PIX 2015
Tethering to a computer
Started Jul 23, 2010 | Discussions
jfh307
New MemberPosts: 3
Jul 23, 2010
Is there an Alpha model that can be tethered to a laptop in a studio setting to use the monitor while taking a picture as opposed to the LCD or the viewfinder?
steelhead3
Veteran MemberPosts: 5,607Gear list
Re: Tethering to a computer
In reply to jfh307, Jul 23, 2010
The 700, 850 900.
 steelhead3's gear list:steelhead3's gear list
Sony a77 II
zd1
zd1
New MemberPosts: 2
In reply to steelhead3, Aug 13, 2010
Try out those three cameras with Lightroom.
phutyle
Regular MemberPosts: 220Gear list
In reply to jfh307, Aug 13, 2010
I know with the A550, you can tether to a TV with a HDMI cable, in that you can see a live image of the camera's LCD screen on the TV (display information included if you have them set to display on the camera). I assume the same is true for any other model that has a HDMI port. Might be an option if you have one of the newer models, but not the higher end ones that can tether to a PC.
 phutyle's gear list:phutyle's gear list
Sony Alpha NEX-7 Sony Alpha NEX-3 Sony SLT-A77
apaulct
Regular MemberPosts: 124
steelhead3 wrote:
The 700, 850 900.
Yes, those models can tether to a laptop for camera control, image storage, time-lapse shooting, etc. Since they don't have live view, AFAIK, you can't use the laptop to replace the lcd screen or viewfinder for framing a shot as the OP asked.
Allen
nbercasio
Senior MemberPosts: 2,498
In reply to zd1, Aug 13, 2010
A700 tethering using lightroom 3 in Mac OS X?
Mike Fewster
Veteran MemberPosts: 4,669
In reply to nbercasio, Aug 13, 2010
Is it allowable to discuss tehered shooting in this forum?
Mike Fewster
Adelaide Australia
Kilrah
Senior MemberPosts: 2,565Gear list
Adobe says LR3 only supports selected cameras from C&N, no Sony.
 Kilrah's gear list:Kilrah's gear list
Sony SLT-A77 Sony a77 II Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* Tamron SP AF 90mm F/2.8 Di Macro Tamron SP AF 10-24mm F/3.5-4.5 Di II LD Aspherical (IF) +2 more
Archer66
Senior MemberPosts: 2,506
In reply to Kilrah, Aug 14, 2010
You can shoot tethered with LR3 using Sony Remote Control software and it works very well.
lonewolf69
Veteran MemberPosts: 3,358Gear list
@Kilrah - while true that SONY isn't currently support by LR3 for tethered shooting, LR3 might be able to do it in the FUTURE. Presumably, SONY doesn't have a SDK that was readily available to ADOBE, so IF/WHEN that happens... ADOBE should be able to support this via LR3...
In the meanwhile A700/A850/A900 users still have the luxury to use SONY's software and display pics via HDMI as well...
-Alex
From the minds of Minolta to the imagination of Sony, Alpha, like no other.
http://www.pbase.com/lonewolf69
 lonewolf69's gear list:lonewolf69's gear list
Sony Alpha DSLR-A900 Sony Alpha DSLR-A100 Sony Alpha DSLR-A700 Sony SLT-A77 Sony SLT-A99 +2 more
Gionni Dorelli
Senior MemberPosts: 1,057Gear list
In reply to jfh307, Aug 14, 2010
Yes you can with a700/850/900.
But it is indirect tethering, which means you need of using Sony capture software and an hot folder to port it to a software of your liking.
I have worked for 3 years with LR, C1 and tried Aperture and the original Sony software.
The fastest from click to screen is Sony software but the less intuitive and practical about 3 sec on the a900.
Second fastest and best solution, because of the interface is C1. 5 secs.
Third is Aperture with 6/7 seconds and last Lightroom with 15 seconds.
With the a700 you can halve the download times, since the files are smaller.
It depend on your work flow, but you have plenty of options for shooting tethered.
nbercasio
In reply to Mike Fewster, Aug 14, 2010
Yes Mike because if you read the title of the forum and note what kind of cameras we are talking about
Jeff-n-MN
Regular MemberPosts: 345
In reply to Gionni Dorelli, Aug 14, 2010
I use it all the time in LR3 (indirectly)
http://www.jjcrawfordstudios.zenfolio.com
