured by Sony and identical to the Pentax D-LI92 and Ricoh DB-100. This means you could get an original charger also from Pentax or Ricoh to charge the original battery for your Olympus XZ-1.
Check the third party replacement batteries from Energizer:
http://www.energizerbatteries.com/productList.asp?device=DIGCAM
I really like the possibility of USB charging the XZ-1, because it's now easy to charge the camera battery in the car or on a motorbike or on a snowmobile. I think the popularity comes from the way you charge your iPods & iPhones. Provides easy access to public 'charge stations' for 'people on the go'.
If you already have an 230V to USB 5V transformer, all you need is an extra USB cable:
■ CB-USB6 is the combo cable that comes with the XZ-1 camera. (Shorter in length now.)
■ (CB-USB4 comes with the standard Mini-USB Series B connector, which is supplied with the E-5 DSLR, hence doesn't fit the XZ-1)
Of course it's recommended to bring an extra battery with, preferably charged via the separately sold Olympus Li-ion battery charger LI-50C, which requires approximately 2 hours charging time.
Capdase Screen Protective Film 3.5" | ScreenGUARD
Another accessory I can recommend is the ScreenGUARD ARIS |iXiMAG|IMAG from http://www.capdase.com/ The XZ-1 needs the universal 3,5" 50x72mm foil slightly trimmed to fit the cameras large (50x71mm) OLED display.
Ref :
  • Capdase Professional ScreenGUARD ARIS Model No. : SP00D035-C
http://www.capdase.com/en/product5.php?cid=6&bid=29&mid=171&pid=3380
