AF assist on 430 EX II
Started Aug 17, 2010 | Discussions
drif8r Contributing Member • Posts: 533
How do I turn on AF assist on 430 EX II flash mounted on XTi.
The flash fires when required ETTL mode, but never seen the AF assist go on in dark.
Michael Thomas Mitchell Forum Pro • Posts: 11,019
Re: AF assist on 430 EX II
Unless your camera offers some additional functionality not addressed in the flash manual, the AF assist beam is automatic and does turn on or off; it is simply always on.
To check your unit, go into a completely dark room. Let your eyes adjust. Then point the camera towards a BLANK wall and press the shutter halfway. You should see a faint red cross-hatch light pattern. The cross-hatch design is there so as to provide contrast for the AF sensor. If it is working properly, the camera should focus very quickly. If you don't see the RED light pattern, then your unit may be defective.
Lemming51
Lemming51 Forum Pro • Posts: 14,007
XTi C.Fn-5 (p. 104). 430EX II C.Fn-08 (p. 21, 23)
To turn on the AF Assist, set the XTi's C.Fn-5 = 0 or = 2. Page 104 of the XTi manual.
Make sure the 430EX II's own C.Fn-08 is set to 0 (Enable). Pages 21 and 23 of the 430EX II manual.
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm f/1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM +5 more
drif8r OP Contributing Member • Posts: 533
Re: XTi C.Fn-5 (p. 104). 430EX II C.Fn-08 (p. 21, 23)
I changed both settings as you mentioned (Camera was off by default) yet the AF assist does not illuminate in PASM modes, in fact with external flash unit attached lens has trouble focusing in dark, to my surprise AF illuminates just fine in Green and all auto modes.
Lemming51
P.S. AF Assist doesn't work with AI Servo.
The AF mode in Green box and all auto modes other than Sports (running man) is AI Focus or One Shot. In these AF modes, the shutter will not trip until focus is confirmed. So the AF Assist Light is projected, then shuts off at focus confirmation before the shutter opens.
If the AF mode is set for AI Servo, then the AF Assist Light is disabled. AI Servo is continous focus, so the AF Assist Light would be need to be projected continously. And in AI Servo the shutter will trip whenever the user full presses the button, it does not wait for focus confirmation. So if the AF Assist Light was on in AI Servo it would show up in the photos. Thus it's disabled in AI Servo.
It has always been so with EOS cameras, I don't know why there isn't a note to that effect in the manuals for the camera or the speedlite.
Re: P.S. AF Assist doesn't work with AI Servo.
AI servo was the culprit, AF assist works in manual mode with one shot focus; I nearly returned the flash.
Of all flash systems I used, Canon speedlights have the least user friendly interface.
WilbaW
WilbaW Forum Pro • Posts: 10,693
That sounds daft. I wonder why they don't just switch off the AF Assist beam while the shutter is open. I hope there's a very good reason why they don't.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
Noogy
Noogy Senior Member • Posts: 1,482
This is my experience as well, it is just always on. Check your AF settings in the camera, you might have disabled it accidentally.
Noogy
'Photography is my therapy.'
Canon EOS 7D, Canon EOS 400D, Canon D10, Lumix TZ5, Kodak V1253
 Noogy's gear list:Noogy's gear list
Canon EOS 7D Sony Alpha NEX-5 Canon EOS 6D Canon EOS Rebel SL1 Canon EF 20mm f/2.8 USM +10 more
