Quantaray 2X teleconverter ?
Started May 6, 2010 | Discussions
stan_pustylnik
Veteran MemberPosts: 3,806Gear list
May 6, 2010
I can get new 2X Quantaray teleconverter made for Maxxum system for $65
Does anyone use it? It should be similar to Sigma 2X for Maxxum.
Make photos that will be interesting to check after many years.
http://stan-pustylnik.smugmug.com
 stan_pustylnik's gear list:stan_pustylnik's gear list
Panasonic Lumix DMC-TS2 Sony Alpha DSLR-A850 Sony SLT-A55 Sony DT 18-55mm F3.5-5.6 SAM Sony 50mm F1.4 +11 more
madecov
Senior MemberPosts: 2,922Gear list
Re: Quantaray 2X teleconverter ?
In reply to stan_pustylnik, May 6, 2010
Just an inexpensive 4 element.
I have a Promaster version. PM me and maybe I can give you some tips and opinions
In god we trust, all others are suspects
 madecov's gear list:madecov's gear list
Nikon 1 V1 Nikon D610 Nikon D7200 +1 more
Schwany
Forum ProPosts: 10,055Gear list
Got one. I have used and still use it for close-ups. Kinda of fun with the 50F/1.7, and 35-70F/4. It's not a great tele-converter for extending a long telephoto, but it works. I took a few shots with it on a Sigma 170-500, and probably a Bigma at one time. Again it was better at near minimum focus than on distant subjects.
Biggest issue is that it doesn't do much for image quality on subjects further than minimum focus distance, exaggerates CA, and eats up two stops.
 Schwany's gear list:Schwany's gear list
Canon EOS-1Ds Mark II Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X Canon EF 24mm f/1.4L II USM +14 more
joel avery
Senior MemberPosts: 1,686Gear list
I found that the image quality took too huge a nose dive and CA was off the charts. Two days of use and I returned it.
Also, be sure to test it on your camera. My understanding is that there are some older ones with too few pins to communicate fully with the Sony's.
 joel avery's gear list:joel avery's gear list
Sony RX100 II Sony Alpha DSLR-A350 Sony Alpha DSLR-A700 Sony SLT-A77 Sony SLT-A99 +6 more
mzn10
Forum MemberPosts: 70
In reply to joel avery, May 7, 2010
its a horrible teleconverter. i bought it for around 30 bucks and still fell ripped off. but on the flip side, i can always knock out the elements and use it as a extension tube.
btw i think ssm does not work with the teleconverter. my 24-70z just keeps hunting when i try to focus.
GaryW
Veteran MemberPosts: 8,020Gear list
In reply to stan_pustylnik, May 7, 2010
I find TCs to be a mixed bag. They do work, but IQ degrades.
What's nice about the Quantaray 2x that I have is that it changes the reported aperture.
With the 2x, my tele lenses that are f5.6 at the end of the range become f11 which means AF doesn't work and you need bright light and higher ISO. Even so, I think it's probably better than resizing without.
Manually focusing seems to be a problem for me, as I have fewer successes than with AF.
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Cyber-shot DSC-HX5 +11 more
