LX5 Processing
Started Oct 27, 2010 | Discussions
tinpusher
tinpusher Senior Member • Posts: 1,345
LX5 Processing
I'm not sure what mode I was in when I took this but given an ISO of 400 I think it may have been IA that went to Landscape mode;just a guess on my part
Other shots taken at the time are fine so what do you think went on here?
This is my second LX5.
 tinpusher's gear list:tinpusher's gear list
Sony RX100 Sigma DP3 Merrill Nikon D3 Sony Alpha 7 Olympus OM-D E-M10
Gregm61
Gregm61 Forum Pro • Posts: 14,469
Re: LX5 Processing
What are you thinking is wrong with the image?
From the direction of the light, it looks like a backlit scene and the camera opened up the shadows, maybe a little too much, which gives the file a flatter look....at least, it looks like that on the LCD I am viewing it on here at the office. I could see IA doing that. Had it been shot in regular program mode, shadows would have no doubt been darker, giving an overall contrastier look.
 Gregm61's gear list:Gregm61's gear list
Leica M9 Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus E-M1 Leica M (Typ 262) +21 more
tinpusher
tinpusher OP Senior Member • Posts: 1,345
Re: LX5 Processing
It's the processing of the bushes that I find unacceptable.
Was it in focus?
Elements in front and beyond the bushes seem OK but the bushes are just smeared.
I don't know the answer but I do know that the LX5 can struggle to handle fine detailed objects at a distance.
depscribe
depscribe Senior Member • Posts: 1,215
Re: LX5 Processing
there's nothing wrong with the picture. the slight fuzziness of the bushes near the water is due to the little dab of fog rising from the water, caught by the back light. this happens. it would be the case even if you'd shot it with a 4x5 instead of an lx5.
depscribe
some pictures: http://www.flickr.com/photos/depscribe/collections/
 depscribe's gear list:depscribe's gear list
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X30 Nikon D7100 Fujifilm X-E2 +8 more
DezM
DezM Forum Pro • Posts: 34,238
Re: LX5 Processing
The scene appears bright, so ISO 400 was unnecessary. The "film" was too sensitive to the available light, hence the overexposed, harsh exposure. ISO 80 or 100 would've sufficed.
EDIT: I just noticed the fuzziness of the distant trees. Not sure what went on there but I've read others had some issues with similar experiences. They suspected the mode of OIS.
Dez
http://photos.dezmix.com
Detail Man
Detail Man Forum Pro • Posts: 16,400
Re: LX5 Processing - Intelligent Resolution Effects?
"IA" mode uses "Intelligent Resolution", right ?
LUMIX's new Intelligent Resolution Technology automatically identifies parts with outlines, detailed texture areas and soft gradation areas, and optimizes the edge emphasis on the outlines and detailed texture areas while using the Venus Engine noise reduction process to make the soft gradation areas smoother .
http://www.panasonic.asia/lumix/philippines/features/ir_technology/index.html
This is a processing technology used in newer Panasonic Lumix cameras which takes a more sophisticated approach to sharpening and noise reduction by separating the image into three types of area: outlines, detailed texture areas and soft gradations. Outlines are sharpened, detailed texture areas are moderately accentuated and soft gradation areas (like skies, for example), are smoothed rather than sharpened .
By separating these different types of detail and processing them differently, Panasonic hopes to achieve good detail without increasing image noise. Conversely, ‘Intelligent Resolution’ should provide lower noise at high ISOs without compromising on detail, particularly textured detail, which is usually the first casualty.
It’s not yet clear whether Intelligent Resolution offers a better noise/definition compromise than other processing systems, but it’s encouraging that manufacturers realize the issue needs addressing.
http://www.photo-facts.com/WP/archives/10500
Can't access the Original JPG with Exif and maker Notes meta-data in your gallery (you can change the permissions in your DPR Profile "Edit Profile"). With the Original available one could have a look at whether:
The detail of the foliage at such a distance from the camera may well be pushing a "pixel-ation" limit of the 10 Mpixel image-sensor. It's not unthinkable that (as a result) the "Intelligent Resolution" algorithm is interpreting these areas as "soft gradation areas", thus performing no sharpening in those areas. The amount of NR applied when "IR" (may, possibly) be increased (relative to the PASM NR). Thus, "no sharpening" (in such a case) in such areas may have more of an impact than PASM operation.
