1080p .mov playback skips in Quicktime
Started Jul 8, 2010 | Discussions
Matt Long
Forum MemberPosts: 88
Jul 8, 2010
Hi all,
I'm sure this question has been asked, but I wanted to know what everyone is using to play back their 1080p .mov files they create with the 5dII? I'm currently using Quicktime, but it skips during playback. Is there anything out that can play this video back smoothly other than dropping it on DVD?
Thanks.
Matt
PawelWoj
Senior MemberPosts: 1,040
Re: 1080p .mov playback skips in Quicktime
In reply to Matt Long, Jul 8, 2010
Its possible your pc is not powerful enough to playback the movies at 1080p. Need to know a little more about your specs, operating system etc.
Matt Long wrote:
Hi all,
Thanks.
Matt
Matt Long
In reply to PawelWoj, Jul 8, 2010
System Information
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs)
Memory: 4gig RAM
(2) TB Hard Drives
Matt
beeroclock
Forum MemberPosts: 89Gear list
Download VLC (its free) plays native H.264 files better than Quicktime usually.
http://www.videolan.org/vlc/download-windows.html
good luck
cheers philip
hotdog321
Forum ProPosts: 14,625Gear list
Power is not the issue
I've got a new Win 7, 64 bit machine, i7-860 processor, 16 gigs of ram (yes, 16) and an ATI 5850 video card with 1 gig of ram and those damn 5DII files are a jittery mess in Quicktime. I have to convert them or use another program.
I hate Quicktime and 5DII video files, but love the results.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 16-35mm f/4L IS USM Canon EF 24-70mm f/2.8L II USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 11-24mm F4L +1 more
bronxbombers
Forum ProPosts: 18,226
never use QT on a PC to play back DSLR videos!
it's dog slow!
worst of the worst slow!
if you have a card with h.264 support (most even semi-recent cards) you don't even need much CPU power at all to play it back if you use a HW support using player
if you have an old video card but fastish CPU there are still non-QT programs that might make it play smoothly
Matt Long wrote:
Hi all,
Thanks.
Matt
bronxbombers
Re: Power is not the issue
In reply to hotdog321, Jul 8, 2010
exactly
use powerdvd to play them on that machine and they will be silky smooth and the cpu might hit 3%
or use one the quicktime alternatives and it CPU might only hit 20-30% on that monster machine and play 100% smoothly
if you simply strip the .mov wrapper and wrap as .mp4 even premiere pro cs4 can play they 100% smoothly on an average CPU
but use quicktime and....
bronxbombers
VLC should do it on that system and if not, if you have a decent graphics card, something like powerdvd or something else that uses hardware accleration will do it for sure, no problem at all
Matt Long wrote:
System Information
Memory: 4gig RAM
(2) TB Hard Drives
Matt
R Valentino
Veteran MemberPosts: 3,269
Another vote for VLC- I have a Mac and QT s^cks for
anything over 720p.
Gene
Andy Blanchard
Senior MemberPosts: 1,019
In reply to bronxbombers, Jul 8, 2010
That's the trick, alright. I don't think Apple's QuickTime on the PC has any kind of support for using the hardware acceleration video available on most graphics cards, or if it does then Apple's implementation sucks.
Personally, I use QuickTime Alternative and don't bother with Apple's official version. That, and the latest versions of the K-Lite Codec Pack (Full and 64bit), are probably all the codecs you'll need to play any video file at all on Windows; no need for DivX, QuickTime, PowerDVD, RealPlayer, or any of the other bloatware...
See here for more info and downloads: http://www.codecguide.com/
Andy
hotdog321
In reply to Andy Blanchard, Jul 8, 2010
I QuickTime Alternative freeware? I think I'll download it and give it a try.
Matt Long
In reply to beeroclock, Jul 8, 2010
I have VLC, and it didn't do any better. It was worse.
Matt
DonHorne
Regular MemberPosts: 174
In reply to Matt Long, Jul 9, 2010
Matt
That was the case for me with a dual core 2.2 Ghz machine with XP Pro and VLC until I came across a DPR post reproduced below:
PCUNITE said:
Download the latest from videolan.org and do the following:
H.264 codecs are pretty CPU intensive and VLC can't use multi-cores to decode it yet.
1. Open Tools/ Preferences
2. Click Show settings = All
3. Go to "Input/Codecs
4. Go to "Other codecs/ FFmpeg" subcategory
5. Set "Skip the loop filter for H.264 decoding" to ALL
6. Restart VLC
His exact instructions were slightly wrong in terms of menus. But it is simple:
1) Download the latest VLC. VERY important.
2) Set "Skip the loop filter for H.264 decoding" to ALL
Once I did this I never dropped a frame again.
OR, try Kplayer or Zoomplayer
I'm not sure if the newer VLC version would require this 'fix' but you could keep it in mind if the video skips.
aka, Grandpaparazzi
Matt Long
In reply to DonHorne, Jul 9, 2010
thanks DonHorne,
Your fix did the trick! I was using the pre-release version of VLC. I downloaded the latest version, and made the changes you suggested and it worked!
Thanks.
Matt
Ludvig
Senior MemberPosts: 1,293Gear list
Why don't you just use the Windows Media Player that comes with Windows 7? Even on my 1.33Ghz laptop I can run 720 mov files fine. It struggles a bit with the 1080 mov files, but a 2+ Ghz desktop runs all mov files like a dream.
Ludvig
 Ludvig's gear list:Ludvig's gear list
Canon PowerShot G9 X Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EOS 760D Canon EF 50mm f/1.2L USM +10 more
David Hull
Veteran MemberPosts: 5,916Gear list
Matt Long wrote:
Hi all,
Make sure your video card is up to snuff. I had the same issue and solved it by getting an nVidia 1GB video card to replace the on-board video that I had with my INTC MB.
Thanks.
Matt
 David Hull's gear list:David Hull's gear list
Canon EOS 50D Canon EOS 5D Mark III
Jen Yates
Senior MemberPosts: 1,405
In reply to Ludvig, Jul 9, 2010
Maybe because Windows Media Player has always been a bit of a dog? Yes it will play a lot of stuff if you have the codecs but it's not just a nice clean simple player.
If you want a lightweight, efficient player then give either Media Player Classic (Probably the best) or VLC a try.
Jim Campbell
Senior MemberPosts: 1,880
Don't see the post you referenced with regard to VLC
Matt
6. Restart VLC
aka, Grandpaparazzi
Ludvig
In reply to Jen Yates, Jul 9, 2010
You don't need any codecs in Windows 7 to run the Canon mov files. After disabeling all download features and disable any Internet connections for the program, I think it runs fine and smooth. It comes with Windows, so at least for me, it's a effortless way to run mov files.
Ludvig
Andy Blanchard
In reply to hotdog321, Jul 9, 2010
Yep. QT Alternative and all of the K-Lite Codec packs are freeware and are updated frequently to include the latest revisions of each included codec (and there are a LOT of those!). I just update QT Alternative and K-Lite every now and again to get the latest features and bug fixes, don't both with DivX, QuickTime, RealPlayer etc. at all and have yet to find a media file I can't play.
Andy
