Sony Alpha NEX-5 what types of lenses ?
Started Jun 12, 2010 | Discussions
marcolisi
Regular MemberPosts: 247
Jun 12, 2010
Hello guys, what type of lenses can the nes Sony Alpha NEX-5 mount ?
What about CS lenses , or C lenses or 37mm screw on lenses (fisheye lenses ecc)
Thank you
Chris R-UK
Forum ProPosts: 13,333Gear list
Re: Sony Alpha NEX-5 what types of lenses ?
In reply to marcolisi, Jun 12, 2010
Thank you
I don't know much about this area, but here are some uneducated guesses.
In principle it should be possible to fit many still photography lenses, e.g. film SLR lenses, 35mm rangefinder camera lenses and full frame and APS-C DSLR lenses. These will all need adaptors and the only one so far announced is for Sony A lenses.
Some (all?) of these lenses with adaptors may not autofocus.
Lenses designed for cameras with smaller sensors, including camcorders, CCTV cameras, Four Thirds and Micro Four Thirds lenses probably won't be capable of producing an image circle large enough to cover the NEX-3/5 APS-C sensor and therefore won't be usable.
You can probably get an idea of what may be possible by looking at the adaptors available for Four Thirds cameras, e.g.:
http://www.four-thirds.org/en/microft/lense.html
http://www.photographyblog.com/news/novoflex_micro_fourthirds_adapters/
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
Panasonic Lumix DMC-GH2 Olympus E-M1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +3 more
jiks
Regular MemberPosts: 255
The only lenses the NEX system takes natively are the e-mount lenses. There is an adapter for Alpha lenses, and 2 Sony attachments for the 16mm.
I assume there are current screw-on adapter lenses that would work, and if not there probably will be shortly, but the quality of these will essentially disregard the reason most buy the camera; for easy use and good quality images.
marcolisi
In reply to jiks, Aug 13, 2010
thank you guys, I was thinking in buying something like this :
http://panasonic.net/avc/lumix/systemcamera/gms/lens/g_20.html
even if not from panasonic, I need a sandwich lens very good in low light and with autofocus.
Do you know if :
  • this lens can mount/screw on any step down lens ring to put on it a 37mm lens ?
  • does thislens have image stabilization ?
I do not understand if the NEX-5 comes with image stabilization or not.
I am interested mainly in unsing the NEX-5 for videos....
Thank you again
Chris R-UK
In reply to marcolisi, Aug 13, 2010
Do you know if :
Probably not at the moment. It almost certain won't autofocus.
Sony EX has a similar lens - 16mm f2.8 pancake. Sony also has adaptors for the lens to turn it into an ultrawide lens or a fisheye.
No - it shows that in the specs.
Not in-body, but all the lenses announced so far except the 16mm pancake have in-lens IS..
Thank you again
Chris R
marcolisi
In reply to Chris R-UK, Aug 21, 2010
Thank u so much.
Do u know if the Sony Alpha NEX-5 can mount CS mount lenses ?
thank u
AnandaSim
Forum ProPosts: 13,422Gear list
Re: Proprietary Mount and modern requirements for AF, EXIF, f/no control
In reply to marcolisi, Aug 21, 2010
As previous poster said, Sony NEX cameras use a new E mount and use E mount lenses. You will find that from the old film days, each maker made proprietary mounts. There were a few brands that had common mounts - for example the M42 screw thread for Pentax, Praktica etc...
In the modern age, not only do we have the mount mechanical fitting but also the electronics communications and motors. This makes it hard for other makers to make a lens to
  • autofocus
  • control f/no
  • send data for EXIF
There are two new Interchangeable Mirrorless Body lines - NEX and Micro Four Thirds. Because these cameras are so thin, it is possible to make mechanical adaptor for many alien lenses and fit them onto these bodies. But they cannot control AF, f/no. Since lenses for NEX and Four Thirds are modern lenses, even if you managed to fit each other's lenses, these lenses have no f/no ring on the lens and since the electronics are different, you can't control the f/no.
