Heads up - New boxed Ricoh Caplio 500G on Ebay
Started Jan 5, 2011 | Discussions
Andrewteee
Senior MemberPosts: 2,632Gear list
Is it worthy?
In reply to schaki, Aug 19, 2013
Is this camera particularly worthy of tracking down? Is the IQ particularly good? I'm just wondering why this is such a hot commodity.
 Andrewteee's gear list:Andrewteee's gear list
Ricoh GR Digital IV Ricoh GR Leica Q Ricoh GR II Fujifilm X-T1 +4 more
schaki
schaki OP
Senior MemberPosts: 2,215Gear list
Re: Is it worthy?
In reply to Andrewteee, Aug 19, 2013
Sure yes. The 500G and 500SE are based on the Ricoh Caplio GX8 and have better image quality than the newer G600 and G700 which uses slower zoom, smaller sensor and more NR which not can be set to Off. Like GX8 the 500G/SE also uses PD AF which is faster.
I'm not very bothered by the extra bulk, to me it is worth it.
There is some threads about the 500G/SE over at Ricohforum.com even though the PX is dominating there. But that's because the it is newer and not as pricey as the 500G/SE was when these still was sold new. Now it can almost only be found as used on Ebay.
I had a good look at the PX but the image quality was worse than the G600 and G700 as well plus the slower aperture so I backed off from that one.
The Ricoh G800 might arrive at some time during this autumn as long as Ricoh intend to follow their approximately interval of two year for that series. As the zoom in the G600 now also has been used two times with the G700 and G700SE, it should be time for a new zoom.
Hopefully it will be the same fast, (at the wide end) zoom as in Olympus TG-1 and Pentax Optio WG-3. Though hopefully without the smudgy NR in the WG-3 which was a disappointment.
I hoped much that Pentax would get it right with that camera.
 schaki's gear list:schaki's gear list
Contax TVS Digital
schaki
schaki OP
Re: A 500G
In reply to schaki, Sep 9, 2013
Contax TVS Digital
schaki
schaki OP
Re: A 500SE
In reply to schaki, Sep 22, 2013
http://www.ebay.com/itm/Ricoh-Caplio-500SE-8mp-Waterproof-Digital-Camera-/231058210774?pt=Digital_Cameras&hash=item35cc247fd6
Quote from the auction below
You are bidding on a USED Ricoh Caplio 500 SE 8mp Waterproof digital camera. It is well used but works fine taking photos.
NOTE: The connector port to the computer does not work which is why this is listed as FOR PARTS or NOT WORKING.
Comes with camera, neck strap and aftermarket battery and charger.
Memory Card not included.
Sounds like the USB port. Well that should not be a problem as the camera uses usual SD cards to store images on which can be put into a cardreader.
Contax TVS Digital
