Photography / Masking Tip replacing backgrounds
Started May 12, 2010 | Discussions
Mike Warren Veteran Member • Posts: 8,488
The next time you have a project where you know in advance you are going to replace the background behind the subjects, try this.
Shoot two shots on a tripod. One with the subjects and one with the background only.
In post processing follow these steps:
Layer the background only image over the image with the background and the subjects.
Set the background image only layer (top layer) to difference mode.
Stamp Visible.
Use magic wand (with tolerance set to 2, contiguous off) to click on the Black background.
Type Q to enter Quick Mask to check selection and clean up any bits that should not be part of the selection. (Type Q again to leave Quick Mask Mode)
Duplicate the original image (with the subjects and background) and place on the top layer.
Inverse the Selection.
Add mask to the image layer.
Place new background image under this layer.
Try this procedure with these images.
If you are really, really bored, try extracting the pineapple with your favorite masking program / method. :^)
Let me know if you have any questions.
This is a great technique if you are shooting group shots at a wedding outside and the background is not so great. A little planning will save you lots of time in post.
Mike
 Mike Warren's gear list:Mike Warren's gear list
Nikon Coolpix P7000 Nikon 1 V1 Nikon 1 V3 Nikon D810 Nikon D750 +25 more
Mike Warren OP Veteran Member • Posts: 8,488
Pineapple with new background
Mike
GDB Contributing Member • Posts: 810
Re: Photography / Masking Tip replacing backgrounds
Thanks, Mike. I'll have to try this method out. Now, when do I find the time?
Cheers.
Gary
 GDB's gear list:GDB's gear list
Canon EOS 7D Canon EOS Rebel SL1 Panasonic Lumix DMC-G7 Canon EF-S 15-85mm f/3.5-5.6 IS USM Tokina AT-X Pro 11-16mm f/2.8 DX +3 more
aka_den Regular Member • Posts: 237
Thanks Mike... I was able to use your images and...
...Picture Window Pro 5 with the following workflow:
(1) download the OP's 'backgound_only' and 'pineapple-bkg' jpegs.
(2) click on the 'pineapple-bkg' image, open Composite-AbsoluteDifference, set Overlay = the 'background_only' image, click OK.
Creates an 'AbsoluteDifference' image where the background image areas are black with some isolated black in the main subject image areas.
(3) click on the resulting (2) image, open Mask Tool - BrightnessCurve, form, 'lower-left' Apply Add, OK a BrokenLine curve = [0,0], [10,100], [100,100].
Masks the backgound image areas surrounding the main subject with a slight outline edge gradient.
(4) click on the resulting (3) mask image, open the Mask Tool - BrightnessCurve; form and 'lower-left' Apply Add the default [0,0], [100,100] diagonal curve; and then form, 'lower-left' Apply Subtract, OK a BrokenLine curve [0,100], [50,100], [100,0].
Subtracts the black [0%] to 50% toned outline edge gradient from the mask.
(5) click on the resulting (4) mask image, open the Mask Tool - FloodFill; select large background areas [black] as needed to isolate the main subject [white with gray mix]; Invert; OK.
Eliminates the main subject non-white mask image areas inside its outline.
The resulting (5) mask image is sharp edged and will require further preferential feathering and/or blur when used to Composite-Blend the main subject with its new background...
The resulting (5) mask was feathered -2, then +1 and the new background has a 0 to 100% toned colored gradient with 3.5% guassian HSV-V noise, and a 'drop shadow' was added to the main subject...
I am going to have to try this with actual working images. I can see that (1) the background needs to remain static between the two shots; (2) the camera's auto settings need to be switched to manual, so that the background only shot has the same exposure, focus, and aperature as the first shot; (3) main subject shadowing into the background may need to be taken into account; and (4) a rock steady tripod...
...looking forward to some trials and again Mike... thanks!!!
Cheers.
Gary
You're welcome. Hope you find some time. Send me any extra you don't need.
Mike
Re: Thanks Mike... I was able to use your images and...
Thanks for posting your workflow. I don't use Picture Window Pro, but maybe there are others that do that will find your workflow helpful. Nice result!
I agree with your recommendations setting up the shoot. Probably best to focus and expose based on the subjects first, whether it be people, products or a car, then shoot the background by itself second, with all the same settings and focus.
I think a fun test would be to shoot a pic of a car, then move the car to shoot the scene again. It may be a lot easier to set up a tripod and move the car than it is to extract out a busy background around all the car parts.
