7D+300mm F4L IS Filter Issue-- TEST SHOTS, as requested..
Started Apr 5, 2010 | Discussions
bellevilleguy
Senior MemberPosts: 1,089
Apr 5, 2010
At the request of some interested members I have completed the following test shots with an old Bank Note taped to a cereal box, camera mounted onto tripod and with one shot focus selected, 2 sec timer delay, and image stabilizer turned off.
First shot is the 300mm F4L IS with the Hoya Super Multi Coat filter in place... Second shot is only the lens, with no filter. Third and forth shots are deeper crops.. The RAW files really scream the differences when viewed on DPP !!
The differences I see here in sharpness and contrast are exactly what I was seeing in my shots out in the field and mistook for a focusing issue with the lens... If you have followed my other thread, my shots this weekend with no filter have been like night and day... I would never tell anybody not to use filters, as they provide excellent protection, but just be fore warned, that yes they indeed can impact image quality... Many thanks to those who participated in the first thread, your input and links were most helpful... Original thread is here... http://forums.dpreview.com/forums/read.asp?forum=1019&message=34985371
300mm F4L IS with Hoya SMC Filter
300mm F4L IS with NO filter
Heavy Crop, With Hoya SMC Filter
Heavy Crop, with NO filter
clknight
Veteran MemberPosts: 3,107
So your conclusion is
In reply to bellevilleguy, Apr 5, 2010
that the filter itself is degrading the image? Seems clear enough to me.
Thanks for the follow up.
http://www.pbase.com/clknight
Colin
Canon 7D, 50D, 40D
500mm f/4, 85mm f/1.8, 70-200mm f/4, 17-55mm f/2.8
Kevin G.
Senior MemberPosts: 2,830
Re: 7D+300mm F4L IS Filter Issue-- TEST SHOTS, as requested..
Thanks! This, and other posts have convinced me there's no reason to cover an expensive piece of glass with a filter of any kind, for protection or any other reason.
Kevin
pBase...
http://www.pbase.com/keving54
scottb
Regular MemberPosts: 173
First - weird looking toonie - all flat and miscoloured You don't see many of the bills around anymore.
I have a Hoya HMC Super on my 7D's 18-135 and given your test and field experience I'm going to have to take a closer look and run a few tests of my own. I don't expect my results to be as pronounced given the quality differences between our lenses, but I'm still curious.
Has anyone else tried this? Have you tried with other lenses if you have any with the same width?
Thank you for posting this! I'll be bookmarking the thread.
Scott
bellevilleguy
In reply to scottb, Apr 5, 2010
They don't make toonies like that anymore!! LOL!! I would also like to see if others see similar effects too!! Post to the thread if you do, by all means!!
Cheers!
Hurricane Phil
Senior MemberPosts: 1,049
Your test results definitely back up what you posted, earlier. I'm surprised at the huge difference. Do filters negatively affect your other lenses or just your 300mm?
Great job. Thanks.
Phil
bellevilleguy
Re: So your conclusion is
In reply to clknight, Apr 5, 2010
My conclusion is that yes, ifilter use can affect image quality... Even using good quality filters such as Hoya SMC's they can degrade your images... Another thing to keep in mind too, is that this is a controlled test, fixed on a tripod, with timer release fired.. In real life shooting it will never be that steady and from what I have seen out shooting, the results can be much worse when actually shooting. Which is why I thought it was some sort of focus issue... Thanks for your input along the way!
http://www.photofroggy.com
bellevilleguy
Thanks Phil !!
In reply to Hurricane Phil, Apr 5, 2010
I am going to test my other glass the same way as I did here, all of my lenses have Hoya SMC filters, and I guess are just as prone to image degradation as my 300mm. I hope this info. can help someone else, because top notch image quality is what we all strive for, and so far with my 300mm, that just is not possible with a filter... Thanks for tagging along Phil !
bellevilleguy
In reply to Kevin G., Apr 5, 2010
I'll be removing all of my filters!! that is for sure!!
gm1974
Contributing MemberPosts: 538
In reply to bellevilleguy, Apr 6, 2010
First off, glad you used non-destructive painter's tape on that bill, it's probably worth more than $2 right now Looks like it's pretty much mint condition too.
Second, I put a UV filter on my 24-105L for a day when I first got it, and promptly retired it due to image degradation. This was a B+W filter too, not some cheap $20 special.
