Video frame rates and NTSC vs PAL - 550D
Started Jun 23, 2010 | Discussions
archiebald Senior Member • Posts: 1,499
Is this assumption correct?
If I record video with the camera set to NTSC it will record at 30 / 60 fps depending on the selected resolution.
If I play back from the camera direct to an NTSC TV it will play back correctly.
However, if I travel to the UK and plug it into a PAL TV, I need to change the camera output to PAL.
Will the camera then try to play back the video at 25 / 50 fps? i.e. 20% too slow. Or will it play back at the recorded frame rate and let the TV sort out how it is displayed?
Of course if I run it through editing software, I can do almost anything with the output. It is just direct output to TV I was thinking about.
archiebald OP Senior Member • Posts: 1,499
Re: Video frame rates and NTSC vs PAL - 550D
Anyone who can answer this?
Narcosynthesis Senior Member • Posts: 1,809
My knowledge of current tv is very limited, but is NTSC/PAL still an issue if you are taking about HD broadcast?
http://www.flickr.com/photos/narcosynthesis
http://www.illaname.deviantart.com
Lawrencew Veteran Member • Posts: 4,369
All modern PAL tvs will accept NTSC input. So just play back NTSC, don't change to PAL.
Regards
Lawrence
My Flickr http://www.flickr.com/photos/lozwilkes/
 Lawrencew's gear list:Lawrencew's gear list
Sony Cyber-shot DSC-RX10 III Canon EOS 70D Canon EF 70-200mm f/2.8L IS II USM Canon EF-S 18-135mm f/3.5-5.6 IS STM Canon EF-S 10-18mm f/4.5–5.6 IS STM +3 more
lacix
lacix Regular Member • Posts: 355
On my PAL Samsung LED TV I played all combination (standards and frame rate) with no problem at all.
But, may not be the same on NTSC TV set,
See the article
http://hometheater.about.com/od/televisionbasics/qt/ntscpalframes.htm
UBL
 lacix's gear list:lacix's gear list
Sony a6000 Panasonic Lumix DMC-GM5 Sony Alpha a6300 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sony E 50mm F1.8 OSS +8 more
