Workaround for Sigma lens on A33 and A55
Started Sep 11, 2010 | Discussions
SrAT
Junior MemberPosts: 40
Sep 11, 2010
Imaging Resource published the suggestion to engage the DOF preview several times to reestablish aperture communication with the camera when the Sigma lens loses that communication. I found another workaround for my Sigma lens on the A33 that I-R didn't mention.
If you slide the body AF/MF switch to MF. mount the Sigma lens, and then slide the body switch to AF the Sigma lens stops down and autofocuses properly. With my fast and old Sigma 75-200mm the lens works properly on an A700, but the lens rarely initializes the aperture properly if I mount it on the A33 with the body AF switch in AF.
As I-R pointed out, when the aperture does not engage the aperture remains stopped down, and in my 5-pin lens you can't AF and the aperture is reported incorrectly. Apparently with the current 8-pin interface the Sigma behaves a little differently. When I slide the body switch to MF before mounting the Sigma, then switch to AF the Sigma lens initializes aperture and focus properly and it has continued to work until I turn off the A33.
I am going to try the DOF stop-down trick I-R used to see if that reestablishes communication with my Sigma lens as well. With my Sigma lens once I have aperture cmmunication everything works as it should and continues to work as it should - it doesn't lose the communication once established.
This in fact may be a Sigma mechanical problem with their A-mount copy and not a chip issue. If so Sigma is being disingenuous in saying they can't fix older lenses. They probably just don't want that expense. OR perhaps it is a combination of a mechanical issue and the lens firmware chip.
At least there are apparently at least two ways to workaround the issue until we have a real solution from Sigma.
Sigma was already at the bottom of my list for third-party lenses after my Canon experiences. However, Sigma does have some unique lenses and I reluctantly bought them when there was nothing else from Tamron or Tokina. The Sigma experience with Minolta/Sony had been better, and unless they were film era Sigma for Minolta the Sigmas have been fine (I have a Mint condition super tiny 60-200mm push-pull Sigma from the film era that no one will rechip, so its a paperweight). However, with this latest A33/A55 incompatibility pointing toward a Sigma inability to even reliably copy the mechanical parts of the A-Mount, I probably have bought my last Sigma.
Of couese the problems will make the Sigma for Sony prices drop to the point where a fast f/2.8 is dirt cheap and I will probaly be tempted to grab a bargain and take the risk. At least I know it's my fault if I do decide to take the gamble.
furjaw
Regular MemberPosts: 189
Re: Workaround for Sigma lens on A33 and A55
In reply to SrAT, Sep 12, 2010
I ordered a Sigma 18-250 to use with the A33 that I plan to buy.
I will only have the one lens, so it will never be removed.
If I put the lens in Manual Focus and mount it,
will it continue to work properly after the camera is turned off?
brendon1000
Regular MemberPosts: 281Gear list
In reply to furjaw, Sep 13, 2010
Thanks for the tips !
I stay in India and I doubt the local service centre will help as they deal with only Canon and Nikon mount lenses.
And I have two Sigma lenses to worry about.
 brendon1000's gear list:brendon1000's gear list
Sony SLT-A55 Sony SLT-A37 Sony Alpha 7 Sony Alpha 7 II Sony DT 16-105mm F3.5-5.6 +9 more
RenatoXSR
New MemberPosts: 1
In reply to SrAT, Dec 11, 2010
SrAT,
Does your fix work without removing the lens? I mean, turn off camera, switch to MF, turn on camera, switch to AF.
Thanks.
PS: I have some sigma lenses and I plan to buy the A33 and a 18-250.
PC Wheeler
Forum ProPosts: 15,079Gear list
In reply to RenatoXSR, Dec 11, 2010
Your new Sigma lens is likely to be compatible. The one I received earlier this month is compatible with SLTs and says so on the box.
Phil
Canon 7D, S90; Sony A55; Panasonic ZS7
http://www.pbase.com/phil_wheeler
 PC Wheeler's gear list:PC Wheeler's gear list
Canon PowerShot ELPH 330 HS Canon PowerShot SX50 HS Panasonic Lumix DMC-LF1 Panasonic Lumix DMC-FZ1000 Sony a6000 +7 more
Little Pooter
Contributing MemberPosts: 644
In reply to furjaw, Dec 11, 2010
When you receive your lens, look on the box for a sticker that says it is compatible with the SLT A55/A33. If it has the sticker then it has been updated and will work like any other lens, a great lens by the way. If it doesn't have the sticker then it likely hasn't had the update and you will need to send it in to Sigma for a free upgrade. The "workarounds" discussed in this thread refer to older discontinued lenses that Sigma will not update.
Sony A55, A500, HDR-SR12, T100
Lenses: Sigma18250 OS HSM, Maxxum 50mm 1.7, SAM 18-55mm, SAL70400G, Lensbaby Composer
ConfuciusTse
Regular MemberPosts: 289
In reply to Little Pooter, Dec 12, 2010
I triggered the error by taking a couple quick shots wide open, close down hard a couple shots, then back again. After a couple cycles like this the lens got stuck stopped down. I "think" it's simply the aperture lever size is just slightly "off" and doesn't physically catch. It took my local Sigma service center 20 minutes to fix two lenses.
BUT I do wish Sigma would extend the fix to all their lenses, new and old. If it really is a quick and simple fix (vs manufacturing a bunch of new chips for each lens type), then they should "do the right thing" and support the customers who support them. Otherwise there will always be a cloud over every Sigma purchasing decision which would permanently put them beyond other third parties such as Tamron and Tokina for similar products.
