Minolta Elite 5400 II 35mm Film scanner and Windows 7
Started Aug 3, 2010 | Discussions
Robert P Miller
Senior MemberPosts: 1,956
Aug 3, 2010
My XP Pro machine is likely to get an upgrade to Windows 7. However I am concerned that certain devices that are no longer made like my Konica Minolta Elite 5400 II will not run. Anyone know about this?
Best,
Robert
Deleted1929
Forum ProPosts: 13,050
Re: Minolta Elite 5400 II 35mm Film scanner and Windows 7
In reply to Robert P Miller, Aug 3, 2010
Have you tried contacting Konica-Minolta ? They are the most likely to have knowledge of this.
StephenG
Pentax K100D
Fuji S3 Pro
Fuji S9600
Robert P Miller
In reply to Deleted1929, Aug 3, 2010
No, I started here first figuring since Sony bought KM, well, finding where to call may be daunting. Still, it's on the short list and I'll look into doing it soon.
Thanks.
StephenG
Pentax K100D
Fuji S3 Pro
Fuji S9600
Best,
Robert
Lloyd O'Daniel
Regular MemberPosts: 346
In reply to Robert P Miller, Aug 4, 2010
I'm happily using my 5400II with Vuescan (www.hamrick.com) under Win 7 x64. No problems at all. Vuescan has a generic driver that can be installed to run just about every scanner out there. I don't think the KM software or driver will work in x64. The last time I checked, this also takes out Silverfast as it uses the KM driver. This might have changed in recent SF versions.
Frankly, I wish I had all the $$ back that I have soaked into scanner-specific versions of SF in the past. Vuescan's results are very good. My workflow now involves scanning raw to DNG. Then, I can run the scans through ACR or LR just as I would my camera raw files. No special workflow / learning curve just for scanning.
Toermalijn
Forum ProPosts: 13,494Gear list
Don't worry.
If you purchase windows 7 pro or windows 7 ultimate then you have the free windows xp modus. This means you can run programs like they did in xp(pro).
If you can find a windows vista driver for your scanner then you're set. Vista drivers also work in windows 7.
SWo, you have at least 2 options to make sure the scanner will work in windows 7.
here is the link to the latest driver. it is an xp (pro) driver.
http://ca.konicaminolta.com/support/americas/scanners/dimage-scanners/dimage-scanelite_54002/software_drivers/index.html
I am quite convident that the scanner will work if you set the program to xp compatibility in windows 7!!!
it's a 32 bit driver, that will work in windows 7 set to xp compatibility. No need to run in xp modus. ( xp modus needs extra space on the harddrive and 1GB extra memoery to run. So if you can avoid this, all the better. But i am quite convident it will run without problems.
Robert P Miller
In reply to Lloyd O'Daniel, Aug 9, 2010
Thankyou!
Those are comforting words. I like the idea of making them DNGs. I love working with RAW in Silkypix, so it would be great to not have to go with a new learning curve with scanner specific learning curves. I'm sure there may be times fro some scanner specific controls, but I'll try the simpler route first.
I've looked at some silverfast software and even have a demo version of some. But I've yet to use it.
Best,
Robert
Robert P Miller
In reply to Toermalijn, Aug 9, 2010
Thanks! Sounds like Windows 7 Pro should work out for most things I plan on installing then. I'll take the resource hit if I have to just to run some of the programs.
Thankyou for the link to the latest K/M driver for our scanner.
Best,
Robert
Toermalijn wrote:
Don't worry.
