just received my Pentax 18-135 mm lens
Started Dec 29, 2010 | Discussions
gotompoes Regular Member • Posts: 465
Very nice lens indeed. Small size and well build.
Did some comparisons between this lens and the 50-135 mm and the 18-55 kit lens.
Its IQ is indeed somewhere between the kit lens and the 50-135 mm but closer to the 18-55 then to the 50-135. My educated guess an improvement of 30 % over the kit lens. As such not a spectacular improvement.
Very happy with the lens as it is an ideal walk around lens. But for the more serious work i will return to the 31mm/77mm and the 50-135 mm lenses.
Considering the image quality rather expensive.
Conclusion: very convenient, improvement of kit lens but somewhat expensive, very usefull addition to my current lenses.
 gotompoes's gear list:gotompoes's gear list
Leica Q Leica SL (Typ 601) Fujifilm X-Pro2 Leica Summilux-M 35mm f/1.4 ASPH Leica Summilux-M 50mm f/1.4 ASPH +4 more
mvb123 Veteran Member • Posts: 3,299
Re: just received my Pentax 18-135 mm lens
Congrats!
Maybe not a spectacular improvement but given the much greater focal range and the compact size I think it's a good achievement.
Yes, it's not quite cheap.
I ordered one too 7 weeks ago but it's still in backorder..
Menno
ozdean
ozdean Forum Pro • Posts: 23,007
How does it compare to the 55-300?
Thanks for the report BTW
Regards Dean - Capturing Creation
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited +9 more
Johan Josefsson Senior Member • Posts: 1,151
But if you would like to stay within Pentax lenses and have the same range with same or better IQ you would need to go with either...
DA16-45 + DA55-300
+ ~ same price
+ 16-18mm and 135-300mm
\- Dual lens
\- No WR
\- No 45 - 55mm
\- Heavier, bulkier
DA17-70 + DA55-300
+ 17-18mm + 135-300mm as a bonus
55-70mm Overlap
\- ~ 2x price
\- Dual lens
\- No WR
\- Heavier, bulkier
DA*16-50 + DA*50-135
+ WR
+ Better IQ
+ 16 - 18mm
\- ~3x price
\- Dual lens
\- Heavier, bulkier
Even as a pretty expensive lens, I would like this one.
+ Seems to have good IQ, I am happy with the sharpness with my copy of the 18-55II, but the bokeh isn't really to my taste. Rounded ap. blades on the 18-135 might make a huge difference here.
+ 1 lens. One compact super zoom with decent IQ to complement my primes when on travel. This is what I use my 18-55II for today, this lens will probably do a much better job.
+ WR - Very useful for a "go everywhere" lens.
janneman02 Forum Pro • Posts: 15,732
Very usefull indeed, when shooting and requiring or desiring at least WR, the 50mm split in the DA* line up can be very annoying.
Despite what s being said in many * vs WR debates, I think the 18-135 WR feels more solid compared to at least my 16-50 (maybe due to compactness). Also one of the sliding tubes is metal and not plastic (I know, I scratched it already )
The difference between genius and LBA is that genius has its
limits.
  • Janneman ( adaptation of the Kings quote from Albert Einstein)
gotompoes OP Regular Member • Posts: 465
Good question.
Will do a comparison and report back.
You are quite right.
A lovely lens and an excellent match with the K5. The build quality matches the quality of the K5 and the range is very usefull. I did have the 16-45 mm lens but did not use it very often. Despite the good quality i did find its range somewhat limiting.
Sold this lens recently.
Most of my pictures exceed the 50 mm range hence my love relationship with the fantastic 50-135 mm lens.
I can only recommend the 18-135 mm lens.
Untill now i always took 2 camera's with me. The Pentax k7 with the 50-135 mm lens and Leica Dlux 4 for the range below 50 mm. For the longer range i use the 50-300 mm.
This lens was a surprise to me, low price combined with an amazing quality.
I do have a 31mm ltd and a 77 mm ltd. The 31mm did disappoint me but i love the 77 mm. I consider to sell the 31mm and use the funds for a 60-250 mm lens
Following your question i did a comparison between the 18-135 mm lens and the 55-300 mm lens.
My observation are as follows:
at 135 mm:
  • the 18-135 performs slightly better at 5.6 and 8.0
  • the 55-300 performs slightly better at 11.0
at 85 mm
  • the 18-135 is slightly ahead at 5.6, 8.0 and 11.0
at 55mm
  • same as at 85 mm
The iq differences are small. My copy of the 55-300 is really very good and the 18-135 is marginally ahead of the 55-300.