Let me know if you try this. I'd like to see your results.
Mike
Tom C Veteran Member • Posts: 5,488
Re: Mike.....
What is Stamp Visible? I have the black background but when I use the magic wand I get white dots that blink on and off.
Stamp Visible.
Mike
Tom
When my bones turn to dust,
and if my CD's didn't rust,
future generations will see my photos
and think that I was nuts.
Re: Mike.....
yeah, that is an important part of the procedure.
Stamp visible makes a layer that is the equivalent of flattening the file and pasting the result on the top layer.
Click on the top layer then use these 4-key strokes:
command-option-shift-e for Mac
control-alt-shift-e for PC
You should end up with a new image layer on the top layer.
Now when you use the magic wand, it will make the selection correctly.
Mike
Stamp Visible.
Mike
Tom
Mike
resident Senior Member • Posts: 1,381
Re: Mike.....
thanks for the tips...will play with it tonight.
never knew about stamp visible either
badui bourizk
http://www.studio102.net
http://www.sicilians.com.au
 resident's gear list:resident's gear list
Nikon D800E Fujifilm X-T1 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +11 more
WineO Veteran Member • Posts: 4,316
Works like a Charm
Thanks Mike it underlines that you use horses for courses with Photoshop. I tried Fluidmask but gave up when I saw the time it would take on this image to get a good selection. I don't think it would be quite as successful with fussy hair extraction but CS5 Refine edge might make it worth trying. I found that if I made a Clipping Mask and pasted the new background into the image I did not need to place it behind the top layer or invert the selection. Saves a few steps but comes to the same thing.
Claude
Re: Works like a Charm
Claude
Thanks for trying the method out Claude. Yes, there are many ways to skin a cat using Photoshop. Your method having the background on the top is good if you want to set the layer mode to darken over a light background for better transition of the edges (like a sky over tree branches). My method having the background below the subject is good for when you want to use layer styles to add a drop shadow or outer edge glow over the background. It just depends on what you planning to do with the image next.
Mike
Re: Mike.....
Thanks Mike, good Technique.
Tom
Re: Mike.....
Not as good but it works with one photo if the background is all one color. I created a background with gray picking the color closes to the hair and it gives you a rough mask. You have to up the tolerance to 22 and subtract the selections where you don't want them. You can then use refine mask to cleanup the rest.
I only spent about 5 minutes on this.
Tom
Re: Mike.....
Tom
Great Job-Looks like you got the concept and technique down!
Mike
vwgn Senior Member • Posts: 2,106
Re: Mike.....
nice trick, i will have to try this out!
joe filer Senior Member • Posts: 2,934
Worked very well, however...
I think the technique worked very well on the supplied images. In the real world, the layers used to create the difference mode black won't be the same (identical) image. This may make it more difficult to get a pure black for selecting the extraction subject. Taking identical background images with the commotion of a wedding might prove to be difficult.
Still appears to be a potentially useful technique and worth practicing.
My 2¢ worth
Joe Filer
Mahomet, IL
http://www.pbase.com/filer
My latest hobby: http://www.pbase.com/filer/longarmquilting
My 60 year still camera history: http://www.pbase.com/filer/image/49099880/original
My wife is proud to participate in the Alzheimer's Quilt Initiative!
http://www.alzquilts.org/
She has met her first $1000 promise for Alzheimer's research and is working on her second $1000. Cheer her on at: http://www.amisimms.com/1000promise.html
 joe filer's gear list:joe filer's gear list
Canon PowerShot G3 Canon EOS 20D Canon EOS 7D Canon EF-S 10-22mm f/3.5-4.5 USM Canon EF-S 18-55mm f/3.5-5.6 +5 more
Ralph Ramirez Veteran Member • Posts: 6,990
Thanks Mike, I tried it using the images you provided. Works very well and quite easy..................Ralph
Stamp Visible.
Mike
Lucy Forum Pro • Posts: 31,032
I think this is what I was looking for....
I started a thread about how to cut out a flower from the background, make it into a layer and then bevel it and overlay the original.
I'll give this method a try.....THANK YOU!
Lucy
E- 510, 40- 150, 14- 54, 70-300 and ZD 35 Macro lenses, and UZI Owner with B-Macro lens
http://www.pbase.com/lucy
FCAS Member #98, Oly Division
'Photography is the art of seeing what others do not.'