Your previous image of foliage seemed (to my eyes) to have some similar effects.
I have yet to see any of the suspected to be "uncharacteristically soft in certain places" LX5 images posted appear (to me) to have been caused by the OIS system.
To evaluate the basic optical integrity of the camera, (I, personally) would stay well away from "IA" mode . To allow the camera to "heap" robot-brains on top of the (already complex enough) window-dressing of the in-camera JPG engine makes for a soup of dubious variables.
Shoot in RW2 to evaluate the performance of the lens-system and image-sensor. Add "bells and whistles" (if at all possible) one at a time . Your answers can then be delivered by simple deduction.
Detail Man
I tried down-scaling the exposure-level in your (Large version) image, but matters do not improve.
The Shutter-Time = 1/640 Seconds.
I think that it is more than "mist" and "back-lighting". The trees (along the edge of the body of water) look really, really bad (to me).
Noticed that in a post on another thread that you stated that you were liking using "Intelligent Resolution" at the highest setting as a shooting technique.
My theory is that this image (as well as your previously posted image of the foliage in a previous thread) demonstrate how poorly the results can come out with foliage (and any other very finely detailed subjects) at a distance when using "IR" ...
Do you have any examples of performance this poor when you are sure that "IR" is completely disabled?
If it is the "IR" causing this I (personally) would never use it again (particularly with landscape shots involving fine foliage detail) ...
tinpusher
Re: LX5 Processing
No fog
tinpusher
Re: LX5 Processing
I believe the camera chose this ISO I certainly didn't
tinpusher
Thanks to everyone that commented.
I wanted the original with exif to be available so I must check the Gallery settings.
That is the worst picture I've had but smearing is visible on some shots where part of a texture ( brickwork ) is smudged and part remains sharp. Intelligent Resolution doesn't seem so good now.
Other shots taken at the same time are perfect
MrClick
MrClick Contributing Member • Posts: 946
Detail Man is correct. The others are wrong.
It is Intelligent Resolution causing this effect of smearing of the bushes which are in the less contrasty shadow areas i.e. where sunlight is absent.
Also, I'd advise you to shoot in RAW to obtain the highest degree of fine-detail capture. Else, if shooting JPEG, then choose the finest setting.
Switch off extended optical zoom (and digital zoom) too.
Switch off Intelligent Exposure or set it too Low if you do not PP your images.
Choose Standard Film and set the NR to -2. In fact, if you post process your images, you might as well set the other three settings (Contrast, Sharpness and Saturation) to -2 as well, else not.
With these settings, you will see that this smearing phenomenon is at its minimal.
Hope this helps.
Click
tinpusher
Actually I think I know how to overcome the problem.
Intelligent Resolution isn't the cause ; it's partly the basic noise reduction processing so setting file modes to NR -2 helps.
Setting Intelligent Resolution to High can help .. not what I'd expected.
Overexposure seems to be the key to what has happened together with the softness at the 90mm end of the lens.
Actually , the smearing caused by NR appears on some RAW files so there's quite a bit of processing going on there too!
By dropping the NR to -2 my results are much better and I'm going to keep the camera for now.
Many thanks for everyone's comments ; they've all been helpful.
MrClick
I'd also like to add that Intelligent Resolution basically is a combination of NR and sharpening... low contrast areas have more NR applied to them. high contrast edges edges get sharpened a bit too. So imagery processed with the Intelligent Resolution look a big cleaner in low contrast areas and sharper overall.
Glad to know that setting the NR to -2 helped.
Click
Detail Man
Note how little difference the LX3 NR = -2 setting makes compared to NR = 0:
http://www.dpreview.com/reviews/panasonicdmclx3/page8.asp
I wouldn't expect the LX5 to be much (if any) different.