This again proofs that the 18-135 to be a very usefull lens with the right balance between convenience and image quality
My solution is:
for convenience - walk around:
Pentax 18-135 plus Pentax 55-300
for best iq
  • Pentax 50-135
  • Pentax 31 mm
  • Pentax 77 mm
These are the lenses i own and i am aware that for the best iq i have no solution for the wide angle range.
ozdean
Thanks for that comparison Goto, if its as good as the 55-300 has rounded aperture blades, light & weather sealed I can't see you can go wrong - fast focus too I hear.
Zooms allow you to get the shot and if its something really special you can always mount a * or prime.
Irek J Senior Member • Posts: 2,762
Yes, but how about the 18-55 WR and 50-200 WR? Slightly cheaper I suppose...
The 18-135 does look good as a one lens solution in that range, for the money and goodies you get with it.
olynik969 Senior Member • Posts: 1,436
Good comments..
Not sure it would be a reasonable expectation for it to equal the 50-135 f/2.8. However, compared to other similar range offerings it has some very attractive features (at least IMHO on paper - don't have one yet).
First: I "think" it is the only WR zoom of this broad a range (FOV range) out there regardless of the manufacturer.
Second: Combined w/the WR K200, K10/20 or K-5/-7 that is a very very attractive feature set/kit!
Third = Price: I'm not sure that given the WR (and no one else offering that) the price should be considered too high. I think we would all "like it to be" cheaper... :-); however, in reality the WR feature I believe justifies the additional expense.
So - given the "good" IQ, I see it as a total winner! Again, thanks for the comments!
Nik-Nik
 olynik969's gear list:olynik969's gear list
Olympus E-M1
Raghu R Senior Member • Posts: 1,109
Yes there is 1 solution for wideangle range that is Sigma 8-16 f 4.5-5.6 the best IQ
in this class.
R.Raghu
gotompoes wrote:
My solution is:
for best iq
  • Pentax 50-135
  • Pentax 31 mm
  • Pentax 77 mm
'The Photographer reveals the light;the light reveals the picture'--C.Rajagopal.
A picture should communicate with our heart.
Efzee-50 & Foojee F 31fd---Polaroid X-530
 Raghu R's gear list:Raghu R's gear list
Pentax K-x Canon EF 50mm f/1.2L USM Canon EF 85mm f/1.2L II USM Pentax smc DA* 55mm F1.4 SDM Pentax smc FA 31mm F1.8 AL Limited +8 more
Bart Roskam Regular Member • Posts: 460
Re: Good comments..
I thought a thread about a lens without any pictures would not do. Bought this lens a week back and had the time two days ago to go out and take some pictures. It is about what I expected in image quality. Build quality is way beyond what I had imagined.
All shot with K10D, converted in LR 3.3, no pp done except for one horizontal flip.
audiobomber
audiobomber Veteran Member • Posts: 5,299
Re: Good comments..
That could be good, bad or indifferent. Could you please explain?
Dan
 audiobomber's gear list:audiobomber's gear list
Pentax K-3 Sony a6000 Pentax K20D Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 +17 more
Isn't the DA 12-24mm pretty good as well?
Johan - Swe
http://joj.smugmug.com
http://joj.smugmug.com/Lenses
From what I have read so far, the 18-135 seems to be a little bit above the 18-55 and 50-200 wrt IQ, more like DA55-300. But let's wait for some additional tests before drawing too far reaching conclusions.
Re: Good comments..
Dan
Before the 18-135 I had a DA 16-45/f4. Since quite some time has passed since they designed this lens, I expected lens quality in general to have improved. Furthermore, the 18-135 costs about 2 times as much as the 16-45. Thus, I hoped (expected) that the 18-135 (7.5x zoom) would be comparable to the 16-45 (3x zoom) quality wise. I hoped that the pro's of the steeper price and newer design would make up for the con of the bigger zoom range. This is what I expected and this is what I found to be true, looking at the pictures I took (I did not shoot any test charts). I did not expect an improvement over my 16-45 because there is just so much you can expect from a 7.5x zoom lens.
The build quality of the 18-135 is much ahead of my 16-45 which had a wobbly inner barrel. The 18-135 feels very solid and the focusing feels faster (on a K10D). Furthermore, I like the hood of the 18-135 more than that of the 16-45. The 18-135's hood fits neatly around the lens when reversed where the 16-45's hood was quite a bit bigger and bulky.
audiobomber
Ahead in what way? MTF resolution? It's hard to believe the 50-135 would be better for vignetting and PF. What about colour and contrast? Most of the 18-135mm photos I've seen so far seem to have a weird bluish colour cast, but I don't know if it's the way the lens produces colour or the K-5, or the combination.
Dan
audiobomber
Re: Good comments..
Thanks Bert. My 16-45 is very good, I rate it just above my 55-300mm. If the 18-135 can match the 16-45, I will most definitely get one. I no longer use the 18-250 because it was too much of a compromise in IQ compared to the 16-45 + 55-300.
Have you noticed anything different about the colour rendition of the 18-135 vs 16-45?
Dan