I now shoot with a hood on at all times for extra piece of mind, but only use a filter for special things (i.e. a polarizer if needed for certain effects) and then it's back to a naked lens for me.
I think these front elements are designed to be pretty tough. Someone posted a YouTube video of some guy whacking the cr@p out of a nifty 50's front element and it looked like it can take a fair amount of abuse. If you are going to have something happen to a lens that's going to wreck the front element, then I'm guessing there will probably be some internal damage too
p.s. I spent a bunch of summers at the base in Trenton during my teens. Beautiful part of the province. I still try and get out to Sandbanks when I'm back in Ontario visiting family/friends.
Cheers
http://www.flickr.com/gm1974
Dietmar Fichter
Senior MemberPosts: 1,655
Re: Thanks Phil !!
Years ago on this forum, the filter issue came up in a heated discussion and is not new that degradation occurs when sticking a inferior piece of glass in front of superior quality glass. It's nice however to see some conclusive results.
Dietmar
bellevilleguy
In reply to gm1974, Apr 6, 2010
Ya, I've had that old $2 bill for years now!! LOL!! Nice to hear of other peoples issues with filters too!!
I love the Sandbanks provincial park! I usually get there at least a few times a year!! Nice place to go shooting too!
Thanks for chiming in!
Peter 13
Veteran MemberPosts: 8,301
Repeat the test by taking the shots at an angle slightly different than 90 degrees. Look for misfocus. This way you will know whether the filiter causes AF problems or really degrades the image.
I have done many experiments with my 70-200 f/4 IS with and without an B+W filter. No difference at all. The only downside of the filter is flare under extreme conditions - a light source in the frame.
clknight
Sounds like a load off of your shoulders. Enjoy!! (NT)
Colin
Canon 7D, 50D, 40D
guy schlacter
Senior MemberPosts: 1,030
Re: Sounds like a load off of your shoulders. Enjoy!! (NT)
In reply to clknight, Apr 6, 2010
Two things are needed to round out your test....
1. Since the Hoya Super HMC (and HMC) were top rated in a published test, and showed improved results and no image degradation, I suggest you try a second copy of the filter to determine whether you have a bad copy.
2. Take shot at Angle to determine AF issue (notate and use center spot AF) - determine whether some slight front / back focus issue occurring
IMHO, Your results seem too dramaticly different to simply say it is all HMC Hoya filters that degrade IQ.
-Guy
clknight
I think he's finished.
In reply to guy schlacter, Apr 6, 2010
No, really, I think he's done with filters. LOL
You may have a valid point, true enough. But something tells me.....yeah, he's done.
Colin
Canon 7D, 50D, 40D
rwbaron
Veteran MemberPosts: 7,425Gear list
I think what would be worthwhile...
would be to shoot one series using the phase detect AF with and without the filter and another using contrast detect in liveview. This would tell you if the filter itself is screwing with the IQ or if the phase detect AF doesn't like the filter. There is an obvious difference that looks like a loss of contrast but lower contrast can be the result of slight misfocus too.
Bob
http://www.pbase.com/rwbaron
 rwbaron's gear list:rwbaron's gear list
Canon PowerShot G9 Canon PowerShot S90 Canon PowerShot G1 X Canon EOS 50D Canon EOS 7D +16 more
mmullen
Veteran MemberPosts: 4,256Gear list
Re: I think what would be worthwhile...
In reply to rwbaron, Apr 6, 2010
Yes, but it doesn't matter what is causing the problem, mis-focus caused by the filter or lack of contrast and sharpness caused by the filter, the net effect is the same - less than optimal images.
That's why I never use filters for "protection".
Mike Mullen
 mmullen's gear list:mmullen's gear list
Canon PowerShot S80 Canon PowerShot G11 Canon EOS 40D Canon EOS 7D Canon EF 85mm f/1.8 USM +8 more
rwbaron
In reply to mmullen, Apr 6, 2010
I've never seen this with any camera body or lens using B+W UV filters and I test extensively. I'd like to know what's causing this and if it's related to the 7D PD AF using the Hoya filter. None of my lenses long or short on my 7D have shown this issue with my filters.
Bob
mmullen
It's not specific to the 7D, lots of filter problems have been reported before the 7D was even available. But the higher resolution of the 7D is more likely to show filter issues because you can view the images at a higher magnification. That is not a problem but a benefit.
Mike Mullen