Here is the Histogram of the entire image. It's getting "up there" in total exposure - but the amount of color-channel "clipping" is slight:
Here is a crop of the trees from the area just above and to the right of the fellow on the sailboard. Note that the Blue channel peaks at a level of 70 out of 255. That's a full 1.87 EV below the maximum level. Not what I would call "overexposed":
I have not seen any indication in the LX5 RW2s that have been posted that there is (any) "raw"-level noise-reduction going on. If you see smearing at that level you should look to the camera lens-system itself - and/or the "raw" processor itself. Silkypix is known to have limited spatial frequency resolution (even when the NR tools are not utilized at all) as compared to Lightroom ...
Detail Man
As I stated previously, the fine-detail of the foliage in the trees (may) be exceeding the ability of the 10 Mpixel image-sensor to resolve that level of detail.
The resultant "smearing" seen in this particular image may due to pixel-lation effects. What the "Intelligent Resolution" system may have done as a result of the loss of detail (and the corresponding loss of much of any "contrast" in such smeared details) is the question.
I would (if possible) take the same shot at the same place from the same distance under similar lighting conditions (with "IR" disabled) before drawing a conclusion that "IR" is not (at least part of) the problem - or assuming that "IR" has (in the case of this image) improved matters.
It just may be that RW2 is your best approach in such cases of highly detailed foliage at a distance. The best that (I see) the LX5 (in JPG mode) doing in similar images is providing an illusion of detail (mostly as a result of "sharpening"). Viewing at higher magnifications reveals the "smoke and mirrors" involved in that illusion (and not well-defined detail at such distances from the camera).
Trevor G
Trevor G Veteran Member • Posts: 6,540
Partly correct.
There have been some weird answers to this query from folk who obviously either did not view the picture at a larger magnification, or don't realise that noise always affects the darker parts of the image first.
It is very obvious that the darker parts only of the image (the foliage in shade) have had excessive NR applied, which has smoothed away most of the detail. Ugly.
Turning NR to minimum is correct as the first solution.
It's believable if some of the explanation provided by DM is correct.
The parts of the image which were blurred were not over-exposed. Over-exposure was very minor in this case, 1/3EV, and actually helps to reduce noise in shadows, because there is less area in shadow.
The "softness at the 90mm end of the lens" (if it exists) has absolutely nothing to do with the shadow blurring. The blurring is a very obvious, NR over- processing effect.
Any lens related issue affects both highlights and lowlights equally.
That is quite possible, too.
aerorail
aerorail Contributing Member • Posts: 757
Re: LX5 Processing
looks like ia to me
i wouldn't use that and stick to 'p' or other settings
set iso lower or lower iso auto setting
perhaps change to single point focus instead of multi
take a couple shots exposing for water then for sky etc
its digital takes lots and throw out what you dont like and/or pp different exposures
  • Exposure Time (1 / Shutter Speed) = 10/6400 second ===> 1/640 second ===> 0.00156 second
  • Lens F-Number / F-Stop = 40/10 ===> ƒ 4
  • ISO Speed Ratings = 400
  • Original Date/Time = 2010:10:25 15:11:02
  • Digitization Date/Time = 2010:10:25 15:11:02
  • Exposure Bias (EV) = 0/100 ===> 0
  • Max Aperture Value (APEX) = 20/10 ===> 2
Max Aperture = ƒ 2
  • Metering Mode = pattern / multi-segment (5)
  • Light Source / White Balance = unknown (0)
  • Flash = Flash did not fire, compulsory flash mode
  • Focal Length = 192/10 mm ===> 19.2 mm
  • Custom Rendered = normal process (0)
  • Exposure Mode = auto exposure (0)
  • White Balance = auto (0)
 aerorail's gear list:aerorail's gear list
Sony Cyber-shot DSC-RX100 III
Faisalee
Faisalee Contributing Member • Posts: 561
Seems like Extended ZOOM!
The quality seems to be a result of extended ZOOM... but I may be wrong! I never use JPG, almost all the time RAW
Shot in RAW f5.6 60s exposire, I will post some bushes later for you to check
Faisal.
Pentax Digital User
Nikon Digital User
http://www.flickr.com/photos/faisalee/
