Does the GF1 work with a Pana 14-42mm g Vario
Started Dec 15, 2010 | Discussions
Peter1976
Peter1976 Forum Member • Posts: 82
Dear all,
I am considering to buy a GF1 and found some offers on Ebay, selling the body with a Panasonic G Vario 14-42mm O.I.S. instead of the KIT lens 14-45.
I already found out some differences between the two lenses (e.g. the 14-42 seems to have a plastic instead of metal bayonet (which I wouldn't care for, as I wouldn't switch lenses that often).
The 14-42 doesn't have a O.I.S. on/off switch on it, is that a problem?
and: does the lens fit the GF1 good? The 14-42 is the kit lens for the G- not the GF-series, as far as I can see. And divers tests show that image quality is not that much of a difference.
The offers with 14-42mm are all cheaper than with the 14-45mm...
Many thanks for your help
Best
Peter
Winston Loo
Winston Loo Contributing Member • Posts: 681
Re: Does the GF1 work with a Pana 14-42mm g Vario
HI Peter
The 14-45 was the first m4/3 kit lens Panasonic manufactured. Its typically found as the kit lens for G1, GF1 . Since the G2 was launched, they replaced that with the cheaper (and some say not as good IQlens) the 14-42.
THe 14-42 has OIS built in. Just that its not like the 14-45 where there's a swich on the lens. The 14-42's IS is activated from the camera's setup menu.
Since this 14-42 is a native m4/3 lens by Panasonic, it works fine on the GF-1. Not sure why you would want to use this rather than the 14-45 though as most reviews (including this site) says that the 14-45 is better..
check out the G2 review where they talk a bit more on this lens.
http://www.dpreview.com/reviews/PanasonicDMCG2/
 Winston Loo's gear list:Winston Loo's gear list
Panasonic Lumix DMC-ZR3 Olympus PEN E-PL5 Panasonic Lumix DMC-GH3 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS +6 more
Peter1976
Peter1976 OP Forum Member • Posts: 82
Winston Loo wrote:
HI Peter
Hi Winston,
thank you for the quick answer. Maybe I have to look a bit deeper in the lens comparison, I just found one German review saying that the difference is minimal.
There is a price difference of about 50€ (which is approx. 65$) so it seemed logical to take the 14-42 if it was almost as good as the 14-45.
But I will check the lens reviews a bit better...
Thank you, best
Peter
Peter1976
I just see that the upcoming GF2 will come with the 14-42mm... is that the same kit-lens as with the G-series? Seems so...
Winston Loo
Yep.. seems so. Panasonic only has the 2 kit lens.
I have a G2 with the 14-42. Never had a chance to try the 14-45 and I shoot for fun and family moments. So far no issues with the 14-42 except some softness when its wide end 28mm (35mm equvalent). Totally acceptable to me.
I guess if its $65 difference between almost 2 equivalent lens, then maybe you should try it out at a retailer? Again.. reviews are reviews. I'm not a pixel peeper so I'm contented with my 14-42.
Winston Loo
I did a fast search.. actually most of the Panny G and Oly Pen discussions (i.e. m4/3) are all at the Micro Four Thirds forum.. not so much this Panasonic forum.. you might want to drop by for a visit.. I frequent both forums because I have 2 Panasonic P&S and a G2 m4/3 camera.
There was a forum thread sometime ago on this exact same question.. you might want to check this out :
http://forums.dpreview.com/forums/readflat.asp?forum=1041&message=36967227&changemode=1
Happy Shooting.. whichever lens you buy !
Peter1976
Thank you very much Winston!!!
All the best
Peter
