Aftermarket battery
Started Apr 1, 2010 | Discussions
Owen
Owen Senior Member • Posts: 2,578
Aftermarket battery
Bought an aftermarket battery for my 5D mkII about 6 months ago. Label on it says CTA. I never used it much. Last night I charged it and nothing, camera would show a dead battery. I mainly purchased it as a backup. I will try charging it again but I am not hopeful.
Beware if you have one of these.
Owen
GtoJon
GtoJon Veteran Member • Posts: 3,549
Thanks for the Heads-Up : )) (nt)
http://www.JonSmithers.com GtoJon -
Taken any photographs lately?
 GtoJon's gear list:GtoJon's gear list
Panasonic Lumix DMC-LX100 Canon EOS 7D Mark II Sigma 120-300mm F2.8 EX DG OS HSM Canon EF 24-105mm f/4L IS USM Sigma 12-24mm F4.5-5.6 II DG HSM +9 more
Scales USA Veteran Member • Posts: 3,121
Re: Aftermarket battery
Owen
You are lucky, I bought a used Sony digital camera with a aftermarket li-on battery that had expanded until it would not come out of the camera. I spent a hour carefully drilling it dozens of times until I could take it out in pieces. Then, I bought a authentic one.
Remember, these aftermarket batteries are made by the country that let dairy producers cheat on baby's milk. Do you think they care about your camera battery?
 Scales USA's gear list:Scales USA's gear list
Canon PowerShot G1 X II
Steve Burger Forum Member • Posts: 72
Only the Canon battery will work right away and give charge levels. An good fully charged aftermarket battery will give an error message on screen and them work fine but show no charge. Are you sure you did not get the battery communication message... you have to choose to use the battery a start up when you get the message. I have a couple of the aftermarket batteries which I use for backup for trave,l I charge the Canon battery right away and use aftermarket ones when I can not charge. Canon battery charges fine in aftermarket charger so you don't need to carry both.
Will Rushmore Regular Member • Posts: 467
To be honest, the "original" batteries are likely to be made exactly in the same country. It's not where they're made that matters, it's whose logo they bear and how much the owner of that logo cares about being sued.
wa2n Regular Member • Posts: 173
Also, the aftermarket batteries won't be charged on the Canon charger - only an aftermarket charger will allow the charge to proceed. Conversely, the aftermarket charger will charge a Canon battery. So if you forget and leave a charger home, leave the Canon.
Owen
Owen OP Senior Member • Posts: 2,578
Got the message
and clicked o.k. Battery indicator on the top LCD flashes empty.
Owen
Owen
Tried charging it again
Put it back in the camera and all was ok, for awhile, went out a couple of hours later and the battery was dead.
That's what I get for not buying a Canon replacement.
Owen
txww Regular Member • Posts: 202
Re: Tried charging it again
Are you sure you get the right battery? I have 2 after market batteries for my 5D and have not had a bit of trouble with them. In fact they last longer then the original Canon battery does. They also fit and charge in the Canon charger. That's why I wonder if you got the correct battery.
Don Krauss
Don Krauss Contributing Member • Posts: 708
I have had good results with CTA batteries. I used them on my old 5D, 40D, and 20D.
Today I have two CTA batteries for my 5D mark II. I use the battery grip and mix one Canon and one CTA. The Canon battery reports the charge level, so when it is low, then I know the CTA is also low.
So far the pairs has been working fine, and it has saved me a few bucks, plus I have a second charger for the CTA batteries.
-DK
Many aftermarket battery brands don't actually manufacture anything, they just buy the batteries (from multiple suppliers), slap their logo on them and sell them in a different country. This means batteries of the same "brand" might come from completely different manufacturers. This would be fine if the final "brand" had any quality control, but most of the time they don't (they just import, repackage and resell), so it's a matter of luck.
Canon and Nikon probably don't manufacture their own batteries, either (I'm sure Nikon doesn't, Canon might), but they do put them through quality control, since bad batteries would affect their reputation.
Nikon1977 Contributing Member • Posts: 515
I checked my LP-E6 battery for my 5d Mark II and it says "Cells made in Japan", "Further processed in China". I assume any circuitry and packaging were done in China. In some cases, the manufacturers will have company owned plants in other countries to reduce cost.
Well, there are good and bad manufacturers (of pretty much anything) in China, so it's still a matter of luck. Unless you know the exact manufacturer (which can be nearly impossible to find out), the best indicator of quality is whether or not some major brand was willing to slap their logo on it. That won't guarantee you're getting the best, but it (almost) guarantees you won't be getting something terrible.
kevindar
kevindar Veteran Member • Posts: 4,038
bought 2 for my 5d2 a year ago. they charge in canon charger, show amount of charge, and have been working fine for a year. bought them for 16 each. canon was going for 80 back then. There was a seller on ebay selling them for a period of about a week. dont know what they were pulled.
http://www.flickr.com/photos/11731152@N00/
 kevindar's gear list:kevindar's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 85mm f/1.2L II USM Canon EF 24-70mm f/2.8L II USM Sony a6000 +23 more
Robert Sheldon Senior Member • Posts: 2,098
I got mine at the same time and it is still working. The next week the seller reported he was having "supplier" problems and has never had them since that one time.
Bob Sheldon
Photo Gallery at
http://www.bobsheldon.com
lensman57 Regular Member • Posts: 341
Owen
The funny thing is this particular country is also manufacturing about 90% of the electronic equipment that we use today including DSLRs, Flash units , Mac computers etc, etc ,etc . long live free global ( cheap labour, low quality) market economy.
