Sekonic L-758D problems with reflected spot operation (?)
Started Apr 20, 2010 | Discussions
Captain Hook
Captain Hook Senior Member • Posts: 1,777
Got an Sekonic L-758D a few weeks ago and I'm trying figure something out about reflected spot operation.
Problem:
If I choose 'ambient' mode (the solar symbol) and try to do a reflected object spot measurement (the Incident/Reflected Spot selector dial is on the 'eye' symbol), I always get a blinking 'Eu' (= Exposure Under) in the display.
It doesn't matter if I select T or F, and even if I set the ISO value on 8000 (!), it still displays 'Eu'.
(no, I didn't forget to remove the cap from the spot lens )
You might think there is something wrong with the sensor, but as soon as I select the 'flash' mode, reflected spot measurement does work!?
When I switch to 'incident' mode (using the lumisphere sensor) everything works like it should be. But I want to use the Sekonic for remote spot measurement.
I'm I doing something wrong? Do I miss something? Help please...
Yes:
-I already tried a new battery.
-I reset the Sekonic to its factory settings
-Even if I use a flashlight to lighten up the spot lens, it still says 'Eu'. But as soon as I switch to 'flash' (streak symbol) mode the Sekonic immediately sees the enormous amount of light.
-Regardless of any other setting I can think of, as soon as I use ambient reflected spot measurement, it always says 'Eu'. Switching to flash measuring mode and/or using the lumisphere sensor, everything works ok (?)
I don't get it anymore...
Captain Hook
Captain Hook OP Senior Member • Posts: 1,777
Re: Sekonic L-758D problems with reflected spot operation (?)
Nobody using ambient reflected spot measurement?
BarrieS
BarrieS Junior Member • Posts: 43
I can only say that mine (L-758DR) works properly in same situation.
Joseph
Captain Hook
Any idea?
Thanks for your response.
Any idea what might be my problem?
BarrieS
Re: Any idea?
When in flash mode, does it give you the ratio between ambient and flash light?
Rogier Bos Regular Member • Posts: 189
Hi,
I have the Sekonic 758DR and am slowly getting to know it. I might be one of those photog's who could have dione with a simpler light meter, but after own a Gossen lightmeter I wanted something more substantial and accurate that I could grow into. Needless to say, I am still trying to grow into it.
I've just tried to replicate your situation, and I get it too. I get out of it though if I just turn the values dial long enough, till I reach a shutter-speed (or aperature if that is what the light meter is set to) that is compatible with regular camera's. In other words: in the reading I just took, at 1/8000s the meter gives me E.U.; ie. no aperature. But now I nturn the dial to 1/4000s, and the meter gives me 0.59 for aperature.
Please excuse me if I have not understood your problem. Otherwise I hope this is helpful.
Rogier
Captain Hook
Re: Any idea?
It displays '100%'.
And, as I said before, in flash mode everything works ok.
Captain Hook
Thanks for the reply.
But it is really mind boggling.
When I set the Sekonic to e.g. 400 ISO, T=1/125, it displays F= Eu when using reflected spot metering. And keeps on display 'Eu' whatever combination of T, F or ISO values I choose...
As soon as I switch to either flash mode and/or ambient metering, it displays a reasonable F value (like F=7)
On the display, do you see an 'm' or 'f/s'?
Your question prompted me to take another look at the manual. This meter is so amazing in the amount of functions my first inclination would be to think I have some made some function selection that is now giving me a response I don't understand.
Captain Hook
Doesn't matter.
Either in minutes or in seconds, it always display E xposure U nder
I don't have a 758Cine, but a 'normal' 758D. So it displays a 'm' or a 's', depending on if I selected minutes or seconds for T.
Captain Hook wrote:
Doesn't matter.
Yeah, I think this is where your problem comes in. Your dial has been turned so far you are in the film-light metering range. I've done this before myself. If you turn your dial far enough the m and/or s should disappear and you will have arrived in the range of normal photography range of aperatures and shutterspeeds.
if I am right, your problem is addressed in the Sekonic manual ( http://www.sekonic.com/products/Sekonic%20L-758DR%20DIGITALMASTER-documentation.asp ) on page 19.
Personally I think it is strange design on Sekonic's part to put the CINE speeds after the regular shutterspeeds.
And, just before you repeat you don't have a L-748CINE, I did read that in your post. But even the 758D has some CINE functions. The 758Cine just has more.
