Does Minolta 50mm F1.7 Auto Focus work with Sony A55?
Started Aug 29, 2010 | Discussions
mugupo
mugupo Contributing Member • Posts: 621
How does that compare to Sony 50mm F1.8? Used Minolta 50mm 1.7 is like $50 in ebay compare to $150 new one from Sony.
 mugupo's gear list:mugupo's gear list
Canon EOS M Canon EF-M 22mm f/2 STM
zackiedawg
zackiedawg Forum Pro • Posts: 25,513
Yep...
All Minolta Maxxum, or A-mount, lenses work on all Sony DSLRs and the A33 and A55, with full normal autofocus.
The old Minolta lenses don't have modern coatings which are typically applied to digital-developed lenses, but when it comes down to it, most feel the old Minolta lenses can perform every bit as well. Even if some think the Sony 50mm F1.8 is better, I don't think anyone could argue about the Minolta 50mm F1.7 having more 'bang for the buck' - it's hard to beat for the money. I've had one for years, and it's a great little lens. Caution when buying - try to make sure there are no issues with sticking aperture blades or excess oil on the blades, as it can cause optical problems...it doesn't happen often, but if the lens was stored in humid or hot locations, left on car dashboards, or generally abused, it can occur. Or at least buy somewhere with a guarantee and return policy.
 zackiedawg's gear list:zackiedawg's gear list
Sony Alpha DSLR-A580 Sony a6000 Sony Alpha a6300 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +22 more
Tubal
Tubal Contributing Member • Posts: 709
Re: Does Minolta 50mm F1.7 Auto Focus work with Sony A55?
Check this thread you started yesterday. It should tell you.
http://forums.dpreview.com/forums/read.asp?forum=1037&message=36159137
 Tubal's gear list:Tubal's gear list
Sony Alpha DSLR-A100 Sony Alpha DSLR-A700 Sony SLT-A77 Sony 70-200mm F2.8 G Sony DT 18-70mm F3.5-5.6 +10 more
Corkcampbell
Corkcampbell Forum Pro • Posts: 14,880
Instead of starting multiple threads on the same topic, why don't
you just spend some time on dyxum and read the reviews?
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-GH3 Olympus E-M5 II +3 more
balduv
balduv Regular Member • Posts: 128
Re: Yep...
Is the aperture electronically controlled too?
HobbiesAreFun
HobbiesAreFun Senior Member • Posts: 2,457
Re: Yep...
Yes.
A Beginning Amateur Photographer
 HobbiesAreFun's gear list:HobbiesAreFun's gear list
Nikon D800E Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF Sigma 50-500mm F4.5-6.3 DG OS HSM Nikon AF-Nikkor 80-200mm f/2.8D ED Samyang 14mm F2.8 IF ED MC Aspherical +3 more
tbcass
tbcass Forum Pro • Posts: 23,062
Yes it does and very well
I use the Minolta lens on my A55 with great results.
Tom
Look at the picture, not the pixels
http://www.flickr.com/photos/25301400@N00/
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony SLT-A77 Tamron SP AF 90mm F/2.8 Di Macro Sony DT 35mm F1.8 SAM Tamron SP 70-300mm F/4-5.6 Di USD +7 more
tbcass
Yes
Yes it is.
Tom
Gary Baker
Gary Baker Senior Member • Posts: 1,289
Re: Yep...
If you get a good copy of the lens - it is a good buy. So, for $50 - might be worth a look. I happen to have a good copy and use it for low light no flash and some close up flower pictures. I think I paid $60 -65 for mine 3-4 years ago - the going price was a little higher then.
