UK Users - Charging up in the US?
Started Aug 11, 2010 | Discussions
mini2
Regular MemberPosts: 148
Aug 11, 2010
Hi Guys
I've never been to the US before and I'm going next month to LA so I need a bit of advice on what seems like a bit of a dumb question. How do you guys charge up your batteries whilst our are over there? Obviously need an adapter plug for the charging units, but do you need anything else like a power converter?
ItsMeOnly
Regular MemberPosts: 123
Re: UK Users - Charging up in the US?
In reply to mini2, Aug 11, 2010
mini2 wrote:
Hi Guys
If your charger is rated 110-240, you're good to go.
g3vbl
Forum MemberPosts: 59
Most recent chargers, especially for Canon cameras and including 7-Day shop items, are clearly marked 100-240V AC 50/60hz. In which case all you need is the adapter.
mini2
mini2 OP
In reply to g3vbl, Aug 11, 2010
Thank you guys!!! That's helps so much. I will check what my chargers say when I get home
Lawrencew
Veteran MemberPosts: 4,151Gear list
In reply to mini2, Aug 12, 2010
Canon ones are universal
Regards
Lawrence
My Flickr http://www.flickr.com/photos/lozwilkes/
 Lawrencew's gear list:Lawrencew's gear list
Canon EOS 70D Canon EF 70-200mm f/2.8L IS II USM Canon EF-S 18-135mm f/3.5-5.6 IS STM Canon EF-S 10-18mm f/4.5–5.6 IS STM Sigma 150-600mm F5-6.3 | C +1 more
Flying Fish
Veteran MemberPosts: 4,467Gear list
You will need an adapter, because we use those dinky 2-pronged plugs here. Of course, at 110 volts, we don't need the tank-like things you Brits and many other countries with 220 volts use. And as the others said, the charger will work here and there.
FF
 Flying Fish's gear list:Flying Fish's gear list
Canon EOS 7D Canon EOS 550D Canon EOS 6D Canon EOS 7D Mark II Canon EF 400mm f/5.6L USM +3 more
Nerv0usT1ck
Junior MemberPosts: 43Gear list
In reply to Flying Fish, Aug 12, 2010
i could be wrong but the plug that fits into the charger seems pretty standard. if the charger is the same here and abroad, then you could probably find some $10 radio that uses the same plug. ive done this before for other items, and it worked fine. the radio'd likely be easier to find than the plug on it's own, and likely cost the same price.
 Nerv0usT1ck's gear list:Nerv0usT1ck's gear list
Canon EOS 6D Canon EF 85mm f/1.8 USM Canon EF 17-40mm f/4.0L USM Canon EF 24-105mm f/4L IS USM Canon EOS 550D +2 more
