How to format memory card on D7000?
Started Dec 25, 2010 | Discussions
JDalton
Regular MemberPosts: 110
Dec 25, 2010
The manual says hold down the play and trash buttons (on the top left of the back control panel) until Format appears on the LCD display or viewfinder. That doesnt seem to work for me. Anything I'm missing?
Thanks.
Formerly MrTeatime on here
Polyglot92
Senior MemberPosts: 1,467
Re: How to format memory card on D7000?
In reply to JDalton, Dec 25, 2010
Thanks.
I don't have a D7000 but I'm sure if the manual procedure doesn't work for you you can use a menu item.
D5000 - Nikkor AF-S DX 18-105mm F/3.5-5.6G ED VR - Nikkor AF-S 50mm f/1.4 G
Canon PowerShot S3
Dave Courtenay
Contributing MemberPosts: 713Gear list
In reply to Polyglot92, Dec 25, 2010
Easiest way is to press Menu the go to the set up menu-spanner sign and there it will say format memory card
http://www.wildlifeinfocus.com
Facebook-David Courtenay Photography (www.wildlifeinfocus.com)
 Dave Courtenay's gear list:Dave Courtenay's gear list
Nikon D800 Nikon D800E Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 600mm f/4G ED VR +9 more
JDalton
JDalton OP
In reply to Dave Courtenay, Dec 25, 2010
Yep, done it through the menu. Thanks.
Richard Southworth
Regular MemberPosts: 407Gear list
It's the trash and metering buttons (both have a red format nearby), and the buttons have to be pushed a second time to invoke the format. With two cards it's easier to do from the menu.
Richard Southworth
 Richard Southworth's gear list:Richard Southworth's gear list
Olympus Stylus 1 Panasonic Lumix DMC-ZS50
mandp
Regular MemberPosts: 109
In reply to Richard Southworth, Dec 25, 2010
+1. Need to press the two buttons a second time while the LCD is showing 'For', then it works a dream... must be safety feature to avoid accidental re-formatting.