For alien lenses on NEX, look for third party - Sony would prefer to sell you new lenses so they are not motivated to fit other brands lenses onto the NEX.
Ebay has the following:
http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A3475&rt=nc&_nkw=NEX%20lens%20adaptor&_dmpt=Lens_Accessories&_trksid=p3286.c0.m14.l1513&_pgn=2
marcolisi wrote:
Thank u so much.
thank u
Ananda
http://anandasim.blogspot.com
'There are a whole range of greys and colours - from
the photographer who shoots everything in iA / green
AUTO to the one who shoots Manual Everything. There
is no right or wrong - there are just instances of
individuality and individual choice.'
 AnandaSim's gear list:AnandaSim's gear list
Kodak EasyShare P880 Olympus E-510 Olympus E-620 Panasonic Lumix DMC-G2 Olympus PEN E-PM2 +15 more
marcolisi
In reply to AnandaSim, Aug 21, 2010
hi, thank u for all the info.
I would like to try to mount this lens:
http://www.bhphotovideo.com/c/product/617606-REG/Marshall_V_PL26CS_R_V_PL26CS_R_2_6mm_F2_8_CS.html
in front of the sony NEX-VG10 to add to the surveillance system of my store.
Is it going to be possible ?
tx
AnandaSim
Ask at the Sony NEX forum
I don't have a NEX and even if I have a NEX, the adapter is not made by Sony and is not approved by Sony. These adapters are made by other companies and sold on eBay. That lens is also a third party lens.
So all these a specific questions and if there are any NEX owners who know, they will be in the Sony NEX forum
Ananda
marcolisi
Re: Ask at the Sony NEX forum
do u have the link pls ?
thank you
Leonard Migliore
Forum ProPosts: 11,577Gear list
That lens is for a 1/3" sensor
In reply to marcolisi, Aug 22, 2010
That's a video lens that only covers a 1/3" sensor. It's not going to do a very good job of covering the NEX's APS-C sensor; it'll only cover a 6mm circle in the middle of the sensor.
Why not get a video camera like a Cohu that's designed to take that lens? If it's going to be a surveillance camera, it seems like it will be dedicated to that task so why buy something designed for general photography that won't do the job right?
Leonard Migliore
 Leonard Migliore's gear list:Leonard Migliore's gear list
Canon PowerShot G12 Sony Cyber-shot DSC-RX100 III Nikon D300 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G +8 more
AnandaSim
Re: The link
to the Sony NEX forum is the similar way you got to this Beginner's Forum. Up at the top of this screen is Forums link. Also look at the next post below - he says the lens you say, even if it fits, won't cover the APS-C sensor of the NEX.
Ananda
marcolisi
Re: That lens is for a 1/3" sensor
In reply to Leonard Migliore, Aug 23, 2010
Thank you for the Cohu/surveillance cameras advice, but the thing is that I thought that Digital Full HD camcorders are in quality much much better than surveillance cameras. Is it true ?
I wish I could find a full HD digital surveillance camera that could record to Hard disk like the panasi=onic hs700 or the sony xr550 do.
This is the reason why I was thinking at using a pinhole adapter on a full hd camcorder.
What do u think ?
tx
MartyG
New MemberPosts: 5
In reply to marcolisi, Aug 31, 2010
Have you seen the SONY NEX-10?
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10151&catalogId=10551&langId=-1&productId=8198552921666239819
Same sensor but in a very seriously HD video targeted camera (around $2,000).
My basic understanding is that all of the NEX devices will 'share' things like lenses, microphone systems, viewfinders, etc.
Because of this you can shoot stills with the NEX-10 although it is functionally targeted for video.
Likewise, the NEX-5 can shoot HD video, although it was targeted at still photographers.
Since you mainly are interested in video, I think you should seriously consider this design factor?