Does that help?
Rogier
Captain Hook
Either 'm' or 's' or ' '
Sorry, I wasn't explicit enough.
'm' when T is in minutes,
's' when T is in seconds
' ' when T is in 1/seconds.
Either setting gives the same error 'Eu'
Even worse, this would only apply if I select 'T' mode, when I put it in 'F' mode, the T value should be measured by the Sekonic. But it doesn't; it also displays 'Eu'
Even if I maximize all exposure settings. Like maximum ISO value, longest exposure time (T in several seconds/minutes) the F value is still displaying 'Eu' while it should display 'Eo' with this kind of sensitivity. The same thing applies when I select a large aperture (F = 1) and let the Sekonic measure the T value; always 'Eu'.
But, again, as soon as I turn the knob from reflected spot operation to incident operation OR just select flash mode (either 'flash/c' symbol), it works ok. ???
Does that help?
No, sorry.
Re: Either 'm' or 's' or ' '
Does that help?
No, sorry.
OK - I am sorry too. In that case, I'd take it back to the store or contact Sekonic support.
Captain Hook
Verify
Just to be sure:
If you also own a L-758D; does it work if you try the same thing with your Sekonic?
If have already filed a service request at the Dutch Sekonic distributor (= Mamiya). But in the past I had some bad experiences with them. More like no service at all...
Re: Verify
Captain Hook wrote:
Just to be sure:
I have verified this: my L-758DR (notice the R) works fine under the settings you describe. I would conclude your meter has a problem.
Where did you buy it? Can you bring it back to the dealer? The Dutch sekonic distributor works with a dealer network exclusively. They also do Profoto, so I can't believe they would render bad service...
Rogier
wkeuris New Member • Posts: 1
Hi,
I have exactly the same problem! This threat is quite old already, but is the only one I could find on the internet about this problem. Has yours been solved?
gr
Wouter
E E Thompson Forum Member • Posts: 70
Do you have the selector dial set to reflected light mode?
Roman Kazmierczak
Roman Kazmierczak New Member • Posts: 1
I have a similar problem. Spot meter work with ambient but doesn't see flash. When I measure flash with shutter speed set to 2s or so it "sees" modeling light with 0% flash.
I think it may be a firmware problem. I recently made an update. (Note to myself: Do not make updates if everything works fine!!)
I've send an email to Sekonic customer support yesterday and I am waiting for replay.
 Roman Kazmierczak's gear list:Roman Kazmierczak's gear list
Canon EOS 5D Mark III
fotophreek New Member • Posts: 1
I am having the exact same problems experienced by the original thread poster. I have a Sekonic L-758DR that works fine in ambient mode, but when I put it into spot metering mode all I get is a flashing E.U , for Exposure Under, even when I point it directly at a light bulb. Does anyone know if this problem has a fix?
Also, as with the original poster... Yes, the battery is new, and yes, the lens cover is removed when I try to meter.
Any help would be greatly appreciated. Thanks!
UPDATE Nov 8, 2014- Took my meter to Samy's Camera and had one of their guys look at it. Turns out that this type of meter has two photometers built in, one for incident and one for spot metering. It appears that the spot meter on this model is prone to going bad, (which is now pretty obvious considering the number of people who have posted this exact same error). He had seen the problem several times before as well.
Only fix is to send the unit in to Sekonic and have them fix it. Their pre-authorization form, which must be signed and mailed in with the meter, gives a minimum estimate of $125-$250, depending on whether or not they consider this a minor or major repair; and this estimate does not include the cost for parts. This really sucks for anyone that has a Sekonic meter that isn't still covered under the manufacturer's warranty. I really feel that this should NOT be happening on a $700+ light meter!! Besides, how does a photometer go bad on a meter less than 3 years old? There aren't even any moving parts!!
Anyway, to anyone out there considering purchasing a light meter, I would really think twice before buying a light meter manufactured by Sekonic. They obviously use sub-standard parts. You have been warned!!!
Chorepunk New Member • Posts: 1
Hey there! I've just got one used 758cine a couple of weeks ago, and it was working like a champ! Today I was playing with it, and now I'm getting the same eu error in spot metering mode that totally sucks! I live in Mexico City and I think we don't have service here... What happened with yours? Did you send it to repair? How much did u ended up paying if so? I'd really appreciate your feedback! Cheers bro!
