1ds mk II maximum memory card?
Started Sep 2, 2010 | Discussions
Knackerman Senior Member • Posts: 1,448
Hi
I own two 4 gb CF cards that I use with my 1ds mk II, but now I have an assignment to shoot a cat-walk event and I am afraid of running out of room during the event.
In other words I need to buy a bigger card (or two) to supplement what I've already use, but I haven't really bought any cards for it since I bought the camera.
Technology moves on, so I am unsure on what I can use in my camera these days.
Any tips?
Regards
K
 Knackerman's gear list:Knackerman's gear list
Canon EOS 5D Mark III Canon EOS-1Ds Mark II Canon EF 70-200mm f/2.8L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 17-40mm f/4.0L USM +6 more
Charles Scheffold Regular Member • Posts: 218
Re: 1ds mk II maximum memory card?
I'm fairly certain you won't have any problems with larger memory cards, as long as you have the latest firmware (1.1.6). Canon released an update some time last year that allows both larger CF and SD cards for the 1Ds Mark II:
http://www.canon.co.jp/imaging/eos1dsm2/eos1dsmk2_firmware-e.html
My suggestion - if possible, borrow one from a friend and try it out before you buy. In my experience, I've had the best of luck with 4GB and 8GB cards. Anything bigger and you are kind of "putting all of your eggs in one basket" if you know what I mean. Just my opinion, but in any case there shouldn't be any major compatibility issues.
thanks
Charles
Knackerman OP Senior Member • Posts: 1,448
Ah ok thank you, I'll check my firmware when I get home.
I use Sandisk Extreme (I think i use extreme II, need to check).
Was thinking about buying one or two 8 gb cards (I use the 4 gb's exactly to avoid having all the photos on one card and under normal circumstances it works fine).
Do you know if there may be problems using the extreme III and extreme IV etc versions (As I understand, this is related to writing speed, so in my head, this should normally not cause an issue....maybe ).
Thanks for the informative answer, I'll check the firmware when I get home for sure.
Regards
K
peterbosox New Member • Posts: 17
Firmware Question
If you are 2 versions behind the newest firmware, do you have to load both versions of updated firmware? Or just the latest?
Latest version
You load the latest version - no need for the older ones.
Re: Firmware Question
On the page linked above, it states that the latest firmware includes the previous ones, so you only have to flash the camera with the latest version.
Regards
K
I honestly can't keep track of SanDisk's speed designations at this point
There should be no problem using a faster/newer CF card in an older camera. You just won't see the increased speed benefits so it might be a waste of money unless you plan to upgrade the camera soon. For example, if you use a UDMA enabled card in an older camera it will just use the PIO (=slower) modes instead.
AFAIK, all current and proper CF cards are designed to be backwards compatible.
WalterSrChat Senior Member • Posts: 1,289
The 8GB Scandisk Extreme III worked in my 1Ds Mark II.
Walter SR
Regards
K
I am out to take the perfect picture, if it exits!
 WalterSrChat's gear list:WalterSrChat's gear list
Canon EOS-1Ds Mark III Canon EOS-1D X Canon EOS-1D X Mark II Canon EF 8-15mm f/4L Fisheye USM Canon EF 50mm f/1.8 II +4 more
Tom Tran New Member • Posts: 20
I use 8GIG CF cards and 16gig SDHC cards (from different manufacture) on my 1ds mk2 and it work perfect. I update to latest firmware.
Scales USA Veteran Member • Posts: 3,121
I've used 8gb cards on mine, I would not expect any problem with up to 64 gb. 8GB is plenty large for the MK II though.
 Scales USA's gear list:Scales USA's gear list
Canon PowerShot G1 X II
Thank you all
I bought a 8 GB extreme (60 mb/s udma?) card from Sandisk (my other cards from Sandisk has been working flawlessly for 3 years).
Thank you all for the pointers, good to know that the camera isn't totally lost in the computer race just yet.
K
Michael Thomas Mitchell Forum Pro • Posts: 11,042
At least 16GB
I'm using 16 GB Compact Flash and SDHC cards in my 1DsII. Don't know about higher.
I also use a pair of 8GB cards in my 1DIIn.
Both setups provide about 800 or so raw captures. Mine are also setup for backup mode, so that I have two copies of each exposure. My PC reads SDHC much faster than CF, so that's the card I actually use for transfer. The CF is strictly backup.
Knackerman wrote:
Hi
Any tips?
Regards
K
James S Regular Member • Posts: 279
When the firmware for the cameras was updated for larger Compact Flash and sdhc it was supposed to mean that the SDHC limits are imposed and for the CF cards the limit is supposed to be well beyond anything being offered now (some theoretical limit). So you can pick up any size CF card and use it. The speed of the card is really up to your desire to future proof the card and of course if you have a fast card reader the speed of the CF card will help with faster down loads. I use a San Disk firewire 800 card reader and it is very fast so I've stopped having to go for a snack when downloading.
James S
gomcse New Member • Posts: 4
I am unable to use a 64Gig SCT XC card with my EOS 1ds Mk II. Anyone know if there is an actual printed limit? I don't want to go buy a 32gig card if it's not going to work either.
Thanks,
Dave
nelsonal Senior Member • Posts: 2,464
I've never been able to format a 32 GB SD card in a 1DII (which I'd guess is similar). They work after being formatted in another camera. I haven't had issues with 16 GB cards formatting or using though the space left number is usually off. Every 8 GB CF card I've tried works well (format, use, and space remaining). I've never noticed a speed difference between class 4, 6 and 10 cards nor all 15-30mb/s on CF cards. So I usually just buy the cheap, slow ones.
I've heard, but not tested, that SD cards smaller than 2 GB are considerably faster than larger SD cards, but I haven't gotten any to test. It takes quite a while to clear a full buffer with large cards (5x times as long as with any size CF card).
Roonal_Z Contributing Member • Posts: 555
I've formatted Sandisk 32gb CF & SDHC in my 1DMkII with no apparent problem and formatted/used them in my 1DsMkII.
Good Day,
Roonal
I use Sandisk 32GB CF & SDHC in my 1DsMkII with no problem other than the SD slot not being particularly speedy. Never tried a 64GB card.
Regarding speed: From my testing with the cards I have, the slow down is with the SD slot.
Writing 10 RAW 1600 ISO files (time to red light going off):
My 30MB/s SDHC Sandisk 32GB Extreme HD Video is substantially slower than my 15MB/s SDHC Sandisk 16GB Ultra II - approx. 55sec vs approx. 40sec.
My 30Mb/s CF Sandisk Ultra 16GB takes approx. 23sec.
My 60Mb/s CF Sandisk Extreme 32GB gained me only approx. 3sec vs my 30Mb/s CF card.
Good Day,
Roonal
Shlomo Menashe New Member • Posts: 1
Hi There
On the link that you supply
Before downloading the firmware they do ask for the camera serial #
for some reason it don't recognize mine ?
Any Idea what to do ?
Thank you: Shlomo
